Old 01-01-2007, 04:43 PM   #9946
Trader Rating: 244 (99%+)
Ok, I tried getting the center post steering to fit all day. I cant get the ball cups in the center to stop rubbing. Any suggestions?
Fred Perkins is offline   Reply With Quote
Old 01-01-2007, 05:47 PM   #9947
Trader Rating: 8 (90%+)
I had to sand a little bit off of each on the inside and that was using regular associated ball cups.
Johnny Carey is offline   Reply With Quote
Old 01-01-2007, 08:57 PM   #9948
Still Bill's Avatar
After talking with Johnny at the IIC, I ended up using a small rat tail file to elongate the holes away from each other. Used the standard RDX ball cups because they had the best amount of clearance.
You also will want to file about 1/8" off the standard steering post (end that will attach to the new topdeck) in order to get some clearance for the screw at the other end of the post. Otherwise, you need to get an Assassin steering post (it is shorter).
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-02-2007, 09:55 PM   #9949
brian cox's Avatar
Trader Rating: 58 (100%+)
what parts break on this car? generally on a carpet track...
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 01-02-2007, 10:30 PM   #9950
Still Bill's Avatar
If you have the Specialized bumper system (foam and Kydex), you likely will only occasionally break a rear arm on an RDX.
Depending on what class(es) you run, you should maintain an inventory of the plastic "blades" that go on the ends (inner) of the dogbones. In general, blades may last 3-5 runs in mod and 10-15 runs in stock.
Old 01-02-2007, 11:05 PM   #9951
Bill, my blades have lasted forever. At least since the reedy race.
Juan Aveytia is offline   Reply With Quote
Old 01-02-2007, 11:12 PM   #9952
Still Bill's Avatar
Default Blades
OK, I should further qualify my statement then. Plastic blades on diffs last far longer than blades on spools. Blades on one-ways are somewhere in the middle.
Oh, and that front blades wear out faster than rears. How's that?
Good news...Blades are cheap.
Old 01-03-2007, 02:06 PM   #9953
Hello everyone,
Has anyone used the Xray c-clip (as talked about in previous pages) in a diff rebuild? If so, is it the same quality as the Specialized or Corally c-clip? Anything else I should know about them?
Also, Can anyone confirm that the "STEEL" oneway outdrives are #79169? It's not very clear on the corally site.
Cheerz
Obsidian is offline   Reply With Quote
Old 01-03-2007, 02:27 PM   #9954
Jeff Brown's Avatar
Originally Posted by Obsidian
Hello everyone,
Cheerz
Yes, the steel outdrives for the one-way are 79169.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-03-2007, 03:06 PM   #9955
Originally Posted by RC Old Man
Any one have a Carpet/Rubber Tire setup with the new chassis "2006 spec" and new upper deck?
Any one?
Old 01-03-2007, 03:08 PM   #9956
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
You thinking of running rubber with us this week Fred?
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 01-03-2007, 03:19 PM   #9957
Wont be this week but, yes I am sick of foam tires!!
I can drive rubber tires just can never get ist right on foams.
Old 01-03-2007, 04:40 PM   #9958
Jeff Brown's Avatar
Any one?
Honestly, I don't think the chassis setup would change much. You would just see more overall grip. If you are in low to medium bite I would put it on.
Jeff
Old 01-03-2007, 06:10 PM   #9959
Jeff
Ok? A starting point for setup?
Old 01-03-2007, 07:47 PM   #9960
CRASH's Avatar
Trader Rating: 26 (100%+)
YGPM
Later,
CRASH is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
