Old 03-10-2005, 04:24 PM   #1291
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally posted by syndr0me
What's a ballpark pinion to start with? Running on a smallish carpet track (stock) with foam. I just need to know where to start, I can fine tune it from there. Stock spur, 48 pitch.
Check with Bsydor(AKA "D"), he has been playing around with a RDX. He should get you in the ballpark. He should be at Fastlane on Saturday.
Later,
CRASH is offline   Reply With Quote
Old 03-10-2005, 07:34 PM   #1292
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
imprsme,
Steve is correct. Low block down/Regular block down. Basically 0 and 1 positions for both front and rear arms.
BTW, Steve, thanks for correcting me on the angle. I knew it was around 2 degrees by looking at it, just wasn't sure of the exact value (thus the ~).
Raul,
I have found that if you use AE spring perches, they will lower the spring significantly (nearly 1/4"). I have done that for both front and rear, and it works very nicely. This allows you to run larger (58-59 mm) tires and not have the collar topped-out.
Any questions, feel free to ask
Brian
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-10-2005, 07:52 PM   #1293
imprsme's Avatar
Trader Rating: 74 (99%+)
Thanks guys! After I put them on the car I could see it. I had a feeling that just the off-set would yield that small of a adjustment.
imprsme is offline   Reply With Quote
Old 03-10-2005, 08:15 PM   #1294
danjoy25's Avatar
Trader Rating: 37 (100%+)
Default RDX
I have to admit since Speedtech announce that they will be selling Corally's, this thread has picked up alot.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 03-10-2005, 08:33 PM   #1295
if you can't get diff spring perches, just cut the eyelet down to lower the exsisting stock perches, but just make sure they are even or the car will feel tweaked.
Dhartman03 is offline   Reply With Quote
Old 03-10-2005, 08:40 PM   #1296
Korey Harbke's Avatar
Default Re: RDX
Thats a good thing!!!
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-10-2005, 09:26 PM   #1297
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
awesome car..
BadBoyRC is offline   Reply With Quote
Old 03-11-2005, 12:25 AM   #1298
Trader Rating: 74 (100%+)
Default my first outing
Well, if one word sums it up. WOW!!!!!! I went over 1 lap faster tonight with a box stock setup, over my fastest previous car. ANd they looked the same, just different colrs hehehehehe..... Everyone was shocked.
Jeff, Brian, and others,
I have acquired associated perches, but do you still have to cut the lower eyelet to acheive a little more up travel..? Not that you need alot of uptravel.
Also does the preassembled thrust bearings come lubed??
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-11-2005, 05:25 AM   #1299
Where is the RDX carpet spec car availabe for purchase?
kmorast is offline   Reply With Quote
Old 03-11-2005, 07:16 AM   #1300
John Fontaine's Avatar
Send a message via AIM to John Fontaine
You should be able to get it from Speedtech RC very soon
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-11-2005, 08:37 AM   #1301
RCFREAK's Avatar
Trader Rating: 17 (100%+)
raul... i am glad you got great results with the new car.. i got one too.. still didnt get a chance to make it to the track.. tommorrow will be first day out with it...
i am using the Pro4 spring perches..
thrust bearing shredded before finishing the car.. now using the XRAY ones.. better quality.. Corally has upgrades??
anyone got problem with wheels(foams) rubbing spring perches.?? meaning a lot less dual rate on the radio.. can only run approx. 85% with a helios? supposedly the car will steer, and you wont need to run more dual rate anyways..
arvin
RCFREAK is offline   Reply With Quote
Old 03-11-2005, 08:51 AM   #1302
Arvin;
Welcome to the club. Had to turn the JR-R! to 75% to avoid shocks, but hav never been over 50% on the dual rate, pleanty of steering.
Jim Damerell
ukeejim is offline   Reply With Quote
Old 03-11-2005, 08:53 AM   #1303
Jeff Brown's Avatar
RCFREAK...... if you check back through the thread a little there are posts regarding the thrust washers. Corally Holland received a batch that were the wrong thrust washers.
You can contact CorallyUSA and get some replacement ones that are brass colored. Every kit from now on has the brass washers installed. Like I said, their supplier screwed up overseas.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-11-2005, 09:00 AM   #1304
Jeff Brown's Avatar
ukeejim....... which tires do you use? I have 3mm worth of shims on each side of my front end to get the car to 190mm with JACO tires. I believe PARMA tires are offset so it is easier to widen the car. I have 95% dual rate and 75% endpoints and mine clears by like a 1/2mm.
Jeff
Old 03-11-2005, 09:52 AM   #1305
Raul, if you get the AE perches, you don't need to cut anything. It's a "slip on" job, so to speak.
I'm happy you like the car. Everyone else seems to be as well
USVTA Member #211
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
