Old 10-23-2007, 08:53 PM   #10366
Glowster21's Avatar
Trader Rating: 116 (100%+)
Originally Posted by jdearhart View Post
I'm Looking for some of the old style RDX Diff pullies. They were the black two piece design that was replaced by the white liteweight pullies. You can see them in the RDX instruction manual on page four. Part number 79172.
http://international.corally.com/pdf...ual-090305.pdf
If anyone has one or two they want to sell, i'd be very interested!
Thanks!
Jack
Call Dave at Speedzone Hobbies in CT. I know he has them on the wall. 1-860-436-2532. He opens at 1 on wednesday and takes paypal. www.speedzonerc.com
Glowster21 is offline   Reply With Quote
Old 10-23-2007, 09:47 PM   #10367
tom235's Avatar
Set up: 27 turn, 34p, 104s, c27s
Front toe in slight
-1.5 camber Front
-1.5 camber rear
4 degree castor blocks front
Two shims for rear toe-in not sure size looks like 3mm in width Maybe 2 degree of rear toe-in.
4 Black springs 60w front 40w rear 5.5mm height.
this may shound domb but make sure you have the right springs in the right place.
make sure that your wheels turn the same amount on each side
make sure that your tie rods are the same size on doth sides
i just went thru mine and i found one side of the diff bearings were junk
hope this helps
Tom
tom235 is offline   Reply With Quote
Old 10-24-2007, 06:29 PM   #10368
rtherbe's Avatar
Thanks, Larry and Tom, I think i will order a diff rebuild and diff bearings to see what that does. I might try to rebuild with current parts, and see what happens, till i get the parts in.
rtherbe is offline   Reply With Quote
Old 10-28-2007, 05:42 AM   #10369
Post rdx parts for sale
I am having a clear out of some of my rdx spares. Below is whats for sale.
2.4mm chassis part number 79337 (i have filled out slot to enable use of tape but i am sure you could use strap again if needed)
2.9mm chassis part number 79339 (i have filled out slot to enable use of tape but i am sure you could use strap again if needed. this has been used outside a few times.)
2.9mm top deck part number 79356
rear body post plate part number 79407
Shock towers x2 79239
Alloy servo posts 79395
Complete layshaft assembly with two 48dp spur gears
Front spool part number 79155
Complete diff with ceramic bearings inc thrust bearing.
Front bulk head inc bearing holders. part number 79199/79204
rear left and right bulk heads again with bearing holders also inc roll centre block with inserts. part numbers 79199/79205/79206/79120/79123
Rear 2degree uprights part number 79296/79297
a couple of roll bars not really sure which ones (there are silver black and brass ones)
steering blocks part number 79280.
I will sell this as one job lot or split into which ever parts you want. I will ship anywhere in the world. Payment by paypal please. I have added this lot up and it comes to over 500. So sensible offers please. Pics can be sent on request
Cheers
adavison1974 is offline   Reply With Quote
Old 10-30-2007, 08:10 PM   #10370
DrunkMike's Avatar
Trader Rating: 22 (100%+)
I broke the screw that holds the diff together and got it out, but now my diff wont stay tight some one told me i need a new diff lock nut, but i dont want to have to buy the whole diff half, if any one knows what is wrong or where i can get a diff nut please let me know.
DrunkMike is offline   Reply With Quote
Old 10-30-2007, 09:18 PM   #10371
Still Bill's Avatar
About a year ago, CorallyUSA sent supplies of the diff nuts to their dealers for handing out to customers...free. Check with a lhs that is a Corally dealer for one. I have a few in my spare parts. Never had to use one.
Otherwise, contact Jeff Brown at Corally USA.
And don't use the screws with the threads that go all the way to the head of the screw. That is the old one. Get the new one...for sure.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-31-2007, 02:35 PM   #10372
DrunkMike's Avatar
i have the new screws, i guess ill try to contact corally. also is there any bennifits to the 4mm chassis, im tying to get ready for the champs and wanna get the car set up before i go for the most part but on the set up sheet it never says what chassis they use.
Old 10-31-2007, 03:11 PM   #10373
I'd like to know how to get that diff nut out of the diff half. I recently had one break on me as well and put in a one way after the LHS ordered me new diff parts (incorrectly). I've got a spare diff but knowing how to get the nut out would be gold.
ASCI_Blue is offline   Reply With Quote
Old 10-31-2007, 04:36 PM   #10374
DrunkMike's Avatar
i planed on drilling mine out, i gguess with some effort you can pry it ou but that sounds like a lot of work.
Old 10-31-2007, 05:05 PM   #10375
I weigh 160 lbs, I put a piece of metal in the diff half and leaned all of my fat ass against it and it did not budge.
If I was feeling talented enough I'd have taken a drill to it for sure.
Old 10-31-2007, 07:17 PM   #10376
DrunkMike's Avatar
i guess im lucky enough to be a tool maker we have machines for this kind of stuff.
Old 10-31-2007, 10:14 PM   #10377
Still Bill's Avatar
Mike,
In 2006, the Jason E (1st) and Aaron Y (2nd) RDX stock rubber setups used the 4.0 mm chassis plate. Neither came to the IIC this year. I like the 4.0 mm chassis when you have high traction conditions on a smooth carpet track...like at the IIC...For other carpet conditions using rubber, I prefer the 2.9 mm chassis.
My decked out RDX 4.0 mm rubber chassis from this year's IIC is currently listed in the Classifieds section.
Not sure about the 4.0 with foams though.
Bill
Old 10-31-2007, 10:49 PM   #10378
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Ya i've got pretty good at taken those nuts out. The only way I've found to get them out is to drill them out. Granted i'm a machinest and have access to all the right tools as well.
I'm currently running a 4mm chassis on my rubber car.. Love it
Dustin Layne
smoke81 is offline   Reply With Quote
Old 11-01-2007, 07:19 AM   #10379
rtherbe's Avatar
Hey anyone know if I can get the diff washer/springs seperatley? What would be their PN#? In the manual it shows just the diff rebuild as the #. I dont neccassarily mind getting the whole kit but,they're not in stock at Ampdraw who I use frequently (good service)
I believe that this is my problem I posted about previously. I realized that it only breaks loose on power. it reacts the same off power
Old 11-04-2007, 05:57 AM   #10380
The part number for the diff washer/springs is:
COR1236 10pcs will set you back $5.00
TexasMack is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
