Team Corally RDX Touring Car
#1126
Who would I contact at Corally USA to preorder a Carpet Spec kit? Is it possible for me to even do so? Thanks!
Kevin
Kevin
#1128
Jeff Brown is the man!! Rob too but he's a busy person right now I bet!!!
#1129
Originally posted by The Teacher
rayhuang, I cut the teeth on the front and rear belts and it seemed to free the drive train up some. New track layout so I could not compare lap times. Rear belt ended up breaking (will not do that again)....my next move is to cut the teeth on the pulley.
#1130
Originally posted by RCFREAK
hey mike dobbs.. it was nice chatting with ya for while at the birds.. you were sitting there schooling my boy jeff on high bite setups..we were both running the PRO4z..
i did like the fact that you were running your RDX pretty much stock. i was thinking about not buying the thicker chassis since im not going to the NATS and our track does not usually have tons of bite like bigger races.
BTW yeah she is a keeper!!
Arvin
Arvin
#1131
Oh yeah, make sure to lower the front shock tower to run foams on carpet!!
#1132
Mike;
I'll byte, how, and how much do you lower the shock tower? Is this a cut an re drill thing? Thanks for posting your set up on Corally USA. I will be using it for my first test at Hobby Chamber this weekend, if I get the lowered mounts in time.
Jim D.
Jim D.
#1133
Drill new holes just above the stock holes. Make sure you have enough meat to sustain a good crash. Don't countersink the hole, I turned my over and used buttonhead screws with a washer. You will need to cut the bottom of the tower to mount it in the new holes.
#1135
When you say you cut the teeth on the pulley what do you mean?
Mike- when lowering the shock tower I could not get ride height with 56mm tires do I need something other than just the stock parts? My ride height was like 7-7.5 mm raised the tower back up and it went back down to almost 2mm. Am I missing something? LOL
#1136
Jon;
Was figureing on Sat., with a new car I need an empty track to figure it out. If all goes well, I will trudge back up on Sun.
Jim D.
Jim D.
#1137
Ray
#1138
I was able to use the stock spring perches for the rear but I used the Xray ones for the front. When I run outdoors I have been running Losi spring perches front and rear.
#1139
Hey Dobbs....
I was looking to get ready for the Reedy Race. Let me know if you want to meet up somewhere and practice.
Jeff
Jeff
#1140
Poppi's Tomorrow!!!! If no rain!!!
