Thunder Power RC Z3R Motors >
Like Tree1Likes
Old 07-24-2013, 11:00 AM
  #511
big al's Avatar
Need a little help here guys. I recently purchased a used 17.5, that seems to run fine. My only issue is that it's a bit noisy. I thought maybe the sensor was causing it, but my tekin shows that all 3 sensors are reporting. The bearings are very quiet. I'm a bit stumped. Any help is appreciated!
big al is offline
Old 07-24-2013, 02:23 PM
  #512
I'm looking at getting a option rotor for my 17.15 which one will be better to get the blue one or the green one ?
Thanks ...
mwoods is offline
Old 07-24-2013, 02:34 PM
  #513
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Thanks ...
What class?
OVA is offline
Old 07-24-2013, 10:22 PM
  #514
Originally Posted by OVA
What class?
Oops meant to be 17.5 and it will be touring cars ...
mwoods is offline
Old 07-25-2013, 01:02 AM
  #515
Hi
I have just got a 17.5 TP motor. Used it and ran the same gearing as my other motors Dynamite DPS and Reedy but the TP came of really hot 20c hotter than my other 2 motors.
Is the motor to be geared much lower than other motors as it started to go soft the last 2 mins of the race.
The gearing I was running was between 3.2 and 3.3
Many thanks for your help.
415tam is offline
Old 07-25-2013, 01:39 AM
  #516
Skiddins's Avatar
One thing I found with one of mine was that the stator was slightly loose in the can. This meant it could twist very slightly inside the can.
I solved it by adding a second fibre glass gasket up against the original.
Skiddins
Skiddins is offline
Old 07-25-2013, 10:57 AM
  #517
big al's Avatar
Skiddins
I'll take a look. Never thought of that. Many thanks! I wonder if some thermal compound would help that....
big al is offline
Old 07-25-2013, 11:00 AM
  #518
bhambrent's Avatar
Originally Posted by bhambrent
When is the new Thunder power motor's coming out?
I want to stay with the Thunder Power brand, but can't wait to much longer!.
Still would like to here some one from Thunder Power. To give a Yes or No.
Thanks,
b.wiley
bhambrent is offline
Old 07-26-2013, 01:23 AM
  #519
Skiddins's Avatar
Paste on it's own wont do anything.
Skiddins is offline
Old 07-26-2013, 06:16 PM
  #520
big al's Avatar
I've found that although the paste doesn't lower the temp, it does seem to help dissipate heat quicker. Your mileage may vary.
big al is offline
Old 07-27-2013, 02:32 AM
  #521
Skiddins's Avatar
Try measuring the temp through the vent holes with and without paste, you'll see a difference.
Skiddins
Skiddins is offline
Old 07-27-2013, 10:57 AM
  #522
ThunderPowerRC's Avatar
Originally Posted by 415tam
Hi
Because the Z3R uses a smaller rotor it needs to be gears lower than the other motors you mentioned. You can also change to the Blue tuning rotor.
Thanks,
b.wiley
There are a number of things in the works.
ThunderPowerRC is offline
Old 07-27-2013, 11:01 AM
  #523
Could be a slight magnetic unbalance in the stator or rotor. As long as it runs fine it should be no problem. Otherwise you can try another stator.
Old 07-28-2013, 04:46 AM
  #524
Bill K's Avatar
Recently purchased one of these motors for 17.5 boosted state titles approaching.
Currently I am running a 6.25 FDR, with somewhat 40 degrees of boost and 30 degrees turbo on the new HW v3.1 ESC. I have 20 degrees of motor timing on the endbell using the red rotor, and from my experience this thing rocks!
Although, after every run it has a very strong smell to the motor, it performs very well, but I still want some more performance out of it to keep up with some of the faster racers. After a 6 minute run the motor comes off at about 70C with a heat sink and fan, and only once after a 15m run did it come of at 95C (Absolute borderline!!).
For about a 50m straight, this is the only area lacking competitive racing, as a few (not all) racers are alot faster. Can anyone suggest some HW settings that would maybe increase the performance? Or should I be going down on settings and changing timing or FDR?
Bill K is offline
Old 07-28-2013, 10:32 AM
  #525
Hi ThunderPowerRC, thanks for getting back about my gearing question.
Can I just confirm that the TP 17.5 (as comes out of the box) should be geared from my current gearing of 3.2 - 3.3 to say 2.9 or lower.
Is this the right way to gear the motor as per your suggestion.
I just want to make sure I am gearing the right way before I run the TP 17.5 motor again.
Many thanks.
415tam is offline
