Old 03-11-2005, 10:16 AM   #1306
Trader Rating: 74 (100%+)
Default new car
Originally posted by RCFREAK
raul... i am glad you got great results with the new car.. i got one too.. still didnt get a chance to make it to the track.. tommorrow will be first day out with it...
i am using the Pro4 spring perches..
thrust bearing shredded before finishing the car.. now using the XRAY ones.. better quality.. Corally has upgrades??
anyone got problem with wheels(foams) rubbing spring perches.?? meaning a lot less dual rate on the radio.. can only run approx. 85% with a helios? supposedly the car will steer, and you wont need to run more dual rate anyways..
arvin
Welcome Arvin, are you running the Nat's? THe new car is awesome. I also have a thrust bearing issue, but I have to disassemble it first to verify whats in there...
Ukeejim, awesome......
Brian I guess its ok then, also is there a particular shock length I should be using. I pm'd my cell # to you call me. Thanks.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-11-2005, 10:38 AM   #1307
Jeff,
Simmilar results, I have clearance at 75% EPA with 100% dual rate, but have never needed more than 50% to have too much steering. I was answering Arvin, who was concerned about throw.
On the tyre issue, I have Parma on the car now with the stock tow out shims on the back, and I think I may be over 190mm, but it might squeeze into a tech box. Probabl;y the offset.
Jim D
ukeejim is offline   Reply With Quote
Old 03-11-2005, 10:56 AM   #1308
Jeff Brown's Avatar
ukeejim....... ok just checking.
Raul...... if your thrusts are bad and you have copper colored ones then you probably cranked them down too tight. It is a very sensitive adjustment and is easier to fine tune once it is in the car. They aren't like other diffs that you crank down, then back off a half turn. Hope this helps.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-11-2005, 11:04 AM   #1309
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default Re: my first outing
Originally posted by Raul Garcia
Well, if one word sums it up. WOW!!!!!! I went over 1 lap faster tonight with a box stock setup, over my fastest previous car. ANd they looked the same, just different colrs hehehehehe..... Everyone was shocked.
raul,
which car did you feel you were faster with, the mi-2 or the 415?
- chris
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-11-2005, 01:53 PM   #1310
Default Re: Re: my first outing
Originally posted by seaball
raul,
- chris
BMI2!
Old 03-11-2005, 02:48 PM   #1311
seaball's Avatar
word.
Old 03-11-2005, 05:33 PM   #1312
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is there a list of parts (with part numbers) of the differences between the US Spec and the Carpet Spec? I've got a diff in the front and the X-hard arms, but surely there's more. A definitive list would be great.
syndr0me is offline   Reply With Quote
Old 03-11-2005, 05:35 PM   #1313
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
The carpet spec includes a 3.5 mm top deck, 4 degree caster blocks, front diff, and the full silver spring set. I am almost 100% sure that is all that is different.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-11-2005, 05:42 PM   #1314
dawgmeat's Avatar
Default Re: Re: Re: my first outing
BMI2!
First off Rual is a friend of mine, so this is all in fun.
Mi2, Pro4, 415 and now the RDX within a five month period, wow
With only 3 more touring cars to go, TC4, xray and the new Losi, I'll give about a 2 months before you own one of the remaining three, give them hell at the Nationals
dawgmeat is offline   Reply With Quote
Old 03-11-2005, 05:46 PM   #1315
Dawgmeat,
Yes, Raul has been through many kits as of late , but I do believe he has found the glove that fits. After seeing him run last night I do not think there is a need to try the other two kits. LOL
Jamie Corrado is offline   Reply With Quote
Old 03-11-2005, 05:52 PM   #1316
ChadCapece's Avatar
Where can I buy an assassin or RDX?
ChadCapece is offline   Reply With Quote
Old 03-11-2005, 05:56 PM   #1317
dawgmeat's Avatar
Originally posted by Jamie Corrado
Dawgmeat,
It was nice to meet you for the first time, give them hell at the nats.
Old 03-11-2005, 07:32 PM   #1318
Default the RDX experience
i finally had a chance to spend some time with the car on the track. i'm pretty impressed with how incredibly smooth and quiet the car is, all i hear is the whisping sound of the motor and the shredding of foam on carpet, virtually no transmission sound at all.
also with just less than a 1/2 dozen packs run throught the car, i've already managed to turn very competitive lap times. this car is fast and it doesn't appear that you have to over-drive it to achieve speed. on the track it's so smooth that it looks like it's going slow......does that make sense?
just an observation
Electro-MAX RC is offline   Reply With Quote
Old 03-11-2005, 10:15 PM   #1319
brian i think the carpet spec comes with the 3.5 mil top deck not the chassis. not positive tho.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 03-11-2005, 10:20 PM   #1320
koabich's Avatar
Send a message via Yahoo to koabich
Yeah, according to my manual, the top deck is 3.5mm and the chassis is 3mm.
If you want a thincker chassis get the 4MM unit made by BMI. They are available from Corally (BMI will only sell them to Corally).
koabich is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
