TC5 gearing
Old 12-29-2010, 06:53 PM
Thumbs down TC5 gearing
Hi everyone and ty for any and all info.
I am in the process of finishing up a build of a tc5 roller that i picked up for cheap.it came with a 78 tooth 48p spurr gear and when i attempted to throw the only spare pinion on i had which is a 15 tooth it falls way short of meshing.can someone please help me with some gearing answers. it has the mamba max pro/esc 9000 kv set up with a 7.4 5000 mah 50c lipo and a spekrrum dx3 radio and reciever...not that that info helps...lol
scgtpman is offline
Old 12-29-2010, 07:06 PM
Trader Rating: 24 (100%+)
Maybe this will help. Either way...it'll come in handy.
http://www.gearchart.com/
Evoracer is offline
Old 12-29-2010, 08:10 PM
ya just looking for some starter numbers its not gonna be a race car just a weekend street toy that will only see asphalt. thanks.jake
scgtpman is offline
Old 12-29-2010, 09:16 PM
If you have the manual for the motor (or can download it), take a look as the manual may suggest a proper range of gear ratios. Then use the gear chart.
The 15t pinion will never work. With that 78t spur, you should be looking at a tooth count in the mid 20's most likely.
Evoracer is offline
geeunit1014's Avatar
Trader Rating: 14 (100%+)
You would be best off changing the spur to a larger one, the stock spur is an 87t 48p, that should get the gears meshing (and a more appropriate ratio for a 9000kv). The previous owner was most likely racing a spec class and needed a low ratio FDR.
geeunit1014 is offline
Old 12-29-2010, 10:17 PM
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Running a 9000kv you'll need a big spur and a little pinion and watch your temps like a hawk. I'd start with 14/90 and go from there.
Keep a very close eye on Motor, ESC and Battery temps.
nexxus is offline
Old 12-30-2010, 04:05 AM
thank you so very much! what temp should i try and keep my motor at or below?
scgtpman is offline
Old 12-30-2010, 04:10 AM
Keep it below 80 degrees Celsius and you'll be fine.
Scooter79rs is offline
Old 12-30-2010, 10:52 AM
Default 1 more ?
Any idea why the sway bars would have been removed?
scgtpman is offline
Old 12-30-2010, 12:00 PM
Buckaroo's Avatar
Previous owner didn't like or perhaps properly understand the way it affected the handling?
Buckaroo is offline
