Team Corally RDX Touring Car >
Old 07-05-2008, 05:30 AM
  #10411
The Bear's Avatar
rdx for drift....
I personally consider the RDX my 'wooby' for carpet foam. However, if it keeps the hobby going....
I looked around and didn't see any sort of setups for drifting. What are you going to run for springs, oil, ride height, etc?
I'm guessing drift runs a really stiff chassis? Like 33 - 36lb front springs and 30lb rear with like 80/60 oil, 5mm ride height with minimum droop? thick chassis instead of thin... zero caster....?
got a game plan?
The Bear is offline
Old 07-05-2008, 04:34 PM
  #10412
Some people run a stiff chassis, but that's only beneficial if you run on a hard and smooth surface like concrete and carpet.
Since most of the meets are on parking lots, I run 20 wt in the front and 30 in the rear. soft springs up front and medium in the back. any stiffer and it bounces all over the place.
I don't run any droop either when I'm on a parking lot. but for practice with an uneven surface I think it's a good idea to run a couple mm of droop.
Thick chassis? definitely on a parking lot. Thin can be used for the concrete. You can run zero caster if your driving style calls for it. I run the box stock setup. I also like about 0.5 neg camber in the rear and 1.0 neg deg camber up front. Toe-in is stock aswell.
Most people run a locked diff or spool in the rear. I'm a little different in the sense that I keep both ball diffs in. the front is a little tighter than the rear. I drove cars that had a locked rear/spool in the back and I found them to be a little too tail happy compared to the way I have mine setup, which gives some very nice transitions through the corners.
Just like in real life, the more throttle you give the car, the quicker it will rotate through the corners.
Sabin is offline
Old 07-05-2008, 09:19 PM
  #10413
The Bear's Avatar
and you guys are using those plastic drift wheels?
The Bear is offline
Old 07-06-2008, 12:36 AM
  #10414
Depends on the surface. On carpet, I use HDPE rings for practice and LDPE rings for some reasonable speed. reasonable being that if I wipe out, I end up breaking something. Asphalt it's reversed. I can't explain why it works the way it does but LDPE gives the speed while HDPE is the ones for practice.
There's also the HPI drift compounds and the Odyssey Garage tires that I have yet to pick up.
I tried ABS and while they're good for learning, they lack the punch and grip I desire in a tire.
Sabin is offline
Old 07-06-2008, 05:58 AM
  #10415
rtherbe's Avatar
Not sure on how she'll drift,(probably real good) but still a sweet chasis in any regard....
rtherbe is offline
Old 07-06-2008, 03:20 PM
  #10416
and I got it and a lot of spare parts for 175 bucks from one of the guys at T-Bang.
Sabin is offline
Old 07-06-2008, 08:01 PM
  #10417
If you have any drift buddies who want a RDX, I'll sell mine-three different chassis, top decks and a ton of spare parts for $100!
outlandr91 is offline
Old 07-09-2008, 03:54 AM
  #10418
Once they see it for themselves, I bet they will want one.
BTW, I'm also looking to race carpet/asphalt with this. Seeing as this thread is just ginormous, what's a good setup or two to try?
Sabin is offline
Old 07-09-2008, 08:00 PM
  #10419
Check out Corally's website, there's a lot of good set-ups there.
Old 07-09-2008, 08:56 PM
  #10420
Jesse Holman is offline
Old 07-25-2008, 10:13 PM
  #10421
Big Midget's Avatar
Trader Rating: 101 (100%+)
I just bought a used Corally off e-bay. I'm almost done setting it up for this weekend. BUT... My shocks are leaking out the top.........
The manual doesn't really help so I maybe you guys can. The diaphrams look OK dont see any holes in them.
Any help would be GREAT!! Thanks
Big Midget is offline
Old 07-26-2008, 06:27 AM
  #10422
Big Midget's Avatar
Well it turns out, It was a diaphram problem after all. I was able to use some from an old set of 3 racing shocks from my TA05.
The fit GREAT!! no leaks.
Old 08-05-2008, 02:07 AM
  #10423
Kajman's Avatar
I've bought used rdx as spare car for my xxx-s. but I still am unable to make it drive at least as losi... It is very nervous, easily spinning. I run on parkplaces, angles are back 1deg, front 1deg and toe in 0.5, what can I do to make it more stable? I run on 2 diffs, brushless, rubber.
Kajman is offline
Old 08-05-2008, 06:40 AM
  #10424
MD
MD's Avatar
Trader Rating: 128 (100%+)
Kajman - You could try the setup sheets on the Corally USA web site. Just click on Racer Support and then setup sheets.
MD is offline
Old 08-05-2008, 06:44 AM
  #10425
Kajman's Avatar
I've tried, will keep on changing setups, maybe it is just such a nervous chassis?
Kajman is offline
