Ask Keven Hebert, TeamAssociated / Reedy / ApexRC >
Old 12-30-2010, 12:04 PM
  #61
Originally Posted by Warren Weaver
What brand pinion and spur gears are you using in 64p?
Hi, I usualy run Xenon pinion a run Associated spur gears
Originally Posted by thejo3
Félicitation pour ton nouveau contrat Keven !
J'espere que tu trouveras le temps de venir courser à Ottawa sur notre nouvelle track !!
http://rcinsider.com/?p=5095
Congrats kevin awesome run
Originally Posted by rccuba
Keven congratulations .... for your renewal of contract with the brands that you represent, Team Associated, Reedy and LRP ...
Congratulations ..... two years now to make war on the other teams ...
if you come for Spain to a race, has a support group for this land .......
greetings
Juan Carlos
thank you guys for the kind words ! Very much appreciated. I am very happy to be part of such a great team and I am looking forward to another 2 great years.
Keven H is offline
Old 12-30-2010, 12:47 PM
  #62
Thumbs up
félicitation Kev!! t une machine!!
Pace
Pace72 is offline
Old 12-31-2010, 12:14 PM
  #63
Default low grip set up
Keven, i need your help on a low grip indoor setup please. We are running on an indoor rubberized/very slick gym floor with a fairly technical track. I have looked high and low for a setup online but i cant find a thing. I have been experimenting from the stock setup and cant seem to find a happy medium. thank you for any help.
losidrvr is offline
Old 01-02-2011, 06:27 PM
  #64
sesimon's Avatar
Hi Keven; so far I'm really liking the tc6, but I have a couple of questions. I've noticed my car having a lot of wheel chatter with the cva joint going around tight corners. Any suggestions or possible after market drive shafts that you might have to minimize the chatter? I'm also having issues with the rear hubs having not holding the axle bearing tight, any suggestions for that? I had the same problems with my tc5 and have yet to find a solution to them.
sesimon is offline
Old 01-03-2011, 03:17 PM
  #65
Hi, Unfortunately I have never run on such surface but if I go off of a low bite situation usualy I will start with more droop and less front camber. The one thing that I would concider is trying one of the carpet setup ( probably us indoor champs ) would be your best bet and try a long rear link ( on the bulkhead ) and more droop and see what that does.
Sorry I could not be much help
Hi, For the cva, the one thing you might want to try is taking the set screw out and gluing the ring on the axle. Also make sure they are grease quite often and that will help ! Also, you can glue a thin toe shim on the steering block to limit the travel ! that would cure it if the track does not require so much throw.
Keven H is offline
Old 01-03-2011, 04:59 PM
  #66
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Originally Posted by Keven H
Hi, Unfortunately I have never run on such surface but if I go off of a low bite situation usualy I will start with more drool and less front camber. The one thing that I would concider is trying one of the carpet setup ( probably us indoor champs ) would be your best bet and try a long rear link ( on the bulkhead ) and more droop and see what that does.
You already drool alot. How much more can one drool?
See ya' at birds Kev. I'll bring you some wet naps....
Ron Goetter is offline
Old 01-03-2011, 05:08 PM
  #67
if you can, get some perfumed one ! see you there
Keven H is offline
Old 01-03-2011, 05:57 PM
  #68
Blue Screw's Avatar
hello... what cap do u run on the sxx v2... the one that comes on the speedoor the opoinal ones.. u no the 1cell ones and 2 cell ones... can u explain how it will affect it also
Blue Screw is offline
Old 01-03-2011, 06:37 PM
  #69
Hi, I do run the new capacitor. the capacitor is joined toghetter in series so they say it should be more power and it gives lower resistance but the difference is small ! I run the 6-7.4 one !
SESIMON- Sorry I forgot about the rear hub. The one thing I do to prevent slop is I take a exacto knife and mark the hub at 3-4 spots where the bearing sits in so that way the bearing sits tight.
Hope this helps.
Keven H is offline
Old 01-03-2011, 06:41 PM
  #70
RC8daBOMB's Avatar
You may not know the answer to this Keven, but do you know if Team Associated is coming out with a 4WD Short Course truck?
RC8daBOMB is offline
Old 01-04-2011, 05:13 AM
  #71
HI Kevin,
do you tc6 guys run the 8 Steering Block?
what holes you run in the damper?
the car is awesome for modified racing and very good for stock
im faster with modified than with my 416X
im the same speed with stock (17,5)
durability is the best i saw
Greetings
thilo-alexander is offline
Old 01-04-2011, 08:39 AM
  #72
jag88's Avatar
What's the difference in steering between the the #7 and the #8 bellcrank ?
Does the 8 give same entry (as a 7) but less mid to exit steering ?
Thanks.
jag88 is offline
Old 01-04-2011, 03:28 PM
  #73
Blue Screw's Avatar
so u take off the stock one.. you even run the 6 to 7 one in 1 cell? and why
Old 01-04-2011, 04:31 PM
  #74
Originally Posted by thilo-alexander
HI Kevin,
Greetings
I run the 8 block in modified and 7 in 17.5 ! as for the piston, in the shocks I run blank piston from TeamAssociated and drill them ! I drill 2 holes with a 1mm drill bit and 1 hole with a 1.5 ! so it is a 1,1,1.5
Thanks.
Hi , The difference between the 2 is very little but still there. The 8 block will give you more ackerman so a little less reactive but should finish the corner a little better. the 7 block will get in the corner a little harder and should have more steering in-and middle but wont come out of the turn as well ! Hope this helps
yes I take the stock one out ! with 1 cell I run the 3-4 one and for TC I run the 6-7 one
Keven H is offline
Old 01-04-2011, 05:31 PM
  #75
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Keven,
Sorry I know this has been asked, but im still confused on the whole 1,1,1.5 piston. Do you run that piston on all surfaces? From high grip to low grip, carpet and asphalt? Or what conditions would you go away from that piston?
BlackedOutREVO is offline
