Old 01-16-2007, 03:16 PM   #10051
Jeff Brown's Avatar
Originally Posted by Vicko
well check with AB Charles Hobby they are out of the brackets
so dose anyone else know where I may fine some at this time
You can actually use the shock extensions from the older suspension arms as braces. A customer mentioned this to me on the phone one time. The part number is COR79248.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-16-2007, 03:17 PM   #10052
Jeff Brown's Avatar
Originally Posted by Obsidian
Just wondering if anyone uses or recommends the Ceramic thrust bearing for the RDX diff.
You can swap them out if you are changing the thrusts anyways. I don't think it is mandatory, but if you are installing new ones you might has well go ahead.
Jeff
Old 01-16-2007, 04:18 PM   #10053
gone_wheelin's Avatar
Originally Posted by Jeff Brown
The latest kits have black grease in the thrusts now. You can remove them if you want to make sure everything is smooth. Just don't mix up the order of the thrust washers as one is smaller than the other.
The bearings don't need to be sprayed out and relubed. They are super free and spin great out of the box. The outdrives do ride on the bearings that are pushed into the bearing holders. The fit is sometimes snug, if they are super tight you may have to check the fit of the bearing holders into the bulkheads for tightness as well.
Jeff
Thanks Jeff. I eventually pulled my head out of my butt and looked at the one-way that came with the kit and determined that there wasno way the spool was going to fit in those bearings. After installing the rear diff I saw that the bearings slid up-to the bosses(?) on the outdrive. I've never run a one-way before so maybe this will be a good time to try one out. And if I don't like it I can always get new bearings and holders so I can run the spool. Although, I might have a small problem as I have already matched the bulkheads to the one-way bearing holders. Guess I will have to match the spool bearing holders to the bulk heads now.
Redwood Empire Ground Pounders ~ Team CFX ~ Jakes Performance Hobbies
gone_wheelin is offline   Reply With Quote
Old 01-16-2007, 09:01 PM   #10054
blade072's Avatar
Trader Rating: 98 (100%+)
Jeff
i checked it after he put it together and sure enough it was down to 4 to 4-5mm so its all good... he has atleast 1 to 2 mm to play with but the back was almost to the ground... alot more adjustablility as far as spring collars being wound down more but atleast he can make ride height at front now
cheers
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-16-2007, 10:40 PM   #10055
Still Bill's Avatar
Hi Jeff,
Do you know where I can get slightly shorter axles for my RDX? Believe someone posted an answer many moons ago...You?
FYI...I typically have narrow hexes on rear with RP30 pre-mounts.
Thanks.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-17-2007, 10:58 AM   #10056
Jeff Brown's Avatar
Originally Posted by Still Bill
Hi Jeff,
Thanks.
Bill
Hey Bill,
Not that I am aware of. I simply dremel down the axle if I run the Narrow hexes and it is sticking out too far.
Jeff
Old 01-17-2007, 11:10 AM   #10057
Trader Rating: 45 (100%+)
Jeff B - For the new rear hubs on (on Dayger's 2007 Novak Setup) what are they supposed to do to the handling of the car? I see the ball height can be changed as well with these new hubs.
Apex is offline   Reply With Quote
Old 01-17-2007, 11:14 AM   #10058
Jeff Brown's Avatar
Well, the vertical ballstud hubs have 2 mounting locations. The outer one will lock in the rearend more, probably more for rubber tire racing as it won't rotate as good. The inner hole will be used most likely for carpet racing on foams. You can adjust the angle more evenly and make subtle changes. You can also change the angle without changing the length which is nice.
I forgot to put on the setup sheet he ran 2 of the Corally shims, PO. 1280 under the link.
RDX Vertical Ballstud Hubs
PART NO. SRC79295 - $60.00 RETAIL - 2 pcs.
Jeff
Old 01-17-2007, 01:16 PM   #10059
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
haha... last year i took a set of stock hubs and turned them into vertical mount hubs with the same mounting holes.. its just funny cuz they look identical.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 01-17-2007, 02:20 PM   #10060
Vicko's Avatar
Trader Rating: 14 (100%+)
it also look just like the tamiya 415 and ta05 rear hubs
Vicko is offline   Reply With Quote
Old 01-17-2007, 08:52 PM   #10061
Still Bill's Avatar
Jeff
Jeff,
Will these hubs be applicable to the new car too?
Thanks.
Bill
Old 01-17-2007, 09:33 PM   #10062
they should be able to be used on the new car since in the pics thay are using the same suspension components..
Old 01-18-2007, 01:01 AM   #10063
thought i would show you all what i just got done making for my car... look at the bulkheads.. = length.. the pic sucks though sorry....
Old 01-18-2007, 07:54 AM   #10064
Still Bill's Avatar
Huh? Picture is too lacking...
Old 01-18-2007, 08:00 AM   #10065
well just look at the bulkhead on the right side of the car you will notice that it is the same length as the bulkhead that the motor mounts to. and i had to cut down the topdeck to get it to fit. so it has a short topdeck and equal flex. kind of like the new phi....
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
