Old 12-24-2006, 08:37 PM   #9871
nexxus's Avatar
Trader Rating: 302 (100%+)
Ok wondering if someone can help me, just bought a second hand RDX. the rear diff felt VERY gritty, I pulled it apart and regreased the diff balls (talk about bone dry) now when reassembled, no matter how loose or tight the diff is, it's still a bit gritty and I can detect some slip at almost any tension level.
What should I be looking for to fix this?
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-24-2006, 08:56 PM   #9872
Still Bill's Avatar
Check the thrust bearing too.
Change the diff balls and rings.
Does it have the updated bolt with the shoulder?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-25-2006, 12:04 AM   #9873
syndr0me's Avatar
Trader Rating: 32 (100%+)
In addition to the above suggestions, replace the snap ring that holds the thrust bearing in. I believe Specialized RC (Corally USA's aftermarket brand) offers an updated version. A big portion of diff issues can be traced back to a bent or improperly seated snap ring.
syndr0me is offline   Reply With Quote
Old 12-25-2006, 12:05 AM   #9874
syndr0me's Avatar
Check out this guide on how to build diffs, too, it's excellent.
http://www.corallyusa.com/2005/diffs.htm
Old 12-25-2006, 06:34 AM   #9875
Question to all you that have purchased the new style front and rear arms. Has anyone had to file the openings that fit the hubs? I've found that with the hard thickness arms (35)I've had to file the openings to fit the hub. The website said they've got "High precision production and super tight tolerances". I don't mind the extra work but just wondering if I got an old batch or something.
Electro-MAX RC is offline   Reply With Quote
Old 12-25-2006, 06:36 AM   #9876
Trader Rating: 244 (99%+)
The most over looked peice in a diff is the thrust bearing. Replace it! and all problems will be solved!
Fred Perkins is offline   Reply With Quote
Old 12-25-2006, 07:27 AM   #9877
Trader Rating: 45 (100%+)
Yep, had to do the same thing. Probably better to have them tighter to begin with, then you don't have to shim the play out.
Apex is offline   Reply With Quote
Old 12-25-2006, 11:04 AM   #9878
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
yeah i just had the same problem with my diff a few days ago. i put in a whole new thrust bearing and it was good as new. the diff would loosen and tighten during runs and feel tight in certian spots while spinning the outdrives. i overlooked thinking that it was the thrust bearing and after rebiulding it twice with the same results i decided to change the thrust bearing and that was the problem all along.
btw.. i just got one of those delrin spools and those things are trick... very nice kudo's to corally..
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 12-25-2006, 12:04 PM   #9879
btw.. i just got one of those delrin spools and those things are trick... very nice kudo's to corally..[/QUOTE]
Nice , but don't use it if your running on a track that's hard on cars. You'll be replacing it quickly.
Juan Aveytia is offline   Reply With Quote
Old 12-25-2006, 12:24 PM   #9880
my track isnt to bad.. why do the outdrives shatter or something?
Old 12-25-2006, 01:24 PM   #9881
Still Bill's Avatar
Jeff,
A nice Xmas present would be an updated Setup Sheet for our RDXs.
Merry Christmas.
Bill
Old 12-25-2006, 02:51 PM   #9882
Originally Posted by Still Bill
Jeff,
Merry Christmas.
Bill
Yeah- a rubber tire,low traction setup
outlandr91 is offline   Reply With Quote
Old 12-26-2006, 06:14 AM   #9883
OllieRDX's Avatar
Send a message via MSN to OllieRDX
If you need rubber setups on asphalt carpet with low med or high traction pm me your email and what kind of setup you need! I'll send the setup sheet to you as fast as i can!
Greetings Ollie
| Team Corally | GM Racing | SpeedTech RC Germany | Toni Sport | MobGums | XXX Racing Shop | Black Art | Futaba | Loomans Distribution |
OllieRDX is offline   Reply With Quote
Old 12-26-2006, 10:16 AM   #9884
Send a message via MSN to _RDX_
maybee a dum question, but with spool how often do you change the blades?
I drive 4-5, 5minutes race and then it's time to chnage, anybody with the same problem?
Daniel
| Corally RDX Phi'09 | Sanwa M11 | Nosram |
_RDX_ is offline   Reply With Quote
Old 12-26-2006, 10:24 AM   #9885
OllieRDX's Avatar
Daniel
With the Alu spool yeah i even drive 2*5min runs because of the mod classe Brushless or 7T motors!
But i drive with the Delrin spool and i drive about 10 or 15 times 5+min and the blades are still good but not optimal!
Greetings Ollie
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
