Old 07-30-2004, 11:19 PM   #1
nick51's Avatar
Send a message via AIM to nick51
Default yokomo bcs settings??
I have the yokomo bcs charger and dont know wut to put the settings at? I will be charging 6 cell gp3300 and 6 cell sanyo 3000, a good charge for racing and bashing. Which charge mode delta peak (linear mode) or yokomo charge (pulse mode)? How many amps, cut off capacity, cut off voltage, and delta peak cut off voltage? This is my first really good charger, i used to have a dynamite peak charger, 1 button so it was easy and now this new racer charger and dont know, any help would be awsome. Thanks
nick51 is offline   Reply With Quote
Old 07-31-2004, 06:18 AM   #2
Registered User
ritchie's Avatar
use the yokomo charge mode only for ni-cd batterys.
i will assume you know how to change different modes and screens.
peakcharge, temp 66C, 5 amps, 4000 mah, 10 volts, cut off at 20
if you go to yokomousa.com you will find a instruction book for the charge, your gonna have to hunt around for it, i think its under the electronics banner on the left.
ritchie is offline   Reply With Quote
Old 08-06-2004, 02:12 PM   #3
nick51's Avatar
Why 10 volts, then that would only let them get up to 1.60 volts??
KO EX-10 settings johntrickle1 Radio and Electronics 3 08-16-2008 09:08 PM
Help with M8 Settings thieb Electric Off-Road 6 07-10-2006 06:51 AM
li-po settings PLANETSTEREO Electric Off-Road 2 02-27-2006 01:34 AM
Gm V12 esc Settings...Help pablo1 Electric On-Road 3 12-13-2003 11:36 PM
ABS Settings on M8 MadMax Nitro On-Road 1 02-01-2003 10:09 AM
