Old 10-30-2006, 11:01 PM   #9511
Still Bill's Avatar
Originally Posted by Advil
Put the thick topdeck on for NorCal Bill.
Wait! You had the thick 3.4 topdeck on the 2.4 chassis plate????
Geeze! That does not compute Will Robinson!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-30-2006, 11:20 PM   #9512
Still Bill's Avatar
Originally Posted by HarshGuy
Doing it that way, the screw part of the stud hits the top deck, a different servo saver (one not as "wide") would definitely take care of that ...I'll probably leave it as is as it seems to work ok (at lease on the bench LOL) .
I forgot to say that I am using the new narrow servo posts with my setup. These posts give just enough room to keep the servo saver arm and related hardware away from the top deck.
Old 10-31-2006, 08:03 AM   #9513
Trader Rating: 38 (100%+)
Originally Posted by Jeff Brown
Regarding shocks...........
First off shock bladders are really affected by motor spray so do not spray them down when rebuilding or new ones. Once you fill the shock with oil, almost to the top, put the bladder in. Now make sure the piston is near the top which will help seal the shock. Once the bladder is in it will kind of drop in and start to seal. Use the backside of an xacto knife to push it into the shock body slowly.
Once this is done, put the shock cap on. This includes the aluminum and plastic piece. When putting the cap on and tightening, do no grip the plastic part. Only twist on the aluminum otherwise you run the risk of breaking the seal the bladder has created.
Hope this helps. The corally shocks are excellent. Just have a bit of patience. Usually the shockcaps is what causes the issues.
Jeff
Great info Jeff! Can we get a similar write up on proper diff building techniques?
or8ital is offline   Reply With Quote
Old 10-31-2006, 08:10 AM   #9514
Trader Rating: 198 (100%+)
Tim, what diff problems are you having? I have not had any problems yet and have built a few of them now.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 10-31-2006, 08:38 AM   #9515
Well I just wanna see how the pros build it. The only problems Ive had is a clicking which is usually a bent circlip or broken diff screws which not sure what causes that. I had the most silky smooth diff on Sunday and broke the screw in it.
Old 10-31-2006, 09:56 AM   #9516
Are you using the newer screw? As I understand the new one is a 2mm caphead screw. Not the slotted screw.
www.donatelife.net
Old 10-31-2006, 10:06 AM   #9517
Trader Rating: 18 (100%+)
Doesn't matter if it computes or not.....it WORKS!!!
Clicking noise in the diff and most diff problems are a bent circlip. Every time I have a diff doing "funny" stuff I just rebuild it and put in a new circlip. Problems have been fixed almost every time. Tell me this, if you look into the end of the diff with the screw head, when you rotate the diff does the screw head wobble back and forth? If it does, then you have a bent circlip.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 10-31-2006, 10:15 AM   #9518
Im using the screw that is not threaded all the way up but has a slotted screw. Is there another new diff screw??
Old 10-31-2006, 10:16 AM   #9519
Anyway I still wanna see a write up on how the pros do it. Like which lubes do they use, how much, how far do they tighten the diff screw, etc.
Old 10-31-2006, 10:17 AM   #9520
syndr0me's Avatar
Trader Rating: 32 (100%+)
Using the Corally diff grease really helped the diffs a lot, as well as not using too much of it. I've had good luck with the MuchMore thrust grease as well.
Bent circlips have been the bane of my diffs, too. I'm real gentle with them now, and that seems to help. Replace those cone washers regularly and your diffs will treat you right.
syndr0me is offline   Reply With Quote
Old 10-31-2006, 11:09 AM   #9521
Tim throw that old diff screw away. the newer one is a cap screw and has threads all the way up.
www.donatelife.net
Old 10-31-2006, 11:17 AM   #9522
Are you sure of that? This is the first Ive heard of that.
Old 10-31-2006, 11:33 AM   #9523
syndr0me's Avatar
Default Diff Screw FAQ
http://www.rctech.net/forum/showpost...postcount=6210
Old 10-31-2006, 11:39 AM   #9524
Originally Posted by syndr0me
Thats what I thought. Had never heard of a different one. Kevin, are you sure yours arent from a different car?
Old 10-31-2006, 11:43 AM   #9525
rayhuang's Avatar
I just built a brand new kit and ordered a few diff kits and they all were screw head type with a shank. No cap head screws.
The keys to the perfect RDX diff are the circlip and carbide or ceramic diff balls. if your diff builds funny-(wont lock the diff or feels mushy, but still loose) then open it up and I bet you'll find metal shavings on the clip-toss it and put in a new one!! dont try and flatten the clip or widen it, etc.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
