Old 11-03-2006, 01:35 PM   #9556
rayhuang's Avatar
Originally Posted by syndr0me
Right now I've got every Corally weight I own loaded up on there double tall, and I'm still about two ounces light. We're starting to enforce a 51oz. weight rule in the 4300/LiPo class, so I'll have to figure something out.
not to impose on fastlane Syndr0me, but why arent they lowering the weight for lip0/4300 class and have better handling cars that are less prone to breaking (due to being 4 oz lighter??) Just curious-not arguing.
or is it due to needing to get corner weights more equal?
Ray
Old 11-03-2006, 01:37 PM   #9557
Jeff Brown's Avatar
Originally Posted by or8ital
Wow, that was fast! Already in the works or did you get it together in just a couple of days?
In stock and ready for shipping.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 11-03-2006, 01:39 PM   #9558
Jeff
Another example of Corally listening to their customers... keep it up guys!
duckman996 is offline   Reply With Quote
Old 11-03-2006, 01:42 PM   #9559
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
for what it's worth, the halloween classic, cleveland champs, and the roar carpet nationals are all at 50oz, with transponder.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-03-2006, 01:48 PM   #9560
Suspended
McSmooth's Avatar
Cool
Jeff
Do I get a free pack as my consulting fee?
McSmooth is offline   Reply With Quote
Old 11-03-2006, 02:12 PM   #9561
Trader Rating: 198 (100%+)
I have had an RDX for about a month now and I have never been this impressed with support. And the way CorallyUSA listens to it's customers.
Great job keep it up.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 11-03-2006, 02:22 PM   #9562
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
can anyone give me some help on makin my rdx fast in oval? its not that big of a track but the problem is the car rolls over and bites way to hard on the right side tires...
im runing foam tires as of right now with the hardest spring on the right front the second hardest rr and second hardest on the lf then the 3rd hardest on the lr.. Silver springs from corally..
bsr foams are what im runing with xxpink/purple all the way around thanks guys
o and im not runing a sway bar on the front nor the rear
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 11-03-2006, 02:27 PM   #9563
Trader Rating: 18 (100%+)
Jeff
Ack!!! I missed it by one day.....
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-03-2006, 02:55 PM   #9564
rc_bam226's Avatar
Don't worry, you'll find a buyer for the C-clips you purchased.
rc_bam226 is offline   Reply With Quote
Old 11-03-2006, 03:27 PM   #9565
syndr0me's Avatar
Trader Rating: 32 (100%+)
Ray
Oh, some of the guys are still running NiMH, so we wanted to make it "fair." I imagine once pretty much everybody is doing LiPo we can convince them to drop that rule.
The 50oz rule at the big races is interesting, I'll bring that up.
syndr0me is offline   Reply With Quote
Old 11-03-2006, 05:03 PM   #9566
The biggest change to 'normal' setups that I witnessed and started using at the Halloween Classic is that alot of people were running Magenta/Double Pink tires front and rear. This worked really good in 19T and Mod, but some really fast people in Stock were also running this tire setup.
Stealth_RT is offline   Reply With Quote
Old 11-03-2006, 07:51 PM   #9567
Fervidsea's Avatar
Can some help me understand the difference with these parts?
79295 Rear Uprights
79296 Rear Uprights - 2 Deg
79297 Rear Uprights - 2 Deg
79298 Rear Uprights (1 Pc) - Duraluminium NARROW - 0 deg
79299 Rear Uprights (1 Pc) - Dural. 2 HOLE NARROW - 0 deg
Why is one better than the other, etc? I run on asphalt and currently use the 79298 Narrow 0 Deg. Is that right?
Also, 79238 RDX LOWERED Shock Tower (Front/Rear), what does the lowered shock tower do for the car? What needs to be done to run the lowered ones?
Sorry if this is vague, Just trying to learn more about the car, instead of just running it not knowing. Any information will be useful.
Fervidsea is offline   Reply With Quote
Old 11-03-2006, 08:05 PM   #9568
shaggster's Avatar
The lowered shock tower will let you mount your body lower in the front. When I got my car(used) it had already had the front shock shafts cut for the lowered tower so I am not sure how far they need to be cut.
Hope this helps!
-Shaggy
Shaggadellic Paints
shaggster is offline   Reply With Quote
Old 11-03-2006, 08:11 PM   #9569
Jimmy Morris's Avatar
Cut 3 mil off the shock shaft and 3 mil off the shock bottom.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 11-03-2006, 08:12 PM   #9570
The uprights are actually pretty easy to understand.
1) There are the kit ones.
2) 2 deg uprights that put the toe at the upright instead of with shims on the bulkhead.
3) There are narrow ones that help make tech, like a 1mm narrower for an overall of 2mm for your trackwidth.
4) There are new ones that have a 2nd hole for the hingepin. They change how the rear of the car rolls with the hingepin in a wider pivot point. I personally liked these the best for asphalt.
later
Mike Dobbs
barnacle is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
