Old 08-04-2004, 12:56 PM   #1
Send a message via ICQ to rcnewb2004
Default V2 revolution gearing with a TA-04 anyone?
Hi,
I want to run a ta04-trf with the peak surikarn edition v2 10x1 motor.
Can anyone suggest some gearing?
(And pls try not to gimme a ratio)... as I dont' know how to calucalate from the ratio back into size of pinion and spurs.
Currently, I am using 0.4 module (similar to 64 pitch) 34T pinion with 128T spur
Any ta04 racers, please gimme some help!!!!
rcnewb2004 is offline   Reply With Quote
Old 08-04-2004, 02:38 PM   #2
Rick Hohwart's Avatar
8.0 - 8.5 to 1
Someone who knows your transmission ratio can tell you what gears to use to get this ratio.
Rick Hohwart is offline   Reply With Quote
Old 08-04-2004, 02:41 PM   #3
Thanks very much. My current setting is a 8 to 1... but i think i might have to go a bit lower... but i am not sure if my car will support it, since the manual does not give me any table values with a pinion smaller than 34T
so it has left me suspecting....
Old 08-05-2004, 09:40 PM   #4
rto997's Avatar
goto www.gearchart.com They have a program that will help you figure what gears to use!!
Royal Rumble Racing- OG
rto997 is offline   Reply With Quote
Old 08-05-2004, 10:25 PM   #5
Unfortuately.... I have no idea what to do in that website so it will give me some numbers.
Old 08-05-2004, 10:30 PM   #6
rtypec's Avatar
Please find attached a zip file containing an excel file with spur/pinion gear chart. Use the ones labeled for "414" and you should get the spur/pinion combo you need.
rtypec is offline   Reply With Quote
Old 08-05-2004, 10:58 PM   #7
thx rtypec
does anyone know the rpm of a peak surikarn edition 10x1?
Old 08-05-2004, 11:35 PM   #8
Tek Nickal's Avatar
Well, RPM varies from motor to motor, thats why motor companies usually have Dyno sheets included with the motor.
Tek Nickal is offline   Reply With Quote
Revolution BuggyKing Chat Lounge 3 05-01-2008 10:16 AM
FS Team Orion Revolution Touring V2 7x1 Revolution Modified (2) darchard123 R/C Items: For Sale/Trade 1 01-30-2007 10:28 AM
ESC for Revolution HVAC25000 Electric On-Road 6 05-17-2006 10:20 PM
revolution 7x1 [email protected] R/C Items: For Sale/Trade 1 09-30-2005 04:26 PM
PTI EVO 2 Revolution Kyew Electric On-Road 39 12-09-2004 05:23 PM
