Old 03-21-2005, 09:02 AM   #1426
Send a message via AIM to munrath
Chris,
I'm using Ben's from the website as a starting point. The asphalt track that I ran on over the weekend had plenty of traction so I need to adjust the setup a little. Check back with me in about 3 weeks as I'm going back to the rug for a few weeks before hitting the asphalt again. I should have something by then.
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 03-21-2005, 09:22 AM   #1427
raffaelli's Avatar
Thanks guys. I watched someone build one at the nats. Looks like a pleasure to build.
24ITA
raffaelli is offline   Reply With Quote
Old 03-21-2005, 10:06 AM   #1428
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Default Car Width
Does the car measure at 190mm out of the box with foams?
Does the kit come with the narrow or wide hex adapters? I would like to space the front tires out some more to be able to get the tires to turn further without rubbing the spring, but don't want to make it past the 190mm.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 03-21-2005, 10:13 AM   #1429
rayhuang's Avatar
Default Re: Car Width
Brandon-in the front-one spacer on the inner hingepins and the stock hexes equals 190mm.
As an option-you can run two spacers on the hingepins and narrow hex's. Jeff said thats mad steering like that and I dont think anyone is running that as a set-up right now.
IN the rear-no innner spcers, but narrow hex's equals 190mm.
Ray
Old 03-21-2005, 10:58 AM   #1430
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
the kit comes with the wide hexes front and rear... if you need the narrows you hafta get 'em separate.
our local (small) track was just coated with Skid-Not, kinda like indoor asphalt surface. low traction right now, but it will improve as its run in. i got the RDX working pretty well last saturday using the oneway, qualified 2nd, finished 3rd in Pro Stock.
now if i could just get enough guys to run 12th scaleMini, i would go ahead and order that Minisassin!!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-21-2005, 11:13 AM   #1431
Default Re: Re: Car Width
Ray
Using two spacers does not put the tire out any further in relation to the shock, because the WHOLE arm is moved out when shimming the hinge pins out.
I was basically wondering if I put a spacer on the axle against the hex (to move tire out) if it would be too wide.
I am running it like it shows in the book with the silver hexes, so it should already be at 190mm.
Old 03-21-2005, 11:25 AM   #1432
rayhuang's Avatar
Brandon-sorry-I didnt get that from your post-I thought you wanted to know how to make the car max-190mm.
Old 03-21-2005, 11:35 AM   #1433
Mart42's Avatar
Question guys:
How about the fragility of the car, i heard that the arms broke easily, any comments about that?
MARTIN LECUYER
Team Associated - Reedy - SMC - Team Scream - BSR - SlyGraphiX - Carpy's
[email protected]
Mart42 is offline   Reply With Quote
Old 03-21-2005, 11:50 AM   #1434
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
MART
I use the rubberneck bumper.. the car is really strong. you're going to hit stuff sooner or later..
I suggest that you use the plastic steering blocks.. they will break in a hard hit but won't allow too much energy to transmit to an arm or hinge pin. If you use the aluminum steerting blocks then you'll likely bust an arm in a hard hit.
the rear upright is duraluminum so if you hit really hard you'll break an arm.
otherwise its a very strong car.
Remember the car handles like its on rails and you'll be tempted to go faster than ever before.. so be prepared when you hit.. that you'll be doing so at a higher speed!
When you get a kit always carry spares. Lucky for rdx racers...all the arms, pivot blocks, hinge pins , shocks, shock towers are all the same no need for front and rear sets.
make sure you use locktite (blue) on all screws that go into metal
I have some setups weve been using here on the west coast that work good.. email me if you like
[email protected]
BadBoyRC is offline   Reply With Quote
Old 03-21-2005, 11:56 AM   #1435
Mart42's Avatar
Thanks Badboy,
I will do, i aprreciate it.
MARTIN LECUYER
[email protected]
Old 03-21-2005, 11:57 AM   #1436
Michal101's Avatar
Originally posted by Mart42
Question guys:
The only thing that I have broken has been 2 rear arms (50% arms) with very minor hits and two turnbuckles...they are very fragile.
I have had the car for about 6 or 7 weeks and run the P-Dub bumber and a larger front bumper.
I hope this helps, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 03-21-2005, 12:07 PM   #1437
MartinSorlie's Avatar
And this weekend the RDX got it's Norwegian Cup Series totalwin also... Kinda nice trophy(last two pictures taken with my phone, not superb quality...)
This car is supersolid, I've had it since november, and running modified I've only broken a few arms and steering blocks...
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 03-21-2005, 12:16 PM   #1438
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Question guys:
Both of the cars you got from John and I should have the Rubberneck bumpers already. The car you got from me has the BRP bumper on there as well.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-21-2005, 12:22 PM   #1439
Mart42's Avatar
Thanks for the quick reply guys.
Blake
Hope i get the car today, can wait to work on this car.
MARTIN LECUYER
[email protected]
Old 03-21-2005, 12:27 PM   #1440
BadBoyRC's Avatar
Mart.. heres a good setup from this weekend.. good for intermediate and advanced racers
easy to drive, smooth and forgiving.
allows you to become aggresive and not get in trouble. (Carpet setup)
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
