Old 03-13-2005, 02:31 PM   #1336
raffaelli's Avatar
I am currently running KO receivers but am probably going to switch to Spektrum.
I remember Raul's car looked tight on electronics space. Will the Spektrum receiver fit with a regualr sized servo and a Quantum or KO speedo?
24ITA
raffaelli is offline   Reply With Quote
Old 03-13-2005, 02:32 PM   #1337
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
All the springs have a different number of coils. For instance, the 42 lb springs have the least amount, and the 26 lb have the most. I labeled mine by color by marking them with a sharpie on the top of the spring.
Yes the spectrum will fit, you will have to stand it on it's side, however.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-13-2005, 02:35 PM   #1338
raffaelli's Avatar
Brain, thanks for the very quick responses!!!
24ITA
Old 03-13-2005, 03:02 PM   #1339
No problem
USVTA Member #211
Old 03-13-2005, 03:23 PM   #1340
ExcelRC's Avatar
Send a message via Yahoo to ExcelRC
Brian is on the ball...or on here alot
ExcelRC is offline   Reply With Quote
Old 03-13-2005, 03:29 PM   #1341
raffaelli's Avatar
Hey Mr Excel....I can't seem to get your link to work.
24ITA
Old 03-13-2005, 03:38 PM   #1342
Send a message via AIM to munrath
Brian - Thanks.
Chris - You have a "." in front of "www" in your link
Raffaelli - Click here http://www.excelrchobbies.com/
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 03-13-2005, 03:46 PM   #1343
raffaelli's Avatar
Got it thanks!
24ITA
Old 03-13-2005, 03:48 PM   #1344
raffaelli's Avatar
Originally posted by Brian McGreevy
The Oneway kit is part # 00166
The Standard kit with the diff is # 00166UK
The Carpet spec kit (foam tire use) is # 00167
The first two cars are multi-purpose but the oneway kit is not for use with foam tires. The standard kit would be ok to get you running if you could not get the Carpet spec kit for the nationals. The carpet spec would be your best option at this time.
The 00166 kit is for rubber on pavement?
24ITA
Old 03-13-2005, 03:54 PM   #1345
Raffaelli,
That's the kit I just purchased and three of my buddies have them. All have been running them on Carpet at Mimi's.
The traction at Mimi's (The Track) isn't what I consider high bit, maybe low to medium bit depending on the day.
I plan on running mine at the new indoor asphalt track that just opened up, and maybe some carpet.
Either way you can't go wrong with this kit or the carpet spec.
Mark
Races for 2015:
Old 03-13-2005, 03:59 PM   #1346
raffaelli's Avatar
Originally posted by munrath
Raffaelli,
The traction at Mimi's (The Track) isn't what I consider high bit so the cars are doing awesome.
Mark
In the summer I plan to run pavement once in a while. But int he winters I am carpet everyweek. Should I get eht carpet spec and change the suspension for pavement?
If you are heading to the Nats I would like to check out your car. Unfortunatley, I did not get a chance to head down to Mimi's this year.
24ITA
Old 03-13-2005, 04:01 PM   #1347
raffaelli,
That is the kit I got as well. There were no UK or Carpet kits in at the time, so I got that and a front diff. For anything but the highest traction conditions, the stock 2.9 mm chassis and topdeck work just fine. Although, the 3.5 mm topdeck that comes in the carpet spec kit does stiffen the car up just a tad more than it already is.
For any carpet racer, the US Carpet spec kit #00167 is the best bang for your buck. You get the 3.5 mm topdeck, spring kit, and 4 degree caster blocks that you'd normally have to purchase seperately.
USVTA Member #211
Old 03-13-2005, 04:04 PM   #1348
Raffaelli,
I can't make it to the Nats this year. I'm leaving for NC this week for work. Cuff's, and others will be there for sure just snag him for a look or to.
If you can wait another week I believe more carpet specs will be available. If not I'd go with the UK kit and get the 75% arms (Ultra-hard) and the silver spring set.
Mark
Races for 2015:
Old 03-13-2005, 06:54 PM   #1349
ExcelRC's Avatar
It's working now...thanks munrath. Weird that i didnt put the "." there
I will be getting the dual diff UK kits in along with the 75% X-Hard arms and the hard spring set along with many other items Monday so click the "working" link Monday night.
Old 03-13-2005, 08:30 PM   #1350
lazyboy's Avatar
Send a message via AIM to lazyboy
wow brian poppin off answer, what dont you know about this car
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
