Intellect 7.4v 6200mah 60C >
Old 01-04-2011, 03:29 PM
Default Intellect 7.4v 6200mah 60C
Anyone try Intellect 7.4v 6200mah 60C?
It is good lipo or better get SMC?
Regards!
M.Abramowicz is offline
Old 01-04-2011, 05:13 PM
They are good my SMCs swelled.
Cammer is offline
Old 01-04-2011, 11:26 PM
Regards!
Check out CRC's new lipos @ teamcrc.com. Heard great things about the 1s stuff.
roadbeast is offline
Old 01-05-2011, 01:22 PM
Thanks!
I got 2x new smc 6200 extreme bla bla in great place
Maybe next month I check intellect
Regards!
Old 01-13-2011, 02:24 AM
anyone have this batteries just now? They charge really 6200 or not?
Mi other IP 5000 lipos never charged this, and they never fill more than 4600mAh.
The same with that new lipos? If so, why?
Thanks!
Psycho_ is offline
Old 01-13-2011, 10:48 AM
ngo8's Avatar
IP best baterrys out there hands down and for the price you can get them at the perfomance and quallity can not be matched i had puffy smc and puffy thunder power and never again just get some ip and you will be happy .
ngo8 is offline
Old 01-25-2011, 02:59 PM
darrenoakley's Avatar
I have seen IP lipos puff also.
darrenoakley is offline
Old 02-02-2011, 06:34 PM
YoDog's Avatar
Trader Rating: 28 (100%+)
Thanks!
You will never fully discharge the battery and that's why they don't show as taking in the full capacity charge.
If you do fully discharge the battery it will be ruined anyway.
The amount charged is relative to the charge state of the battery prior to charging.
YoDog is offline
Old 02-02-2011, 07:46 PM
McbainRc's Avatar
I changed from IP to FANTON batteries because the IP's swell heaps on everyone we have had and lots of people we know.
McbainRc is offline
Old 02-04-2011, 02:17 PM
simplechamp's Avatar
Trader Rating: 73 (100%+)
I run my Turnigy and Flightmax 2S 5000mah hardcase packs from 4.2V/cell down to 3.2V/cell cut-off and they take back 5000mah according to the charger.
simplechamp is offline
Old 02-04-2011, 03:50 PM
YoDog's Avatar
Your charger may be storing the charge data for that pack and thus factoring in the residual charge in the used pack. Otherwise, you cant charge in 5000mah into a battery that has only had 2000mah discharged or else KABLOOIE! It may change if you change the settings on your charger to accommodate a different pack and then it will start over.
My hyperion stores this data and maintains statistical information on my packs if I either keep the setting the same or tell it to track a specific pack.
Get's kinda complicated...
YoDog is offline
