Old 03-06-2005, 07:03 PM   #1246
rcgen's Avatar
Default CVD Bones
I've bent both my front cvd bones. Is anyone have the same problem? I run mostly 19t on asphault and did have a few run in with the pipe but were not hard hits.
rcgen is offline   Reply With Quote
Old 03-06-2005, 09:19 PM   #1247
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
rcgen,
I have not bent any cvd bones and have taken a few good hits.
Guys who race on foam tires:
If you want to run your car at fairly low ride height without running the collars near the top of the shock, use AE TC3 spring perches. You'll gain about 1/4" that way. This is especially useful if you run a lowered front shock tower.
I also have found a really good setup for medium bite CRC ozite. I'll post it a bit later.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-06-2005, 09:35 PM   #1248
how does the car use the short and long arms and keeping the width the same? ive been looking at how the arms mount and i just can't figure out how it works out?
Dhartman03 is offline   Reply With Quote
Old 03-06-2005, 09:51 PM   #1249
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
on the short arms, the mounts go on the outside of the bulkheads, and on the long ones, you flip them on the inside.... just like the way the X-rays did, if i remember...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-06-2005, 10:22 PM   #1250
that was my inital thought when i was looking at it so thanks for the input...
Old 03-06-2005, 11:36 PM   #1251
Here's that setup:
Front:
60 wt, 1.3 mm pistons, 33 lb spring
4 degree caster blocks, ~2 degrees anti-dive (low block in 1 front, regular block in 1 rear)
0 toe, -1.5 camber, 1.5 mm droop over ride height, 4.5 mm ride height
1.9 mm roll bar
2nd from inside hole on shock tower, outside (3) hole on arm
Outer camber link hole (lower holes for stock tower, upper hole for lowered tower)
Short wheelbase (both clips in front of arm)
Stock ackerman positions
Rear:
40 wt, 1.3 mm pistons, 26 lb spring
0 toe blocks, 1.5 degrees toe, ~2 degrees prosquat (low block in 1 front, regular block in 1 rear)
No roll bar
Outside hole on tower
Outside hole upper camber link, outside hole on hub
Long wheelbase (both clips in front of arm)
Stock 2.9 mm chassis and topdeck
Dbl Pink/Orange and Dbl Pink or Cyan/Magenta tires
Parma Alfa
Paragon traction compound
USVTA Member #211
Old 03-07-2005, 07:27 AM   #1252
Turbonium's Avatar
Brian, thats eerily close to what i wound up with in Dallas yesterday, only i was using the 1.3mm bar, and no prosquat in the rear.... but should have switched to the 1.9 bar, as the front was diging in a little too much.
what would the prosquat do for it? maybe i should have tried it, just ran out of time...
Wes
Team Novak
Old 03-07-2005, 01:46 PM   #1253
Wes, the prosquat seemed to make it turn in harder and rotate more on and off-power. This was for a really tight and technical layout, so for more flowing layouts it'll be killer, as well.
USVTA Member #211
Old 03-07-2005, 02:00 PM   #1254
Turbonium's Avatar
cool.. the track i was at had a lot of 180s, connected by long straights. they are supposed to be changing it up before the big race next weekend, so ill keep that in mind. thanks!
Wes
Team Novak
Old 03-07-2005, 05:57 PM   #1255
Jeff Brown's Avatar
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-07-2005, 09:17 PM   #1256
wannabee's Avatar
FYI one for sale on the sales thread!
http://www.rctech.net/forum/showthre...threadid=65565
wannabee is offline   Reply With Quote
Old 03-07-2005, 09:18 PM   #1257
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Brian- you ready to kick some butt together on April 2nd?
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 03-07-2005, 09:21 PM   #1258
Oh yeah dude...bring on the competition. Koch and I will be bringing it for Corally.
USVTA Member #211
Old 03-08-2005, 08:03 AM   #1259
TTT
USVTA Member #211
Old 03-08-2005, 09:23 AM   #1260
ground-round's Avatar
Trader Rating: 18 (100%+)
Just got my RDX this weekend. I've been building it a little bit every night and all I can say is WOW! This thing is going together beautifully. I've been an Associated guy for the past 6 years and the difference in the manufacturing tolerances isn't even close. Build the RDX like the instructions say and its perfect. Build a TC3 or 4 from the instructions and you've got a trainwreck.
ground-round is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
