Old 03-05-2007, 08:11 PM   #10276
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm surprised to hear they're backing out, mine are generally so tight they're hard to turn at all. Is there some chance you're using the wrong screw or something? It doesn't seem possible for them to back out on their own under normal circumstances.
syndr0me is offline   Reply With Quote
Old 03-05-2007, 08:31 PM   #10277
gone_wheelin's Avatar
They are the only 4 set screws that could work in there. They are approx. 1/2" - 3/4" long set screws. They thread in with almost no effort.
Redwood Empire Ground Pounders ~ Team CFX ~ Jakes Performance Hobbies
gone_wheelin is offline   Reply With Quote
Old 03-05-2007, 08:45 PM   #10278
rcgen's Avatar
I had one set screw that was loose while the other three were very tight. I now use the torx screw that is used to mount the shocks to the shock tower. Very easy to adjust droop and no fear of the stripping.
rcgen is offline   Reply With Quote
Old 03-06-2007, 04:37 PM   #10279
Steve Bahnatka's Avatar
Send a message via AIM to Steve Bahnatka
Post 95...
Originally Posted by seaball,(9-1-04)
- i would like to see the rear hub ears lopped off, and vertical holes drilled in the flat section that they currently rise from.
- chris.
And response...
Originally Posted by CorallyUSA,(9-1-04)
Rear Hubs.... this was tested and compared in prototyping and we liked this better.
SMC-/-JACO-/-PARMA-/-TEKIN-/-CRI
Steve Bahnatka is offline   Reply With Quote
Old 03-06-2007, 04:40 PM   #10280
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Hey jeff are you going to be able to make it up to the stock rubber tire nats at trackside next month ?
wallstreet is offline   Reply With Quote
Old 03-12-2007, 07:17 PM   #10281
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Jeff, I'm gonna give you a call tomorrow. We had a great weekend on the car at the Oklahoma state champs. Figured out of lot of stuff. Man with as fast as the RDX is this new car is gonna be scary.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 03-13-2007, 11:01 PM   #10282
syndr0me's Avatar
Hi guys. I'm wondering if maybe a bad batch of the 35 "new" arms for the rear got released a while back. I bought one of the original packages that was slightly too small, and those four arms lasted me about 6 months. Then, when I got into the new bags, I broke 8 arms in 3 race nights. After I ran out, I went back to the "old" 75 arms in the rear and haven't had a problem since. I don't know if anybody else has had trouble, but it just seems like too many breaks to be a coincidence. It was tiny, minor things that caused them to break, like rubbing a flapper. I had at least one break without contact, though I suppose it could have been cracked.
Old 03-14-2007, 12:42 PM   #10283
jdearhart's Avatar
Trader Rating: 15 (100%+)
Default Old two piece RDX diff pullies
I'm looking for the old style diff pullies that were two piece. They are the black ones pictured in the link:
http://ashfordhobby.com/detail.aspx?ID=4560
If anyone has any, please let me know!
Thanks!
Jack
jdearhart is offline   Reply With Quote
Old 03-14-2007, 03:05 PM   #10284
BJohnson's Avatar
Hey Guys - Just wanted to drop in and give a big thanks to Jeff and Rob at Corally USA for all the help at the Nats. Keep up the great work and great customer service!
Thanks - Brad
BJohnson is offline   Reply With Quote
Old 03-14-2007, 03:15 PM   #10285
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
anybody have a rubber tiree carpet setup fopr mod? we have reg 12 race this weekend coming up please post!
BadBoyRC is offline   Reply With Quote
Old 03-15-2007, 01:37 PM   #10286
tim fry's Avatar
Has anyone got a template for the front plastic under bumper they could post. (the one that helps protect the front wishbones)
tim fry is offline   Reply With Quote
Old 03-16-2007, 04:45 PM   #10287
Default RDX Bumper
Tim
I will bring a trace of mine with me on Sunday for you.
SagaMike is offline   Reply With Quote
Old 03-18-2007, 09:34 AM   #10288
Default for sale
hiya u lot, selling my RDX, got alot of spares, about 5 paires of wheels and tires all glued on and ready to go...... 150ono or swap for a offroad 1/10 electric buggy... 2 or 4 wheel drive
jordan
pm on here if interested or email me on [email protected]
jordys jrxs is offline   Reply With Quote
Old 03-20-2007, 09:46 AM   #10289
Hello all,
I ran my car this past weekend at an asphalt track that had excellent traction. However, anytime the car made a turned (even slightly turned) the wheels screeched. I assumed this was because I had too much traction (as was apparent by the wear hole on my front left tire and premature wear on my right tire after only 1 and 1/2 runs). The car also had somewhat of a push that I also felt was taking away corner speed.
I'm not sure how to correct this problem so that the car isn't eating up a set of tires in 1 or 2 runs and pushing in the turns.
I'm running Jeff Brown's setup from the 06 Roar Asphalt Nats that was held at Speedworld Race Way.
Should I just try a completely different set-up? Any suggestions?
Much Thanx
Obsidian is offline   Reply With Quote
Old 03-20-2007, 01:26 PM   #10290
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
Originally Posted by Obsidian
Hello all,
i always had to run a crazy soft setup on mine to get it to turn and to be easy on the tires. i always thought they screeched because they didnt have enough bite so the car stopped rolling and just slid on the tires. well anyway, i ran 14 lbs. in the front and 12 lbs. in the rear with 6 mm ride height and 3.5 mm over ride height for droop. i ran the large pistons with 35 wt trinity oil frnt and rear. mind you this was with a 8X1 trinity shock.
-Zac
Z.Hallett is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
