Team Corally RDX Touring Car >
Old 10-04-2006, 06:07 PM
  #9286
Big Rigg's Avatar
Originally Posted by mdwaeracer
I have 2 questions for Jason E.
1. On your 05 IIC set up you used the 3.9 chassis correct? How much difference would there be if using the carpet spec 3.4 chassis.
2. How much difference will there be running a front diff instead of the spool?
Thanks mike
A1: At the IIC I ran the identical setup as Jason with the only difference being the lower chassis, he had the specialized thick chassis and I had the medium 'stock' thickness... both cars were great, I'd have to say that mine was super stuck from the get go and developed a very slight push by the last day... his seemed to just get better and better
A2: We both ran a front 1way, I've only tried a front diff with foamies, but my initial thought would be that it would push coming out of the corners... I've run a spool once (only because I was too lazy to change from my asphault setup) and it was wayyy hard to drive, off power going into a turn it would hook around the inside front tire... no good, hope this helps
Big Rigg is offline
Old 10-04-2006, 06:42 PM
  #9287
Trader Rating: 15 (100%+)
I am going to rebuild my shocks for the upcoming carpet season and was wondering if I should put the 1.1 or .9 pistons in right away or should I stay with the 1.3. The carpet is ozite and the track is 50 x 100.
If I go with the 1.1 or the .9 pistons what am I going to want to do with the shock oil and springs. Right now I was going to run Front 33lb, 60wt with the 1.3 and rear 24lb 40wt with the 1.3.
I have also included a picture of my hingepin blocks. Are these the standard or the lower ones. It is somewhat offset which you can see but it is not alot in my opinion. Thanks
FT_TC3Racer is offline
Old 10-04-2006, 07:35 PM
  #9288
Trader Rating: 9 (91%+)
standard
Johnny Carey is offline
Old 10-05-2006, 01:13 PM
  #9289
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Talking
Thx for the info Big Rigg.
mdwaeracer is offline
Old 10-05-2006, 03:29 PM
  #9290
Drcy's Avatar
Default New Corally
Originally Posted by syndr0me
That antenna thing is listed as a part for the 12X. I just thought it was interesting that it was for an updated RDX that doesn't seem to be available yet. I'm beginning to think the new/updated kit may be a lot farther along than we realize. Though, I suppose the product shot of it from a month ago made that pretty clear already. Is Corally sitting on an updated car that's ready to go, but waiting until the right time to release it? The mind boggles. :-)
I bet the new car is ready to go.
Just that the right time is allways dificult to get....perhaps X-mas sales with announcement end of this month.
I would bet and I hope
cheers
Pedro
Drcy is offline
Old 10-06-2006, 11:28 AM
  #9291
Joel Lagace's Avatar
looking for a oneway are there more then one available? Also does it include the pully, on speedtech they list a oneway but it looks to be missing one side of the pully, my car has dual diffs with white one peice pully.
PS whats with corally usa web site? On both my firefox and IE browsers i can load the page but cannot scroll down any pages.
Joel Lagace is offline
Old 10-06-2006, 11:39 AM
  #9292
rc_bam226's Avatar
There is only one one-way available. Part no. 79167. It includes a pulley, and the outdrives. The only other items to purchase are the bearing holders (79198) for the one way and the bearings for the one way (1134).
rc_bam226 is offline
Old 10-06-2006, 11:52 AM
  #9293
AH man u gotta be joking! A oneway diff with no oneway bearings? Amazing. I gotta dig around for 3 part numbers to create my oneway diff? Sorry ill stop crying
Located everything but 1134 on speedtech
Old 10-06-2006, 11:59 AM
  #9294
rayhuang's Avatar
Joel-not one way bearings, but different bearings in the bulkheads and different bearing holders. The bearings are bigger than the outdrive bearings on the diffs. On the bright side-they arent expensive.
rayhuang is offline
Old 10-06-2006, 12:03 PM
  #9295
o ok, what is the bearing size do u know? Is the 1134 a corally part number?
Old 10-06-2006, 12:04 PM
  #9296
rayhuang's Avatar
12x18 bearing and yes thats a Corally part number.
rayhuang is offline
Old 10-06-2006, 12:28 PM
  #9297
Hey, In fireforx or IE just right click the entry link and tell it to open in a new window - once its broke out of the original frame the scroll bars seem to work fine.
monstercol is offline
Old 10-06-2006, 12:31 PM
  #9298
Thanks that was easy!!
Old 10-06-2006, 03:19 PM
  #9299
mdwaeracer's Avatar
where is the pictures of the updated RDX located?
Old 10-06-2006, 04:16 PM
  #9300
syndr0me's Avatar
Trader Rating: 32 (100%+)
It was pulled from Corally's site after someone discovered it. Luckily, I'm a ninja.
syndr0me is offline
