Thunder Power RC Z3R Motors
#406
Hi All
I have a couple of thunder power z3r 13.5 motors which come with original phillips type timing cap screws, which are starting to round off.
I notice on a lot of the newer thunderpower motors the timing cap screws seem to be of the hex driver type, i was just wondering if anyone knew what the size of these screws were - or even better if thunderpower sold them and if so what the part number was.
Hope the above makes sense
Mark
Mark
#407
Hi,
they are:
M2.5 X 10 SOCKET COUNTERSUNK STAINLESS 20 PACK FREEPOST
from either ebay or:
http://www.triard.co.uk/
they are:
#408
Hi All
Mark
Mark
Hi,
they are:
they are:
McMaster Carr #91294A018 : mcmaster.com
#409
Hi
We run 17,5 blinky , but with gearing limited at 4,00. What Will you say is the right rotor ?? The green One has the most tourqe , but ......
#410
#411
Hi guys,
I'm just about to start racing 13.5 boosted with a TP motor and Xerun v2.1 esc. Can anyone offer me some tips in terms of setup, max amount of timing to keep the motor safe etc?
I'm guessing total timing is motor timing + boost timing + turbo?
Thanks for the help!!
Dan
Dan
#412
Hey Guys
Need a tekin esc setup with a thunderpower 17.5 boosted a gear ratio of 5.5
__________________________________________________ _
TC6.1 LRP 21.5 TEKIN RS
TC6.1 WC REEDY 21.5
TC6.1 WC REEDY 21.5
#413
Hi guys,
Dan
Dan
#414
suggestions please for a 10.5.
Best can timing?
Do these motors like to be geared down (Small pinion High FDR) or geared up (large pinion low FDR)
Best can timing?
#416
I need a good starting point for 17.5 blinky
Lrp sxx v2
Med/high traction IMO
fairly descent size track 150-180ft straight
Motors new with blue rotor
Any help appreciated thanks
Lrp sxx v2
#418
I just acquired the ESC and have no idea how it performs (bought used off rctech) the motor is new too.. I'll be at horsham tomorrow for sure, especially since I can't make the nat this will be the next best thing.. Thanks brother ill see you there
#419
So I purchased a pre-owned one. The instruction manual is vague. It arrived with the timing set at 20 degrees, I should set it to zero, when setting my ESC, etc.? Does this motor require a capacitor?
#420
Always start at 20deg. Never go below 15deg on the motor. If you are running no boost, set timing at 30deg and gear fro temp. If you are using boost, again start at 20deg and adjust timing in ESC.
