Making a pack... >
Making a pack...
Making a pack...
Old 08-03-2004, 07:36 PM
onebeatuptc3's Avatar
Default Making a pack...
I was thinking, if i were to take apart my stick pack and make it into a side by side pack, would there be any advantage? (its a corally 2000mah pack)
onebeatuptc3 is offline
Old 08-03-2004, 09:25 PM
the main advantage is that it makes matching easier, and you can equalize your battery cells.
rcnewb2004 is offline
Old 08-03-2004, 10:23 PM
Wency_TA03R-PRO's Avatar
Exclamation
It also make your car looks good with that bullets in your side by side configuration battery..
Wency_TA03R-PRO is offline
Old 08-03-2004, 10:42 PM
I had this done to my packs by a mate a few weeks ago, I got easily another 1/3rd the punch from the same packs and esc, not to mention more run time.
Plus they look a whole bunch better!
v0rtex is offline
Old 08-03-2004, 11:38 PM
u also get better conductivity because u can use different bars to connect the batteries. like dean bars instead of the traditional spot weld (that limits current flowing between cells)
Old 08-04-2004, 12:49 AM
This site will answer all your questions: http://www.balakracing.com/convertsidebyside.htm
micros_rock is offline
Old 08-04-2004, 12:59 AM
Runtime increase for me......... Dont know why.
Just got one is offline
Old 08-04-2004, 01:06 AM
Better conductivity on the battery bars vs the ones used in a stick pack. which is only spot welded in 2 tiny places
Old 08-04-2004, 08:19 AM
Suspended
cr250 is offline
