Old 01-06-2011, 05:55 PM   #16
Originally Posted by jrp View Post
Been using these since 1S became the standard...
http://hobbyking.com/hobbyking/store...idProduct=7884
thanks for sharing that link!
i`m new to 1:12 and 1s racing. if i buy the hobbyking booster, only thing i need to do is to solder a wire from the male to the + battery cable? or am i wrong?
or do i need to solder 2 wires, one to + and one to -?
Hatebreed is offline   Reply With Quote
Old 01-06-2011, 06:19 PM   #17
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
I solder the + & - to the battery terminals on my speedo. I also wire a switch in-line on the + side. Then you can just plug the other end into an open slot on your receiver.
To make it even easier to change or remove, I solder a servo lead from the + & - on the speedo and then just plug the booster pins into the servo lead. That way I actually use the booster without modifying or soldering directly to it. While I rarely ever un-plugged it, I like the idea of being able to drop in a replacement booster very quickly.
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 01-07-2011, 12:49 PM   #18
team green's Avatar
Just want to know if this booster will work? The airplane guy's use these..
http://www.dimensionengineering.com/...yVoltMicro.pdf
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Mugen MTC1
Associated B6
TLR 22-4 2.0
team green is offline   Reply With Quote
Old 01-07-2011, 02:27 PM   #19
V12
V12's Avatar
This booster has just a 0.5A output what is not enough in my opinion. Also the voltage output range is to much adjustable so if you adjust a too high voltage accidentally you will kill all of your electronics in the car. I would prefere a fixed output voltage for this reason.
Iīm just using the cheap Hobbyking booster and this works for me. Voltage with 5V is a little on the low side but I didnīt wanted investing very much as I run 1/12 very rarely now. If you want a higher quality booster there are the Dynamic booster, the Robitronic and the one from Sweden brand Team Laje what looks the best to me.
V12 is offline   Reply With Quote
Old 01-07-2011, 03:12 PM   #20
Default rc dynamics
There is only one choice the rc dynamics, forget the Novak .Worth paying that bit extra, very small and built in switch, they also make one suitable for the AE BDiamond Esc.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
1/12th Scale Wiring...(1S) StickyFingaz Electric On-Road 108 05-04-2010 08:59 AM
New SpeedMerchant Rev 5 Lipo Edition 1/12th scale jsmax R/C Items: For Sale/Trade 12 02-08-2010 11:44 AM
help me juice up my novak gtb 4 cell for 1/12th scale tomkelley Electric On-Road 7 01-20-2010 07:03 PM
