Old 03-22-2005, 04:50 PM   #1471
the shims that go behind the roll center blocks can change the rear wheel base. i had the stock shims in it and it was a little wide at the nats and i had to change it. Also you have to watch adjusting the shims for the rear toe. Don't just use the 1 degree or 1/2 degree shims to change the angle, measure the front and rear of the wheel to see if your tire is toe-ed in or out.
Dhartman03 is offline   Reply With Quote
Old 03-22-2005, 08:02 PM   #1472
Send a message via AIM to munrath
Brandon - You got PM
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 03-23-2005, 12:11 AM   #1473
Jeff Brown's Avatar
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-23-2005, 08:17 AM   #1474
Default THANK YOU!
Originally posted by Dhartman03
Id just like to thank the Team Corally guys for fixing my car at the nats when it broke in a false start, and the support they gave me at the race. Before i was able to get off the drivers stand, Mike Bruce had my car in his pits replacing the arm, then Jeff Cuffs helped out by setting my car back on the track. I've never seen a team help out a "non-team member" in this way. This is one amazing car, I ran a box stock US carpet spec kit, and was able to place in the top ten twice in the qualifing rounds.
DH
I would like to personally THANK the guys at Corally for helping Dan with his broken car. This is what a real team is about, especially when they did it for a car owner, NOT a team member. Keep up the good work ROB & gang! John Peoples
John@RiverJct is offline   Reply With Quote
Old 03-23-2005, 08:48 AM   #1475
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Default Rollout chart
For anyone that wants one, I have made a rollout chart that gives tire diameter every .2 mm. I know gearchart already has this done, but I wanted finer tire diameter rollouts. It's for a 104 spur.
PM me an email address if you would like a copy, you will need excel to open.
If you use inches for tire size, just multiply your inches by 25.4 to give mm.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 03-23-2005, 09:43 AM   #1476
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
If anyone needs rollout charts
I have done for 78t spur and 104 spur.
email me for one if you want.. you don't need excel only adobe acrobat reader these are pdf files.
[email protected]
BadBoyRC is offline   Reply With Quote
Old 03-23-2005, 02:44 PM   #1477
imprsme's Avatar
Trader Rating: 74 (99%+)
Jeff-
I have some of the AE alum. clamping narrow axles, Would those work, are they the same thickness as the Corally ones?
Thanks!
Anthony S.
imprsme is offline   Reply With Quote
Old 03-23-2005, 03:13 PM   #1478
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
nope... the AE hexes will be inch measurements, and the Corally is metric.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-23-2005, 03:38 PM   #1479
MartinSorlie's Avatar
I disagree. The Corally has MIP axles, and the wheel axles are in inches. you can use both AE and Team Losi wheel nuts, wich means that the AE hexes should fit also. It's only the outer nut diameter that is 7mm. They're still not the same as Tamiya 7mm...
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 03-23-2005, 03:41 PM   #1480
imprsme's Avatar
The AE hexes "fit" I was just wondering if they are the same THICKNESS as the Corrally ones.
Old 03-23-2005, 03:49 PM   #1481
Can't you just measure that yourself?
TLR - Spektrum
Old 03-23-2005, 03:49 PM   #1482
Turbonium's Avatar
well, i wouldnt think they are correct, as the bearings and wheel nuts are metric. not that the AE hexes wont fit, just no properly, i wouldnt think....
and i think the AE hexes are about the same thickness as the wide Corally's, and the narrows are about half the width...
Wes
Team Novak
Old 03-23-2005, 03:53 PM   #1483
imprsme's Avatar
I could measure them myself if I had the narrow hexes to know how thick they are! But then again if I had them here to be able to measure them I would not have posted. LOL
Turbo- they fit properly, trust me I just put them on the car with wheels and tire (foam and rubbers) no slop, didn't pull off or feel loose.
Old 03-23-2005, 03:56 PM   #1484
imprsme's Avatar
I was just thinking that since Jeff worked at Superior he could just walk over to the wall take the AE hexes and compare them to the Corally ones. HINT HINT!
Old 03-23-2005, 03:56 PM   #1485
Test using an AE wheel nut, if you think it's metric Then you'll get a surprise...
TLR - Spektrum
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
