Old 08-03-2004, 09:17 PM   #1
Send a message via AIM to Just got one
Default Drifting Is HARD!!!!
I just tried out my new ABS tires, WOW, its hella hard!
Its like running on ice with ABS for tires
Any tips?
Just got one is offline   Reply With Quote
Old 08-03-2004, 09:32 PM   #2
Joel Lagace's Avatar
put the rubber tires back on! LOL
serioulsy: Try some soft springs and light oil. you have 0% traction so you need to get the car to at least shift weight over the tires..... i mean pucks
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-03-2004, 09:44 PM   #3
Ok, thanks ill try that
Old 08-03-2004, 09:52 PM   #4
Send a message via AIM to ThaFlash_LA
My HPI treaded tires let me drift just fine with a very very worn out 13 turn. I just don't think that they are intended to do that. Seriously though, you are supposed to lower traction when drifting, but you do need some to prevent ice skating.
ThaFlash_LA is offline   Reply With Quote
Old 08-04-2004, 01:03 AM   #5
u have to steer with the throtle u give it throtle to push and let of for more steering and if u are going to hit something u have to turn away from the object and gun it after a while u will get ahold of it i did about the third run in
nick b. is offline   Reply With Quote
Old 08-04-2004, 07:51 PM   #6
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Heres how I drift. Go to the corner at 1/2 throttle. While turning into the corner, let go. You will now feel that the rear end is loose. Now floor the throttle and countersteer.
DOMOisCOOL is offline   Reply With Quote
Old 08-04-2004, 09:44 PM   #7
kuanseng1981's Avatar
Trader Rating: 15 (100%+)
Default Drifting
If u let go throttle while into the coner u will spin out.
The best is to play with the throttle for example 1/2 3/4 1/2 3/4 throttle to make the rear throw and the front wheel to grip and also your steering. and we drifters in Singapore used very soft spring infront and hard spring at the back and all round 0 camber, with PVC and stock sliver can motor. Cause we believe in power is unless without control. And the silver can provide just enough trouqe and speed without comprising run time.
I've seen some ppl just play drift for a while and give up cause they say that they can't control the drift.
The reason is because they just played for a while and just give up. Hope u guys out there know that drift is different from grip where u turn the wheel the car dun turn where in grip it is the oppsite.
Hope u have fun.
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
Old 08-07-2004, 01:09 AM   #8
bubbles's Avatar
Do you really drift?
bubbles is offline   Reply With Quote
Old 08-07-2004, 01:11 AM   #9
Tek Nickal's Avatar
More traction is bad in drifting.
Tek Nickal is offline   Reply With Quote
Old 08-07-2004, 04:30 AM   #10
Default Foams are good too
hey
hes my advice if you cant get your car to drift with rubber tires try foam tires but they have to be hard e.g 45 front and 42 rears with the suspension all round has to be firm and have 0 camber all round
Also i use a D5 trinity 10 turn that can hold the drift nice and long also i go around a corner and at least you must have 1/4 throttle when you are half way around the corner FULL THROTTLE and you car will break traction and thats it but when your car looks like its getting traction back turn the car in the oppostie direction and put on the breaks a bit then flatten it again and it with driift the other way
Also the added bonus with foams is it looks like smoke for the tires when they spin
Its really exciting
See ya guys
mr barracuda is offline   Reply With Quote
Old 08-07-2004, 05:21 AM   #11
Drifting is controlling a car that is out of control... of course it isn't easy but it is fun too....
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-07-2004, 06:06 AM   #12
pheyhoe's Avatar
Post
drifting is like racing on polished to be honest. on polished wood the car is never going properly staight with no wheelspin.
theres a few videos on my site and you might be able to tell how slippy the floor actually is. erm download racing at grrcc and onboard footage.
link is erm................
http://www.thedinghy.co.uk/ter/site/article.php?11.255
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
1/10 & 1/18 RC Drifting Speed Demon Malaysian R/C Racers 115 06-22-2009 11:16 PM
Drifting! ValleyNitro Nitro On-Road 12 08-10-2005 01:08 PM
Drifting? t3guy Nitro On-Road 59 11-18-2004 03:46 AM
Drifting Set-up Just got one Electric On-Road 2 05-02-2004 12:07 PM
HPI Sport2 - die hard, mega hard ! Cole Trickle Electric On-Road 6 07-07-2002 12:40 PM
