Old 02-21-2005, 03:59 PM   #1066
Michal101's Avatar
Default Body posts!
Speaking of body mounts…I wanted to know if most of you have kept the screw on type body mount or have switched to a conventional type? It seems to me that the screw body mounts are definitely needed in the front to help secure the top graphite bumper plate.
Also, is there any easy method of screwing on those body mounts holders without ripping up your hands???LOL
Basically, what have most of you done with the kit body mounts?
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 02-21-2005, 04:11 PM   #1067
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i switched 'em out for some others... if you keep the stock ones, after some use they will loosen up, but it is a lil rough for a while. i use some, uh, brand T body posts, and a long body clip to hold the bumper plate down... although im not sure it needs it. even without the clip, its pretty solid.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-21-2005, 04:15 PM   #1068
Trader Rating: 52 (100%+)
rubberneck racing makes a kydex rear body mount that works trick, I have been running it for a few now and havent had a problem
Mo
Mo Denton is offline   Reply With Quote
Old 02-21-2005, 04:31 PM   #1069
Michal101's Avatar
Mo
Hey Mo,
Any pics of Rubberneck's handywork???
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Old 02-21-2005, 04:36 PM   #1070
kartermdb's Avatar
Trader Rating: 15 (100%+)
i use the corally screw things, i like them because i dont have to worry about loosing them or the body, i know alot of people who have just drilled holes up and down the body post, and used the screw downs as the support for the body and just put a body clip on top
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 02-21-2005, 04:41 PM   #1071
TJ Bradley's Avatar
Has anyone raced on the nats track in CT yet?
TRUSource
www.trusourceusa.com www.hotracetyres.com www.teamtekin.com www.teamassociated.com www.racepf.com www.superiorhobbies.com
www.beachlineraceway.com www.schelleracing.com www.p1brand.com
TJ Bradley is offline   Reply With Quote
Old 02-21-2005, 05:07 PM   #1072
Yes I raced on the Nats track a couple of time already. What do you need to know about it? I'll try to help you any way possible.
DJG24 is offline   Reply With Quote
Old 02-21-2005, 05:57 PM   #1073
RBLove's Avatar
Trader Rating: 72 (100%+)
TJ,
Cuffs has ran on it. I hear it is super smooth, okay traction, but bruttle boards. Some corners with no flappers and just straight 2x4's....
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 02-21-2005, 06:09 PM   #1074
Jeff Brown's Avatar
I've had the same body posts on the car since I built it. I have yet to break one and/or have one loosen. You can tighten the posts down with pliers since you will never put the body rests down that far.
TJ..... i think that is where Cuffs wanted to buy stock in suspension arms. Like RB said...... rumors are BRUTLE.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 02-21-2005, 06:11 PM   #1075
kartermdb's Avatar
anyone running aluminum arms, if so, are you lubing them or just letting them go dry?
Mark Burt
Thanks to:
Old 02-21-2005, 06:11 PM   #1076
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Jeff, you got PM.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-21-2005, 06:18 PM   #1077
Yes the place is killer on parts!! I was there when Cuffs broke so many parts he had to put the car away for the day. The boards are double 2x4 and the flappers on the corners had gallon buckets of sand in the middle of them. It was crazy on parts so stock up. The track is pretty large to and you run from on top of a super tall driver stand.
Old 02-21-2005, 06:20 PM   #1078
Sounds like a somewhat-local track around here. The track is very large and the driver's stand is like 10 feet in the air, at least. I've only been there once, but we ran mod and the cars "felt" so slow when they were right below you...very hard to get used to from being only like 3-4 feet above the track.
USVTA Member #211
Old 02-21-2005, 06:28 PM   #1079
stormperson's Avatar
Send a message via AIM to stormperson
TJ- I ran on it a few times. It is pretty smooth, there is one rough section but the last layout they had didnt include it. The traction picked up, its Frank's newest ozite (cleveland last 2 years and the birds this year), so it gets cars running on it, it should be fine.
Boards were that bad last time i ran on it, it was just the layout they had before the regional.
But both layouts werent exactly tight and techinical and the drivers stand is really high.
PM me if u want the rev. 4 set up i ran there, but i am sure your snowbirds set up will be really close if not alot more dialed, lol
(Also i am running parma tires).
-mark strasnick
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 02-21-2005, 08:20 PM   #1080
wannabee's Avatar
Mo
Thanks Mo, I will post a pix ASAP!!
wannabee is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
