Old 02-17-2005, 07:45 AM   #1021
Michal101's Avatar
Originally posted by wannabee
Bearing holders: DOWN
Hit the chassis with the Dremel to eliminate some of the belt drag.
The drive train is tight at first, but will free up once you run it..
I appreciate the info.
Thanks, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 02-17-2005, 08:38 AM   #1022
The Teacher's Avatar
Trader Rating: 49 (100%+)
Question, it seems that I have to rebuild my diff after every race day, is this normal??? I think I'm not doing something right when building the diff but when I'm done it's locked down (meening it doesn't slip) and it's smooth. Can anyone help??? How many coned washers should I be using on the diff bolt???
The Teacher is offline   Reply With Quote
Old 02-17-2005, 08:42 AM   #1023
rayhuang's Avatar
After 20 or so pacls of stock-both my diffs were still as smoooth as new. But after 5 packs of 19t-the rear has started to show a little grittiness-but far from needing a rebuild.
I have 4 cone washers and stealth lube on the diff balls and black grease on the good thrust washer. The good thrust washer is the one with the copper colored race-not the stamped alum one.
For me-I think my set-up unloads the insde rear too much in fast-tight corners and I slip the rear diff a bit. maybe!! I think the diff itself is fine.
Ray
Ray
Old 02-17-2005, 08:44 AM   #1024
wannabee's Avatar
Are you using the alum. diff pullies or the delrin??
I believe the kit calls for 4 coned washers...
wannabee is offline   Reply With Quote
Old 02-17-2005, 08:57 AM   #1025
wannabee, I have the black delrin pulleys ....
rayhuang, I have the ceramic thrust ball/washer set up on both diffs now but I have tried both types that you mention. Maybe it's the amount of lube that I am using??? Do you also put grease on the coned washers???
Old 02-17-2005, 09:05 AM   #1026
rayhuang's Avatar
Nope-no grease on the cone washers. No carbide stuff in my diffs-at least i dont think so!! I use very little lube on my diffs actually. I think they tighten up with less pressure-so therefore the balls and rings take less load and they diff should last longer. Thats my theory anyways. I do pack as much black grease into the thrust washers as I can though.
Old 02-17-2005, 10:52 AM   #1027
Black Corally delrin diff pulleys, Corally ceramic diff balls, Corally cardibe thrust washers, Associated black grease and Diff lube!!
Smooth as silk, no problems!!!
Mike Dobbs
barnacle is offline   Reply With Quote
Old 02-17-2005, 11:09 AM   #1028
Can anyone give me an idea on how tight you keep your diffs?
Do you tighten just until they not longer slip?
Electro-MAX RC is offline   Reply With Quote
Old 02-17-2005, 11:33 AM   #1029
Tighten the rear diff untill it stops slipping then 1/8 to 1/4 turn more,Tighten the front alittle tighter then that..I always run my front diff alittle tighter then the rear..
Hope that helps
Curtis
TLR|Horizon Hobbies|SpektrumRC|JConcepts|BradleyRacing|92zero|VRP|AceHardware|Tekin|TXDGraphics
CurtDawg is offline   Reply With Quote
Old 02-17-2005, 01:20 PM   #1030
CypressMidWest's Avatar
CurtDawg: Platinum this weekend? P Diddy and I will be heading up. I'll probably run TC MOD. Stock's just no fun.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-17-2005, 01:27 PM   #1031
wannabee's Avatar
Old 02-17-2005, 01:37 PM   #1032
rayhuang's Avatar
Kevin-I want to race at Platinum again soon. Let me know a good day for 19t or modified down there. You know-I gotta see how much higher I can plaster the wall at the end of the straight. I know I hit it at least 2' high-I can go for 3' next time!!
Old 02-17-2005, 01:40 PM   #1033
How about Sunday Ray? I know it's not a "big race" but it'll still be fun.
Old 02-17-2005, 01:41 PM   #1034
koabich's Avatar
Send a message via Yahoo to koabich
Just talked to Corally USA. The US Carpet Spec is another 2 weeks out
I want this car badly!!
Have fun!!
koabich is offline   Reply With Quote
Old 02-17-2005, 01:43 PM   #1035
rayhuang's Avatar
Wish I cold-but the gate is a Throw down royal!!! STock sedan TQ and honor are on the line!!!
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
