Thunder Power RC Z3R Motors >
Like Tree1Likes
Old 03-11-2012, 09:30 AM
  #151
Skiddins's Avatar
What motor timing are you guys running in boosted classes?
What timing seems to provide the most torque?
I've found that increasing the motor timing does seem to improve acceleration even though logic would suggest the extra timing will reduce the grunt.
Skiddins
Skiddins is offline
Old 03-11-2012, 09:36 AM
  #152
LOW ET's Avatar
Trader Rating: 109 (100%+)
20* on motor, everything else in the esc.
LOW ET is offline
Old 03-13-2012, 01:30 PM
  #153
Skiddins's Avatar
What class and size or track was that on?
Skiddins is offline
Old 03-13-2012, 01:38 PM
  #154
LOW ET's Avatar
17.5 boosted touring car. not real sure on the track size but i think 40X90. this is with the blue rotor.
LOW ET is offline
Old 03-13-2012, 01:53 PM
  #155
ThunderPowerRC's Avatar
17.5 Boosted TC
30 motor
50 boost
15 turbo
5000 -14000 rpm
.1 delay
10 min throttle
10 min brake
2 ramp
geared around 5.5
Red rotor
ThunderPowerRC is offline
Old 03-13-2012, 02:38 PM
  #156
Skiddins's Avatar
Originally Posted by ThunderPowerRC
17.5 Boosted TC
30 motor
50 boost
15 turbo
5000 -14000 rpm
.1 delay
10 min throttle
10 min brake
2 ramp
geared around 5.5
Red rotor
Anyone have any idea on gearing and motor timing on this track in boosted 13.5
In the Video they were GT10's running 1s 10.5;
+ YouTube Video
Skiddins is offline
Old 03-13-2012, 03:54 PM
  #157
racer x 1's Avatar
Trader Rating: 27 (100%+)
Default 1/12 blinky
Hey guys just thought Id share my settings.
25* on the can
rollout usually 97mm
stock rotor(red)
and on this page theres a few 1/12 races im in the all green. http://www.tqrcracing.com/forum/gallery.asp
racer x 1 is offline
Old 03-27-2012, 11:37 AM
  #158
Skiddins's Avatar
I must confess that I'm seeing the best results for accelleration and speed when the motor timing is between 25-30deg.
This is with the ESC backed off a bit, 42-48deg timing (max available is 55)
Whenever I have run 20deg timing on the motor, it is still fairly fast, but just seems to lack the oomph out of slower corners.
I have run 32deg a couple of times but blew a stator at my last outdoor meeting.
I have also found that it likes to rev a lot so I have geared down a long way.
8.20FDR on 13.5 boosted TC indoors
Skiddins is offline
Old 03-27-2012, 04:08 PM
  #159
Craig W's Avatar
you will get bottom end by going to blue rotor wich has been sent to brca
Craig W is offline
Old 03-27-2012, 04:37 PM
  #160
easye's Avatar
Ok guy new to touring car got a tc6.1 with 17,5 motor what gearing to run with boost. Will be racing at Leisure hours raceway with a 220' straight. Tekin esc set up would be great to. Thanks Eric
easye is offline
Old 03-27-2012, 05:10 PM
  #161
Skiddins's Avatar
Perhaps, but 'sent to BRCA' isn't quite the same as 'BRCA legal'
Is there any news on whether they'll allow it or not, and was the purple rotor also sent??
Do you know what the gauss rating is for the blue rotor?
Skiddins is offline
Old 03-27-2012, 05:49 PM
  #162
Craig W's Avatar
same as red but with stronger magnet
blue and green were sent to brca
but uk imports as changed
all i know is blue and green were sent to brca same time as motor
you could me paul worsley to see
Craig W is offline
Old 03-28-2012, 01:58 PM
  #163
All of the motors were submited to Paul Worsley at BRCA along with all of the tuning rotors. paul was waiting on the UK dist to notify him they had them in stock. They never ordered the rotors and no notification was given to Paul. We have another dist coming on line here very soon. They will notify Paul once they are in stock. At that time all rotors will be allowed.
Old 03-28-2012, 02:53 PM
  #164
Craig W's Avatar
thank u thunder
Craig W is offline
Old 03-28-2012, 07:12 PM
  #165
defcone's Avatar
Trader Rating: 15 (100%+)
17.5 Boosted TC
30 motor
50 boost
15 turbo
5000 -14000 rpm
.1 delay
10 min throttle
10 min brake
2 ramp
geared around 5.5
Red rotor
How were the temps running the motor like that?
defcone is offline
