Team Corally RDX Touring Car
Originally Posted by McSmooth
Rob/Jeff:
Will either, or both of you be heading to the Nats next week?
Jeff
want to know if other belt fit on the rdx like i would like to have some white one like tamiya or new cyclone white belt to macht my spur gear and diff pulley hehe!!
let me know if you ever see that !! hehe
later
later
Can someone help with a part number for the small bearings in the steering arms. (cor79279's) i can find bushes but not the bearings.
Bill
Hi all
If I purchased the CORALLY RDX – US CARPET SPEC - PART NO. #00167 for racing on Low/Med Bite Ozite, what other parts are needed to get a decent setup? I know 6 degree casters for approx $25 each but what else?
THE HARD FRONT BUMBER IS AN MUST, UNLESS U ARE VERY VERY GOOD
Get yourself the black spring kit, the hard bumper set, and a 64 pitch gear.
The rest of the stuff like low roll center blocks, aluminum steering knuckles, etc you can get as you go along.
When I first got the car, I ran the stock roll blocks for a couple of months and the car is still fantastic.
Just get a setup from the CorallyUSA website, and copy it as close as you can. You'll find the car is still really good, even if you don't have each and every little hopup available for it.
Hi all
Thanks for the info. The problem I see is that the kit is already $400+ and this comes with a decent setup. The basic parts are generally fine. I am just concerned that I found 1 already, the C-Hubs which are a good choice for replacement but they only come in the Duraluminum. Are there other hopups on the latest carpet setup which are higher dollar items? Of course you can always go with a 4d caster and then change the setup in other areas to gain turn-in.
Has anyone else had a problem with their droop screws backing out threading in during a run?
Originally Posted by Still Bill
For top and bottom of the "Duraluminum Steering Blocks", you want to use the bushings instead of the ball bearings. The ball bearings don't hold up to the abuse.
Bill
Bill
Thanks i'll try Bushings
Originally Posted by 429racer
Are you running aluminum arms?
Originally Posted by syndr0me
Na, you don't want the SRC bushings, I think they had problems with those, even though they were made from solid gold. Get the ones made by Corally: COR1141.
Nope. Running the standard composite/graphite arms. I added a few drops of loctite to the screws thinking that might help a little. Haven't had a chance to check it yet though. I did this before the main last night. Will check this again tonight or this week when I get a chance.
