User Opinions TB02/TB03 >
Old 08-03-2004, 11:09 PM
Default User Opinions TB02/TB03
I am interested in buying a TB02 to race.
I currently own a TB03 Surikarn Limited Edition and find that I am forever destroying the bevel gears located in the front and rear gear boxes.
Can anyone that owns a TB02 please advise if the same problem occurs given Tamiya static driveshaft option they have included in the TB model series.
Alternatively could those of you that own a TB03 Surikarn Limited Edition offer any suggestions on how to prevent the bevel gears from becoming damaged in the front and rear gear boxes.
Thanks!
bawho is offline
Old 08-04-2004, 04:59 PM
dsrbltoys's Avatar
The evo III shaft fits a little loose. If you use the tb02 shaft in the evoIII it fits really well. There is also a lt wt shaft same length.
dsrbltoys is offline
Old 08-04-2004, 05:43 PM
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks!
like what dsrbltoys mentioned above... use the lightweight shaft in your EvoIIISE and pick up the new bevel gears. they are fatter than the old ones and made of a new material. if possible, use the penguin backing plate. best way to not strip a gear is to avoid hard crashes good luck!
Hebiki is offline
Old 08-04-2004, 06:08 PM
Speedtech RC has the gears and the new prop shaft (part number 53686) < be sure to get that EXACT part number or your not getting the right shaft
My Evo3 SL is out of commision too...Just new gears, shaft and diff outdrives needed (those white ones keep breaking)
The Black Kat is offline
Old 08-04-2004, 08:20 PM
Can you explain to me that the penguin backing plate is?
bawho is offline
Old 08-05-2004, 02:47 PM
nerdling's Avatar
nerdling is offline
Old 08-31-2004, 09:48 AM
Stark's Avatar
there is this.
http://64.70.208.72/speedtechrc/85.html
But it's sold out.
so we could try this.
TAM53626 Tamiya carbon back plate for EVOIII one-way
http://www.sslorder.com/speedtechrc/261.html
Tamiya carbon back plate for EVOIII one-way. A must hop-up to prevent stripping of the front one-way ring gear
Where do we find these larger gears?
Stark is offline
Old 08-31-2004, 05:08 PM
The carbon backing plate does CRAP for your problem...I just stripped an emense amount of crown gears
The shaft IS the solution. Go to Tower Hobbies and do a little hunting for it. They got it
