Old 02-15-2005, 09:54 PM   #1006
rayhuang's Avatar
Originally posted by John Fontaine
If not, i'll have team tamale make me some lowered spring perches. Is anyone interested if I have them make em?
JOhn-I am using stock plastic XRay ones-so you could easily buy the non-lowered Team Tamale ones for the Xray. No special orders required.
Just FYI-the lowered Team Tamale ones wont work. They sit on the arms and bind on the shocks-not good.
Old 02-16-2005, 10:50 AM   #1007
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Ray - I have experimented with stock Xray spring perches, but the diameter of the Xray and Corally ball ends are different. The Xray spring perch on the Corally ball end is loose (Maybe could be fixed with some tape wrapped around the ball end). I was going to send Team Tamale two Corally spring perches and he was going to machine lower ones based on the Corally design, not the Xray. Let me know if people sound interested, maybe he'll stock it on his site.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 02-16-2005, 10:54 AM   #1008
rayhuang's Avatar
true-they dont fit snug-but after a few race days-it doesnt bother me anymore. You know kind of like the three panels of old wallpaper my wife ripped off the walls at home as a big hint its time for interior decorating. Just dont notice them anymore!!
Old 02-16-2005, 11:09 AM   #1009
Ray,
I had similar problems when using schumacher carpet dragons or T27 tires. I over came it by carefully cutting about 2mm of the end of the corally ballends. This then allows the collar to sit lower.
Andrew Payne
axpayne is offline   Reply With Quote
Old 02-16-2005, 11:16 AM   #1010
rayhuang's Avatar
Originally posted by axpayne
Ray,
Andrew Payne
axpayne-cool-I did that too!! Cut the ball end 2mm. But I still used the Xray spring perches. Now that my tires are all under 55mm I bet I could slap the corally spring perches back on and have no problems!!!
Old 02-16-2005, 11:28 AM   #1011
it is also a good idea to cut half the threds on the shaft off and ya cut the shock end in half and that shoud do it and there are many diff spring cup that will work, kyosho,ae,rayspeed,exray,ect.
Chris Tosolini is offline   Reply With Quote
Old 02-16-2005, 04:51 PM   #1012
If you use the Xray spring perches use the Xray shock ends so they fit snug. They are the same length and work perfect.
DJG24 is offline   Reply With Quote
Old 02-16-2005, 08:41 PM   #1013
I haven't tried it, but the corally ball fits into the xray ball end without problems?? The two cars use completely different mounting hardware.
Old 02-16-2005, 08:43 PM   #1014
kartermdb's Avatar
Trader Rating: 15 (100%+)
i use the xray perches on carpet, they fit rather loosely but i havent had a problem with them
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 02-16-2005, 08:45 PM   #1015
I'm not saying that the xray perches wont work, cause I know they do...i've done it. But it might be trick and worth the money to have team tamale make some rad alum shorten spring perches off the corally spring perch.
Old 02-17-2005, 05:55 AM   #1016
Yes, the ball from the Corally fits into the end of the Xray shocks. They mount right up on the Corally.
Old 02-17-2005, 07:13 AM   #1017
Michal101's Avatar
I just purchased the RDX and I have a couple of questions.
1) Which way do the front bearing holders go...up or down? I know in the instruction manual that it states "Bearing hole downwards" in the rear but nothing on the front.
2) I noticed the front belt right before the front pulley is rubbing the bottom part of the chassis and I wanted to know if this should be a concern?
3) I have the entire drivetrain completed and installed and there is some serious drag on it and it does not rotate freely what-so-ever. I have taken it all apart 2 separate times and checked for everything that I could think of that would be causing the problem and did not find anything. I was wondering is the drive train supposed to be this way or not. (I have built at least 2 dozen R/C cars and I have never had a drivetrain problem this bad before)
Any help would be greatly appreciated.
Thanks, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 02-17-2005, 07:18 AM   #1018
Rob Phillips's Avatar
Ah Hah, Mike got a Corally! You Know I wanted that kit. Let me know when your ready to sell it. I knew you couldn't resist.
Rob Phillips is offline   Reply With Quote
Old 02-17-2005, 07:40 AM   #1019
wannabee's Avatar
Thanks, Mike
Bearing holders: DOWN
Hit the chassis with the Dremel to eliminate some of the belt drag.
The drive train is tight at first, but will free up once you run it..
wannabee is offline   Reply With Quote
Old 02-17-2005, 07:45 AM   #1020
wannabee's Avatar
Oh yea I've got that set up here at work, email me [email protected]
Kevin
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
