Old 10-24-2006, 09:41 AM   #9466
rayhuang's Avatar
Originally Posted by syndr0me
I feel like even though I've set the turn up well, I'm waiting an eternity for the back end to square up so I can get back on the throttle.
I am using the 1.1 pistons, 30 wt oil, 22 lb spring in the regular ext on arm and all the way out on tower. Camber link in 2nd outer hole on 0-deg hub and top outside hole on shock tower. 1mm shim for toe in and narrow hex in back and car rotates fine and finishes the corner. Just a slight blip of throttle in all corners and back full.
Old 10-24-2006, 09:41 AM   #9467
rayhuang's Avatar
DOH-dbl post.
Old 10-24-2006, 09:45 AM   #9468
"The Maestro"'s Avatar
Maybe it's just me, but I hate when someone posts a pic, or has a sig that is so huge - that I have to scroll side to side on my browser window. It messes up the format for the entire page and everyone that has to view it.
Try having a little courtesy for the other 37,608 users and uncountable guests when you post.
"The Maestro" is offline   Reply With Quote
Old 10-24-2006, 09:46 AM   #9469
Trader Rating: 198 (100%+)
I have found that running the front shocks out on the front hole does not give much as a turning radius. Anyone else running the front shocks out with foams?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 10-24-2006, 12:20 PM   #9470
use jaco 5156 and 5160 tires. they're only 26mm dbl pink and dbl pink/org.
or parma tires which have less offset and stick out further
eveloso is offline   Reply With Quote
Old 10-24-2006, 11:00 PM   #9471
lazyboy's Avatar
Send a message via AIM to lazyboy
off topic, does anyone have a setup that was used in stk foam at vegas? im running on the exact same layout at my track and am new to the rdx and have been playing around with different stuff but need some refernce on this one.
any help would be great
thanks
preston
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 10-24-2006, 11:47 PM   #9472
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Preston, hit me up online, I got one for ya...
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 10-25-2006, 01:21 AM   #9473
syndr0me's Avatar
Trader Rating: 32 (100%+)
Moved the rear shocks to the "extra long" position on the new arms, switched from a G6 to the Alfa and went from 19lb to 24lb springs in the rear. The car rotated MUCH better. I picked up a lap on my fastest time, even with a few mistakes, and dropped my best lap time by .7 seconds. I still think the car has some on power push that I'd like to reduce slightly, but otherwise, it still remained very drivable and was much quicker out of the turns. Several people commented on how nice it looked on the track, which is good to hear. I feel like there's a lot more time to be squeezed out of the car, still, which is encouraging because I'm finally able to hang in there with some of the fast guys, at least for a few laps before I doink it. :-D
And off-topic, but the Spektrum will never go in my car again. The Futaba 2.4Ghz system was like night and day. I found the difference to be profound. Anybody that tells you that you can't sense a few milliseconds isn't driving with foam tires on carpet.
syndr0me is offline   Reply With Quote
Old 10-25-2006, 06:52 AM   #9474
Trader Rating: 21 (100%+)
Has anyone been able to get the new jaco 26mm foams online anywhere?
Woood is offline   Reply With Quote
Old 10-25-2006, 07:36 AM   #9475
Trader Rating: 38 (100%+)
Anyone use the Tamiya shocks on their RDX? Im having a problem b/c it comes with two pieces for the bottom of the shock and one make it too long so I cant get the ride height low enough and the other is too short so I cant get enough droop. What's the easiest/best way to fix that problem?
or8ital is offline   Reply With Quote
Old 10-25-2006, 08:39 AM   #9476
I bought 2 sets of the 26mm jacos on www.rcscrewz.com
kobiwan is offline   Reply With Quote
Old 10-25-2006, 08:41 AM   #9477
Tim, cut your front shaftes 2mm. Or use tamiya shafts. And use AE spring cups. The corrally ones are to tall. I use this and it works. I had the same problem.
I will be at WOH tonight to practice for the Classic.
www.donatelife.net
Old 10-25-2006, 08:47 AM   #9478
Robfo's Avatar
I have use Tamiya shocks for the last 14 months with no problems with droop. I use the short ends that come on the parts tree. Maybe just unscrew the ends a little more than you are already, i have my rear shcoks about 2-3mm longer than the fronts to get the correct droop for outdoors.
Robfo is offline   Reply With Quote
Old 10-25-2006, 08:58 AM   #9479
Well it is the full Tamiya shock so it comes with the Tamiya shaft. So it sounds like I need to cut them. They are too tall all around. Honestly though Im not sure 2mm would reduce the ride height enough though. Maybe I will try the HPI shock ends on the bottom and see if that does it. If I remember correctly they seem to be in-between the 2 Tamiya sizes.
If that doesnt work I will try the shorter ends and unscrew them a bit.
Old 10-25-2006, 09:25 AM   #9480
The HPI cups are perfect. They actually fit better than the AE ones.
www.donatelife.net
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
