Old 02-17-2005, 02:02 PM   #1036
wannabee's Avatar
Originally posted by rayhuang
Kevin-I want to race at Platinum again soon. Let me know a good day for 19t or modified down there. You know-I gotta see how much higher I can plaster the wall at the end of the straight. I know I hit it at least 2' high-I can go for 3' next time!!
ASAP! I'm not sure if im racing at Bio's this weekend or not, kinda wanted to do some "diffrent track testing"!!!!
The 27th is ON for sure, I'm down for 19T and am pretty sure we can get at least 4 feet off the ground!!LOL
Grab your balls and get down here (team balls that is)!!!LOL
wannabee is offline   Reply With Quote
Old 02-17-2005, 05:21 PM   #1037
Originally posted by CypressMidWest
CurtDawg: Platinum this weekend? P Diddy and I will be heading up. I'll probably run TC MOD. Stock's just no fun.
CypressMidWest
Hey bro i am so down for some mod TC i'm in...
Curtis
TLR|Horizon Hobbies|SpektrumRC|JConcepts|BradleyRacing|92zero|VRP|AceHardware|Tekin|TXDGraphics
CurtDawg is offline   Reply With Quote
Old 02-18-2005, 06:15 AM   #1038
imprsme's Avatar
Trader Rating: 74 (99%+)
Can some one tell me what weight oil comes in the shocks in the UK kit? Also what is the final drive ratio on this car, wanting to get the same roll out as I was using on my other car.
imprsme is offline   Reply With Quote
Old 02-18-2005, 06:38 AM   #1039
Pulley ratio in the car is 2:1
DJG24 is offline   Reply With Quote
Old 02-18-2005, 06:46 AM   #1040
Racer Z's Avatar
Default RDX
Good run Teacher at Debbies last week. Your RDX looked real good. I liked the way it transfered weight left to right. See you and the rest of the guys soon. Tell Arvin when you see him I said hi.
Melvin
Racer Z is offline   Reply With Quote
Old 02-18-2005, 04:53 PM   #1041
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Thumbs up
Corally USA - I got the package today. Thanks for the quick shipment!!
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 02-18-2005, 07:46 PM   #1042
Michal101's Avatar
Default Roll center blocks
At what time would you want to run the low roll center blocks (Part # 79121) either front or rear?
What are the advantages and disadvantages?
Thanks, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 02-18-2005, 08:23 PM   #1043
wannabee's Avatar
Default Re: Roll center blocks
Thanks, Mike
Good question, I tried them last week with med. bite and the car was OK not great! I went back to a higher roll center and the car was night and day better!
I noticed that Dobbs ran less caster than I did with a slammed RC set up..Is that the trick? 2* caster with lower RC's short camber links...It's hard to take a set up from a car that was being ran on "tar" paper ozite though (lots O bite)...
Old 02-19-2005, 01:05 PM   #1044
wannabee's Avatar
Bump!
Old 02-19-2005, 06:20 PM   #1045
Default roll center
i run the low roll all around and like it better. I also dont run any bars to let the car roll around more. I also run the front link short and in the lower hole.
R Monahan is offline   Reply With Quote
Old 02-19-2005, 06:34 PM   #1046
Michal101's Avatar
Default Re: roll center
I'v notice on a couple of the Setups on the Corally site and some of the setups from the guys at the Snowbirds that they were NOT running a front sway bar. I find this interesting.
I ran my RDX for the first time today with basically the kit setup and the 1.3 pistons and 60 wt in the front and 40 wt in the rear and had a very bad push going into the turns, but it felt very sweet on the sweepers. Maybe I will take off the front sway bar and see what happens.
Any thoughts???
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Old 02-19-2005, 07:02 PM   #1047
I am using stock pistons with 60 wt oil in the front and 40 wt in the back i didnt like how the hpi 1.3 pistons fit. I also think that a 39 pd spring is way to stiff. i use 28 pd xray spring in the front and a 22 pd asc spring in the rear. i think a stiff spring reacts slower in the chicane
Old 02-19-2005, 07:05 PM   #1048
whats your castor and your rear camber link
Old 02-19-2005, 07:15 PM   #1049
Michal101's Avatar
I am running the 39 spring in the front and the 26 in the rear (which maybe part of the problem).
My castor is 4 and the rear camber link is in the 3rd hole on the bottom of the rear shock tower and kit setting on the rear hub (inner bottom row).
Front shocks 2nd hole in from the end as well as the rear shocks on the shock towers.
BTW, plaids and purples.
Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Old 02-19-2005, 07:25 PM   #1050
first thing is i gained 4 tenths per lap at the birds by switching to cyan, magenta and raise the rear camber link on the shock tower and move it in one hole and try 1 down on the hub. this car loves the softer tires. i worked hard a finding a set up with the purple and plaid and no matter what i tried it still had a small push
by the way i run parma tires, someone said there differnt offset then jaco weither of not that is true i dont know i havent checked into it yet.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
