Old 03-19-2005, 11:55 AM   #1381
Send a message via AIM to kabttu
I've finished building the kit, went together very easily. Now I've just to work on getting everything setup correctly.
In regard to the diffs, what do you mean by don't overtighten them? Could I damage them by overtightening them? Thanks!
Originally posted by ExcelRC
kabttu- Make sure you use a little loctite on all of the screws that go into aluminum. Also, do not overtighten the diffs when first assembling. Otherwise enjoy a nice build
kabttu is offline   Reply With Quote
Old 03-19-2005, 10:20 PM   #1382
syndr0me's Avatar
Trader Rating: 32 (100%+)
The Corally UK site has information about a 1 PC. delrin diff pulley. Does anybody know its part number, and if they're available here in the states? I'm having a difficult time making the 2 PC. pulley spin true.
Here's the link to the 1 PC. pulley. I found it by way of http://www.corally.co.uk.
syndr0me is offline   Reply With Quote
Old 03-19-2005, 10:30 PM   #1383
Jeff Brown's Avatar
Those aren't available yet, I am sure CorallyUSA will receive them shortly. They were prototyped at the Snowbirds. I have yet to have a problem with the stock pulleys.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-19-2005, 11:02 PM   #1384
syndr0me's Avatar
Thanks Jeff, I'll keep an eye out for it to hit the states.
It's only my front diff that's giving me trouble. I've tried everything I can to get those three screws even tension, but the thing has a slight wobble to it, no matter what. If they've gone out of their way to make a 1 piece, maybe I'm not alone.
Old 03-20-2005, 12:17 AM   #1385
Regional Moderator
kansasracer's Avatar
BTW
Did anyone notice that a RDX was TQ in mod at the carpet nats!!!
Go Chris!!!
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 03-20-2005, 08:12 AM   #1386
Jeff Brown's Avatar
syndr0me...... well, the diff pulley wobbles on the diff balls a little. You might be seeing that. I wouldn't worry about it. Just tighten down the screws and call it good. My pullies have performed flawlessly for several months.
Jeff
CONGRATS TO TOSO FOR TQing the ROAR Nats!!
Old 03-20-2005, 09:19 AM   #1387
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
COOL!!!!!!!!!!!
Go Chris, and Team Corally!!!!!!!!!!!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-20-2005, 09:58 AM   #1388
Regional Moderator
So all you RDXers...got a question.
I got a kit with the one way in the front (don't know the part number) but my rear diff is mostly machined alum., not alum with a plastic pully like most.
Was this the way all the kits came or am I lucky (or unlucky)
Thanks...
Old 03-20-2005, 10:02 AM   #1389
Jeff Brown's Avatar
You have kit 00166. I am surprised to see you with aluminum diff pulleys. Where you bought it must have had it for a while. You will want to contact CorallyUSA and get Delrin diff pulleys, you will also want to check your thrust washers inside the diff halves. They should be copper colored. If not you can get the brass/carbide ones from CorallyUSA.
Jeff
Old 03-20-2005, 10:05 AM   #1390
Regional Moderator
Is there something wrong with the metal one?
I have an extra "normal" diff I can put in...
Thanks Jeff for the fast response..
Old 03-20-2005, 10:09 AM   #1391
Jeff Brown's Avatar
Well, the aluminum pulley seems to heat up the diff balls quite a bit. Now I am not talking about the aluminum diff halves. Just the pulley. Check the thrust washers too.
You can get the delrin pulley and thrust washers for free from CorallyUSA.
Jeff
Old 03-20-2005, 10:24 AM   #1392
Regional Moderator
Jeff,
Thanks...answers alot of questions...
Old 03-20-2005, 10:40 AM   #1393
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Jeff, you got PM.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-20-2005, 11:18 AM   #1394
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Hey Jeff,
Ran the car for first time yesterday and everything went well. When you're running modified on carpet or asphalt, how much tension do you use on the front belt?
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 03-20-2005, 11:21 AM   #1395
Jeff Brown's Avatar
Well, I don't have the belt tensioner on right now. My belt doesn't seem too loose.
Jeff
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
