Old 11-29-2006, 03:04 PM   #9721
Jeff Brown's Avatar
Originally Posted by syndr0me
You should do a setup sheet, man, the page is in need of a fresh carpet setup. It sounds like things have evolved a bit since last year.
I'll be working on setups from the race. I have a couple from drivers and need some more and will work on getting them up. Yeah, there have been a few setup changes.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 11-29-2006, 03:25 PM   #9722
syndr0me's Avatar
Trader Rating: 32 (100%+)
I checked the threads on all of them, and they don't seem to be cross-threaded. They're not locked down, just much tighter than they used to be, and tend to unscrew the shock body from the cap if I'm not real careful. I cleaned the threads and the collars, and even tried oiling the rings inside them, and they're still tight. My car is about two years old now, too.
Maybe the rubber rings have dried out? Or maybe I got motor cleaner on them and made them swell? I dunno, weird stuff. I guess I could cut the rings out of them and see if they're any easier. Does wax work as a thread lube?
The rings seem to be sold as a separate part, but I don't know if they're still offered, the Corally store says the part is no longer available. I couldn't find an option to buy just the collars. I don't wanna buy new shocks! :-D
syndr0me is offline   Reply With Quote
Old 11-29-2006, 03:28 PM   #9723
syndr0me's Avatar
Jeff
Cool, thanks Jeff. We've got a few locals buying up used RDX's (best deal in town) and switching from their T2's and T2R's. A lot of them are coming with new parts, and they're asking about setups.
Old 12-02-2006, 03:32 PM   #9724
rcgen's Avatar
Is anyone experiencing the pins getting lose enough to were the universals is locked up? My right fronts seems to be the only problem. I've replaced the pin and setscrew and locktight but still manages to slip every two to four races.
rcgen is offline   Reply With Quote
Old 12-02-2006, 05:32 PM   #9725
Suspended
everyone should get a xray. rdx's suck, and they dont even have steering. HAHA
CHEESE CRACKER is offline   Reply With Quote
Old 12-02-2006, 05:41 PM   #9726
tmaxxking's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to tmaxxking
Default .
figured i would add to your useless post you must have missed the bus that morning
FEEDBACK LINK
rctech.net/forum/showthread.php?t=106423
tmaxxking is offline   Reply With Quote
Old 12-02-2006, 05:42 PM   #9727
rc_bam226's Avatar
rc_bam226 is offline   Reply With Quote
Old 12-02-2006, 05:44 PM   #9728
FreqETag's Avatar
/ban
FreqETag is offline   Reply With Quote
Old 12-02-2006, 05:47 PM   #9729
tmaxxking's Avatar
Default .
all 11 post's made by this toolbox are helpful to no one
check out the mini cooper thread and the jrxs
FEEDBACK LINK
Old 12-02-2006, 10:01 PM   #9730
rcmike's Avatar
Trader Rating: 40 (100%+)
Any advice on Nice to have or Needed Hop ups for the RDX if run on carpet for someone that is thinking of getting one? Thanks
rcmike is offline   Reply With Quote
Old 12-02-2006, 10:11 PM   #9731
Trader Rating: 21 (100%+)
rcgen-You can try grinding a small notch on the pin where the setscrew sits. Make it just big enough for the setscrew to have a flat surface.This should keep it tight.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 12-02-2006, 10:58 PM   #9732
rc_bam226's Avatar
Check out the carpet setups from www.corallyusa.com, and definitely get the lowered shock tower for the front especially for carpet racing. Anyone else care to chime in?
Old 12-02-2006, 11:45 PM   #9733
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
along with the front lowered tower i would get the x-long arm extensions. 4.0mm chassis and 3.4mm top deck. x-low roll center blocks also. these are what i have on mine and it rocks..
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 12-03-2006, 10:35 AM   #9734
Jimmy Morris's Avatar
Just remember if you get the lowered tower, you have to cut 3mil off your shock shafts and shock bottoms.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 12-03-2006, 11:27 AM   #9735
Mr. McGoo's Avatar
Mike,
Here is a list of what I would recommend that is a MUST -
- Specialized RC Kydex Bumper Set
- Lowered Shock tower (running on carpet)
---You will need to take 3mm off of the shock piston to make this work
- Team Tamale shock tower braces
- Black spring set
- Specialized RC Extra long shock extension (or new arms that have xtra long placement built in arms)
Here is a list of nice but not necessary-
- Low roll center blocks
- Aluminum steering blocks (i would HIGHLY recommend these)
- Offset Motor mount (i like it - but really not necessary)
- 6 degree C-hubs - nice for testing setups - but I hardly run them at all - i like 4 degree best
Miscellaneous stuff -
- 4mm chassis - you won't need this for Mike's - we don't have enough traction - it makes the car too stiff, but if you ever do go to a big race where there is lots of traction - this is nice, but once again not necessary
I have 2 RDX's - one for me - one for the wife - her's is basically box stock besides - low roll centers, bumper set, & shock tower. I can run just as fast with hers as I can with mine - which basically has about every upgrade i can put on there.
If you have any more questions - feel free to shoot me a pm on here or mikes - can't wait to see another RDX running at Mikes - you can't go wrong...
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
