Old 10-13-2006, 04:22 PM   #9376
Trader Rating: 18 (100%+)
Originally Posted by Jeff Brown
I will try and get the website updated with all the items on the RDX Parts list. We leave for iHobby Expo tuesday so not much time left. None of the items will arrive until the week after the Expo.
At the moment we do not have the new chassis and stiffner plate coming in.
Jeff
And you thought you had this weekend off........
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 10-14-2006, 10:50 AM   #9377
rayhuang's Avatar
Great night running my RDX one-way car on carpet. Ran against all the foam cars and lapped within 0.5 to 1.3 seconds of them.
I started with a PF Mazda 6 and car was ultra smooth. I then put on the Parma Type M and car had a slight off feeling mid corner so I went one longer on rear camber link and car was faster.
I then took off my RP30's (well used) and went to CS27's (Brand new) and car pushed the rest of the night. My fastest lap on RP30's was a 12.2 backed with a bunch of 12.3's finishing on 12.5. ON the CS27's I dropped to 12.5's backed with 12.7's finishing on 13.2's. Seemed like the RP's finshed stronger too.
Any thoughts from you rubber gurus? Maybe the CS27's need s lightly different set-up than RP's to get the max out of them?
Ray
Old 10-14-2006, 03:07 PM   #9378
protc3's Avatar
ray,
RP's are just faster tires.they dont last as long as the CS 27's
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-14-2006, 07:18 PM   #9379
Customworksking's Avatar
Trader Rating: 73 (100%+)
Arrow spool for rdx
eBay Listing Confirmed: Corally RDX Spool clean (290039001020)
selling a spool for an rdx if your looking 1.00
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-14-2006, 08:33 PM   #9380
rayhuang's Avatar
Originally Posted by protc3
ray,
Thanks-I wasnt sure if it was a significant difference, but I think it was by the lap times. No harder to drive-just felt like everything happened slower.
Old 10-14-2006, 10:09 PM   #9381
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Here was my final solution. I tried heating it, I tried the wrench idea, I even tried a screw extractor. No luck with any of them. I will have to wait and se if the hub is weakened too much by the slit. The only other solution was to buy a new hub anyway so ntohing lost by trying.
Old 10-15-2006, 12:09 AM   #9382
syndr0me's Avatar
Trader Rating: 32 (100%+)
Ran the car with the new Orion 3200 LiPo tonight. It's a little narrow for the battery slots and wants to slide around, so I put two thin rubber o-rings between the battery strap and the top of the pack to put a little extra pressure on it. It stayed in place all night, no problem. I won all four races, and didn't hit much of anything aside from a good whack on the battery side (hit a wall) when I went too hot into a corner. The battery stayed in its spot just fine.
I went double tall with 8 gram weights all over the car and I'm still only at 48oz. I guess I have stick weights to the strap.
syndr0me is offline   Reply With Quote
Old 10-15-2006, 06:09 AM   #9383
protc3's Avatar
no problem dude.i found that out by doing back to back tests with new tires.RP's were good for .02 per lap up front
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-16-2006, 09:37 AM   #9384
syndr0me's Avatar
One thing I notice when running the setups from the big races is that my car seems like it's too stuck in the rear. I don't want to slide around turns or anything, but when I watch videos from the big races, it seems like the back side of the car is constantly trying to catch up to the front. I imagine this is what people talk about when they say they're trying to "free up" the rear of the car.
Maybe it's because I'm not carrying as much corner speed as those guys (yet), but my car doesn't do that. We have a fast, sweeping turn, and I feel like the car is digging in too hard in the back, and not allowing it to rotate as easily as it should. Maybe it's just the nature of the turn, I dunno.
I suppose I'll consult my XXX-Main setup book and try some things to reduce traction in the rear just a bit. Problem is, I have plenty of steering, so taking traction away from the back will give me more than I need in the front. I guess it's also possible that my G6 body (I got a few painted, trying to burn through them in the club before going back to a DNA or Alpha) could be the culprit, but I have a hard time believing the body is the only culprit, it seems like such a minor thing compared to actual setup.
Old 10-16-2006, 10:05 AM   #9385
HarshGuy's Avatar
Originally Posted by Still Bill
Jeff,
Do you have any instructions for installing the new center steering on my RDX? Picked up all the required parts from Shane's store at the IIC.
Planning to use it for TC Stock Rubber racing at Stockton; but, not totally sure it is best suited to a rubber setup.
Thanks.
I've got both mine ready to try out at Stockton this weekend. Other than the instructions already found on this thread I had to:
  • Cut the top of the servo link ball cup to clear the sway bar mount (see red arrow in pic below) and
  • Dremmel a little off each end of the steering linkage ball cups (see purple arrow in pic below)
  • Since I am running the 4 mm chassis I also had to dremmel off some material so I could mount the servo (see green arrow in pic below)
  • Since I am running the offset motor mount, I had to dremmel off some of the material to clear the motor mount (see yellow arrow)
  • And I also had to dremmel out some material so I could loosen the battery brace rear screw (see white arrow)
Oh and for those that were asking, once installed and using hudy guages *full lock* the inner wheel is at 28 degrees, outer at 16 degrees ...I'm not sure how to "figure out" ackerman from that.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 10-16-2006, 10:33 AM   #9386
Trader Rating: 21 (100%+)
Syndrome,
You might want to try and run more droop (uptravel) in the rear to help the car pivot in the middle of the turn (free up the rear end). This will not add alot of steering at corner entry, but let the car transfer more weight to the front of the car (in the middle of the turn).
Also from what I have seen and heard, the DNA turns in harder compared to the alpha, but provides a more stable feel.
Are you running the narrow hubs on the rear? I think that will help free the car up some also.
Woood is offline   Reply With Quote
Old 10-16-2006, 12:14 PM   #9387
Harsh,
The Ackerman angle is the difference in steering angle between the two wheels. In this case it is 12 degrees. In the normal steering setup we have the option on 0,3, and 6 degrees. Thanks for your help!
Remind me to throw you a fender next time we are on the track together...
Old 10-16-2006, 12:17 PM   #9388
HarshGuy's Avatar
Originally Posted by Advil
Harsh,
So what does that mean? i.e. 12 degrees = snow plow or wild 'n wiggly?
Old 10-16-2006, 12:25 PM   #9389
I have been told that the new steering setup will give us more steering overall. I did not test it this weekend but I will let you know how it works out after this Saturday. This is on rubber tires. I have also been told that the Foam tire guys are seeing less wear with this setup.....
P.S. Ask Clint if he will look up the next time I say, "Don't look up, Crack Kills!" LOL
Old 10-16-2006, 12:26 PM   #9390
HarshGuy's Avatar
Harsh,
¿Que?
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
