Old 08-01-2004, 12:55 PM   #1
Still Bill's Avatar
Default Novak Smart Tray revisited
Now that I have had some time with my Novak Smart Tray, I seek some input from the "peanut gallery".
First...While running everyone's equipment on a generator at the track, the Novak indicates "LP" (Low power) whenever there is not enought juice available. At these times, I tend to get false peaks from my chargers. I consider the "LP" notification to be a time that I need to watch my chargers.
Second...The electrical connect plug from the included power supply is very fussy about being plugged into the tray properly. Anybody else experiencing this?
Third...Almost invariably, the right two cells (as placed on the tray) go out first. They are followed by the left cell and then the other three. Anyone else experiencing this sequence?
Fourth...When discharging to .9V per cell, I need to cycle through them 2-3 times to have the cells discharge to .9V each. The first discharge cycle never completes the job. And each subsequent cycle still takes several minutes for the last lamp to go out. Doubt that this is much to do with "cell rebound" because I immediately press the tray's start button after all lights go out.
FYI...I am discharging most of the way down with lights before traying the battery packs.
Any comments?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-01-2004, 01:27 PM   #2
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
this is why I still love the indi/integy trays.......0v cutoff, just keep your eyes on the light bulbs, it's worth to me and the integy trays are muuuuuuuch cheaper than any other.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 08-01-2004, 01:41 PM   #3
DerekB's Avatar
I noticed the plug seems to not fit in the jack right too. As far as the other items I'll have to check out.
I don't like that it only accepts packs built one particular way. Something I didn't realize to be a problem at first but having to flip the pack over and have the tabs down can cause some problems.
Velocity RC Magazine
www.vrcmag.com
DerekB is offline   Reply With Quote
Old 08-01-2004, 02:13 PM   #4
Still Bill's Avatar
Salvadori Racing,
I also have Indi/Integy trays; however, I also know when something is technologically better...And that is the Smart Tray.
I don't have to keep my eyes on the light bulbs every time I tray discharge...Which is worth the initial cost alone.
Old 08-01-2004, 02:14 PM   #5
Still Bill's Avatar
Yes, the tabs being in the wrong direction was an issue for me too. Thanks.
Old 08-01-2004, 02:28 PM   #6
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I just recently got a smart tray, and it seems to have been well worth it.... love not having to watch it constantly have had no problems with it tho...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 08-01-2004, 02:46 PM   #7
donoman's Avatar
Send a message via Yahoo to donoman
i have some questions:
Could someone compare the
Smart Tray vs. the Rayspeed.
How often do you use your Smart Tray on something other than 0.9V per cell?
Also, you discharge with the bulbs at 20-30A prior to hopping on the tray equalizers, right? This is just to save time?
donoman is offline   Reply With Quote
Old 08-01-2004, 05:58 PM   #8
Still Bill's Avatar
These dischargers have previously been compared before on other strings. Use the search function to find what you want.
Otherwise, I only use .9V rate. Yes, using lights does save time.
Still looking for replies from others that actually are using the Smart Tray.
Thanks.
Old 08-01-2004, 06:30 PM   #9
I haven't had any problems with my Novak Tray. I have noticed that I have more capacity and higher voltages than when I previously used a Pro-Match Tray. The Novak Tray works faster than the Pro-Match Tray(it would take most of the day with the Pro-Match). I wouldn't use anything but a Novak Tray now. I have only used the 0.9 volt setting so far.
Hondaguy is offline   Reply With Quote
Old 08-01-2004, 08:24 PM   #10
wikedgmc's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via MSN to wikedgmc
the only help I can give you Billis when I use my Smart tray I first discharge my batteries on my 30 amp integy discharger with cut off, then my batteries equalize within about 3 minutes and the always cut out in a different order. Also if I try to retray the light turn off right away again. Hope this helps
Powered by HobbyTown San Jose
wikedgmc is offline   Reply With Quote
Old 08-01-2004, 08:46 PM   #11
j240z's Avatar
So far from what I can remember all of my cells have discharged in different orders. I'm going to keep an eye on them from now on as I find this topic interesting. I haven't had any problems with the plug coming loose either...yet....
j240z is offline   Reply With Quote
Old 08-01-2004, 09:06 PM   #12
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
The lights on my tray have been going off randomly. No pattern there.
I did find that I had to flip my saddle packs to get it to match up. I solved that by resoldering the connectors.
I did have it hooked up yesterday to a power generator and noticed that LP come on at times. This is definitely annoying, however, I don't mind since this tray does allow the use of AC or DC.
I don't regret purchasing this. It is way better than the Smart Tray (which does take forever to equalize).
g_bruin is offline   Reply With Quote
Old 08-01-2004, 09:21 PM   #13
Still Bill's Avatar
That is what I was wondering about. Seems as though there is something wrong with mine.
After I do retray a pack 2-3 times everything is as I would expect it to be. Otherwise, I do get far better mahrs and voltages than what I got with my previous discharge tray.
Old 08-01-2004, 10:39 PM   #14
xxx-s bill
I had the same problem. After I cleaned the contacts with motor spary the problem went away. I cleaned the contacts on the pack as well as the contacts on the tray.
jrrc is offline   Reply With Quote
Old 08-01-2004, 10:49 PM   #15
Still Bill's Avatar
Originally posted by jrrc
xxx-s bill
It's a possibility. Thanks. I will give that a shot (of spray).
orion advantage (non lipo) novak smart tray novak millenium Valentin.H R/C Items: For Sale/Trade 12 11-16-2007 06:37 PM
JR R1, Novak Smart Tray, Novak GTX, Futaba S9451, Hellfire stock motors, plus more yauipop Australia For Sale/Trade 7 08-27-2007 03:56 AM
Integy Zero-Thirty Tray, Novak Smart Tray domo Australia For Sale/Trade 9 07-29-2006 05:34 AM
Novak smart tray and trinity 2.5 tray joerocket900 R/C Items: For Sale/Trade 2 12-12-2005 10:52 PM
Trinity absolute zero tray/ novak smart tray ALL APPROVED R/C Items: For Sale/Trade 9 10-14-2005 07:54 AM
