Old 10-08-2006, 11:11 PM   #9316
Originally Posted by Kropy
Get a job!!!!!!!
LOL -
duckman996 is offline   Reply With Quote
Old 10-09-2006, 06:27 PM   #9317
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Quick question? On setting droop, using Jason E set up for IIC droop is said to be at7mm, but reading in this thread someone said they are setting the up travel/ which way do I does this? I'm have a 7mm block and was going too set the tires where they just started too come off the ground is this an ok way? or set the arms at 7mm with droop gauge?
mdwaeracer is offline   Reply With Quote
Old 10-09-2006, 06:49 PM   #9318
Big Rigg's Avatar
It was 7mm on a droop guage (yes, barely any uptravel at all)... with the slightly lower overall traction this year it was between 6 and 5. Hope this helps
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 10-10-2006, 04:44 AM   #9319
Trader Rating: 45 (100%+)
Originally Posted by TeamPink91
Check it out guys. New top deck on there with the center link steering...
This question is for anyone who has the new topdeck with centerpoint steering. Have you noticed a difference in corner speed and tire wear?
Apex is offline   Reply With Quote
Old 10-10-2006, 06:13 AM   #9320
Originally Posted by Cookie
I raced with the new top deck and center point steering last Saturday and found that it increased the mid corner steering and car rotation quite significantly. I found it required less steering input for same amount of turning which then also provides the increased steering when required.
Overall it just felt like the car wanted to keep turning around the apex whereas previously it would wash out and understeer across the apex until extra speed was scrubbed off.
You could try checking the thread before asking.
Cheers
Peter
Pedro 51 is offline   Reply With Quote
Old 10-10-2006, 06:34 AM   #9321
Cheers
Peter
I really don't have the time to read through the thread. Thanks for finding this!! Please post if you find more.
Old 10-10-2006, 03:01 PM   #9322
Default Basic Carpet Setup
Advice please - After many years I am just switching from low grip asphalt to carpet - What is the best basic setup for the RDX.
Diff - Ball, One way or Spool?
Shocks - Pistons and oil?
Springs -
Roll Bars -
Camber -
Roll centres -
I knows there are some setups posted on the Corally sites but they are for the top drivers and they vary, I would just like a starting point.
SagaMike is offline   Reply With Quote
Old 10-10-2006, 06:17 PM   #9323
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Springs -
Roll Bars -
Camber -
Roll centres -
Honestly any of the posted setups ARE a good starting point for carpet. But just to be clear
60 F 40R oil Associated
Ball diff at both ends
no roll bars
lowest roll block positions
1.5* camber alll the way around
The only thing that might vary is the springs and thats just becasue of differtent arms and different length rear shock extensions. Fronts are almost aslways 33 lbs. Rears vary betwen 19 and 26 depending on the above. : )
Old 10-10-2006, 06:23 PM   #9324
Big Rigg's Avatar
Springs -
Roll Bars -
Camber -
Roll centres -
For rubber tires:
Diff - One way
Shocks - 1.1 pistons, 50 front/30 rear
Springs - 22 front/17 rear
Roll Bars - front, but only if there's a ton of grip
Camber - 1 deg
Roll centres - std blocks in low position (hole down)
For foamies dual diff and way stiffer springs are the norm... but I'll let someone who's run it more than 2wice clue you in here
hope this helps
-Heywood Jablome
Old 10-10-2006, 08:12 PM   #9325
I had a bad bearing in my rear hub. So I took it all apart and the bearing fell out as I removed the CVD. All of it that is EXCEPT the outer race which remained STUCK in the rear upright. I have already tried the obvious "push it out" but the thickness of the race is still thinner than the machined lip in the upright. I can't get a dremel in there without cutting up the hub pretty bad. A picture's worth a thousand words as they say . . .
Any ideas on how to remove it?
Old 10-10-2006, 08:28 PM   #9326
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
hey andrew... you might try heating it up. the alum will expand faster and larger than the steel, maybe giving you enough room to get it out w/o damage...
im still looking for that setup i had, just havent found it yet!
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-10-2006, 08:36 PM   #9327
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Andrew dont heat it up . If you have the corally tool set,,,, one of the nut drivers will fit right in that rear hub with the bearings outer piece stuck in it. Push the nut driver in there and give it a nice twist and then pull it out and out she will come.
wallstreet is offline   Reply With Quote
Old 10-10-2006, 08:53 PM   #9328
Wes
I had thought of that Wes . . .any idea whether it will weaken the aluminum? Just LMK when you come up with the set-up. I'm up a creek till I can get some help. It was like driving on ice . . I think it must be the carpet at Mikes because by all accounts the setups posted on the Corally site ought to get me in the ball park.
Old 10-10-2006, 09:25 PM   #9329
Turbonium's Avatar
i wouldnt think it needs to get that hot to achieve the goal... Wallstreets idea might work as well, if the bearing race isnt too tight a fit in the hub. some are, some arent.
something that just came to mind on your setup... are you running the ultra low roll blocks, or the std ones?
Wes
Team Novak
Old 10-10-2006, 11:03 PM   #9330
syndr0me's Avatar
Trader Rating: 32 (100%+)
I had the same thing happen. I was able to tap it out from the backside by getting a flathead screwdriver in there and slowly and carefully banging away at it.
syndr0me is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
