Team Corally RDX Touring Car >
Old 03-04-2005, 08:30 AM
  #1231
koabich's Avatar
Originally posted by pipih2000
Anyone know if the 4mm chassis and 3.5mm top deck part numbers and availability? Also where do you guy mesure your droop settings?
This chassis is just awsome,many local guys have a hard time to folow me it's just so dialed.
I know the 4mm BMI chassis is available. I ordered mine from Corally Wednesday. Not sure on the top deck.
Here is a picture of the BMI 4mm chassis. This is the chassis that was used by all Team Corally drivers for Novak and the Snowbirds. The chassis on the right is the final version. The chassis on the left is a prototy
koabich is offline
Old 03-04-2005, 08:34 AM
  #1232
Alright -I'm sold are they available (or just preorders), and how much?
Electro-MAX RC is offline
Old 03-04-2005, 08:37 AM
  #1233
koabich's Avatar
According to Corally, they retail for $150.00. They are available and in stock! I had my LHS order one for me through Corally and I ended up paying under $100.00 for the chassis.
koabich is offline
Old 03-04-2005, 08:38 AM
  #1234
Thanks Dude,
You wouldn't happen to have a part number would you?
Old 03-04-2005, 08:44 AM
  #1235
Any update on when the carpet spec kits will be back in stock?
kabttu is offline
Old 03-04-2005, 09:09 AM
  #1236
Company Representative
CorallyUSA's Avatar
Default Chassis Info
4.0mm chassis are in stock. Part number is SRC100. Call us direct or have your local shop order.
3.5mm topdecks are out of stock as they are all being taken by Carpet Spec kits.
CorallyUSA is offline
Old 03-04-2005, 12:38 PM
  #1237
CorallyUSA's Avatar
Default Snowbird Setups
Added Jeff Cuffs setup to the website in PDF format.
Old 03-04-2005, 12:41 PM
  #1238
Registered User
Cool I shall put my order at my locol hobby shop.
Multi-hobby In Gatineau Quebec Canada.
(819)770-5050
pipih2000 is offline
Old 03-04-2005, 11:17 PM
  #1239
danjoy25's Avatar
Trader Rating: 37 (100%+)
Default Drive Ratio??
Anyone know what the drive ratio of an RDX, just got a loaner to try for a few meets but forgot to ask what it is.
danjoy25 is offline
Old 03-04-2005, 11:31 PM
  #1240
Trader Rating: 78 (100%+)
RBLove is offline
Old 03-05-2005, 11:07 AM
  #1241
i would just like to say thanks to rob michaels for welcoming me to the team plus this thread needs to be on the front page again the rdx is a killer car later jason
ERTRACHTER is offline
Old 03-05-2005, 12:12 PM
  #1242
protc3's Avatar
hey guys,just want to clerify something.i cut the 4.0 mm chassis for rob but it is not my product.it is robs design and he sent me drawings for the chassis.please dont take credit from him.thanks guys.it is a very nice chassis.hats off to you rob.
protc3 is offline
Old 03-05-2005, 03:34 PM
  #1243
yeah J.
pritch666 is offline
  #1244
This is tj on pritches computer.
tj
Old 03-06-2005, 02:47 PM
  #1245
Default At long last
At long last i got to run my RDX in anger today at bedworth ( UK track ) despite it just being a degree or two above freezing. Using old cells that have only been used once in the last eight months and a stock motor straight out of the packet i still managed to set FTD and win both legs of the finals.
Found the car to have loads of turn-in even in such cold conditions ( ice cleared in the car park about an hour before the finals ) and running on D20 treaded tyres. I was suffering some oversteer coming out of mainly slow corners before i could even get on the power. Played around with droop on the rear , 19lb springs on the front , slightly tighter front diff , and moved the rear inner camber link positions out one hole.
Once i got inot the finals i was flying with the car and it was going into the corners like a dream , still got plenty to try yet. After this first run im looking forward to some warmer weather and better grip conditions to really see what this car can do.
weekendracer_uk is offline
