Electronics...Which ones? >
Old 08-02-2004, 09:03 PM
Napalm's Avatar
Default Electronics...Which ones?
Ok getting my rig put together now. What are your suggestions on some of the electronics?
Chassis: Evo IV, Tamiya
Speed Control: Novak vs. Tekin GT-7 or G-10
Reciever: ?
Radio Control: JR R-1 Pro PCM Radio 75mhz vs. Airtronics
Batteries: 6 cell pack: Promatch or Fukuyama
Charger:
Discharger: Novak Tray
Motor Tuner/Break in:
I know thats a ton of info but Im just trying to purchase the right stuff from the start...
Thanks.
Napalm is offline
Old 08-02-2004, 09:11 PM
Go with the GT-7 and the airtronics radio. The best charger out right now is probably the gfx but you are looking at a lot of money. A cheaper charger that is decent is the lrp pulsar. Both of them do motor break in as well.
shortygy is offline
Old 08-02-2004, 09:15 PM
Napalm's Avatar
Yeah Ive got a bid over at EBay on a GFX and its just under $400.00 will let you know if I get it... btw its new in the box.
Napalm is offline
Old 08-02-2004, 09:27 PM
Wency_TA03R-PRO's Avatar
Exclamation
I go with the JR radio and use the receiver that goes with it..
Wency_TA03R-PRO is offline
Old 08-02-2004, 09:47 PM
Batteries: You will probably be impressed with either pro-match or fukuyama. You'll probably want to invest in a nice iron to put together your batteries.
Battery tray: I would consider the novak tray to be a luxury. You could also look into a few integy trays as well. I'm of the lazy type and just use my quasar pro occasionaly to dump most of the charge from the cells.
I would definitely buy a JR R1 over the airtronics. It's a personal preference, but I rarely glitch with an R1.
071crazy is offline
Old 08-02-2004, 09:49 PM
ESC: You could also consider a Quantum 2. Or, if you can find a good 'ole Novak Cyclone for cheap (50 or less), then that'll be a great control as well. You can run a 9 single in 95 degree weather and still not worry about shutting down.
071crazy is offline
Old 08-03-2004, 01:48 AM
nick51's Avatar
wut about the yokomo bcs double or single charger??
http://64.70.208.72/speedtechrc/87.html
nick51 is offline
Old 08-03-2004, 02:03 AM
Cole Trickle's Avatar
Yep, a double charger is great, since it take approx. 45 minutes to fully charge a pack of GP3300.
Radio: The most important is grip. Do the grip test and see if it fits your hands.
Cole Trickle is offline
