Old 10-02-2006, 11:02 PM   #9241
Trader Rating: 15 (100%+)
Let me rephrase my question. How can I tell the two apart. I am wondering cause I think this car has the ultra low ones.
FT_TC3Racer is offline   Reply With Quote
Old 10-02-2006, 11:12 PM   #9242
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Hi I don't have the RDX but I know the ultra the hind pin hole postion is lower than the standard one....I could be wrong
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-02-2006, 11:18 PM   #9243
OVA
OVA's Avatar
Default RDX
I'm thinking about picking one up and I need to know ...Does the car performance close to the T2 X-ray.Tamiya MSX MRE, Yokomo BD??
I have not heard much about the RDX lately in the big Race
Old 10-02-2006, 11:52 PM   #9244
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
On Corally's site Jason Ertrachter has his setup from last year at Vegas running Rubber tires. IN it he uses HPI red and HPI PInk springs. I am wanting to put this set up on my car but don't have any HPI springs. So I thought "well I can either go buy the HPI springs or I can try to use the Corally springs with the same/similar spring rates." So I went over to HPI's site and found this
Part # Description Suggested Retail Price
6844 2 Pro Linear Spring 13 x 27mm (Red 238 gf/mm) 5.50/pr
6849 2 Pro Linear Spring 13 x 27mm (Pink 272 gf/mm) 5.50/pr
6754 2 Pro Linear Spring 13 x 25mm (Red 432 gf/mm) (Nitro) 6.00/pr
6759 2 Pro Linear Spring 13 x 25mm (Pink 540 gf/mm) (Nitro) 6.00/pr
6835 2 13 x 29 x 1.5mm Red (Progressive) 4.50/pr
and I see more than one listing for red springs and no spring rates that help me (anyone know the conversion from gf/mm to lbs is?). Any ideas? Perhaps Jason you could shed some light on this for me (and Mr. McGoo if I know him like I think I do )
Old 10-03-2006, 02:47 AM   #9245
Originally Posted by Jeff Brown
I believe there is new hardware coming. I will check into it for you.
Jeff
Any word yet? I am looking at using a sway with the new arms all around.
Old 10-03-2006, 04:36 AM   #9246
Trader Rating: 45 (100%+)
Originally Posted by RichO
What is the best tool to use to remove the circlip (holds thrust bearing) out of the diff hubs and where would I buy one?
I use a small round nose plier. Took it from my wife who uses it for beading.
Apex is offline   Reply With Quote
Old 10-03-2006, 09:21 AM   #9247
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Apex.. i use the similar style pliers... but on mine the nose is longer and narrower... thats pretty much the idea..
arv.
Arv.
EA MOTORSPORTS// KO PROPO// ORCA// 180 RACEWAY
RCFREAK is offline   Reply With Quote
Old 10-03-2006, 09:28 AM   #9248
I am well aware of what they do. I just don't have both of them in front of me to see a difference physically.
If some one could post a pic or please tell me. Are there markings to tell which ones are which.
Again I don't have both in front of me I have one or the other and I am trying to figure out what is on my car!
Old 10-03-2006, 09:57 AM   #9249
RCFREAK's Avatar
i ll try to explain the block... if you look at the standard from the side , the part that is mounted on the bulkhead and screwed in, is pretty straight across , (same level as the block)
the ultra low when compared from the side, the block is acutally approx. 1-1.5 mm lower than the bulkhead portion. the part for the bulkhead is definately higher than the block from the side..dropping down the hinge pin.(ultra low) basically the ultra low block mounting area sits higher/ above the block looking at it from the side..
when the ultra low is mounted on the car... there is about .5-1mm clearance from chassis to bottom of block.
the standandard shows approx. 1-1.5mm from block to chassis.
hope the helps a little...
need a pic to help clarify.... you can post pic what you got..
Arv.
Old 10-03-2006, 12:07 PM   #9250
Anyone know what shock pistons come in the US Spec RDX Kit?
Old 10-03-2006, 12:30 PM   #9251
RCFREAK's Avatar
apex... ygpm!!
Arv.
Old 10-03-2006, 12:35 PM   #9252
edseb's Avatar
I have a compiled spring chart for touring car and although the manufacturers list a certain rate in lbs. for their springs often they are far from that. In my research, I found that THard out of Europe did some spring tests which included HPI springs. Here is what they listed:
HPI Blue 15.29 lbs., Silver 16.91, Pink 17.92,
Gold 19.04, White 20.33, Red 22.41. The only thing is that they might have a different diameter. With some springs like AE or Tamiya, you'll have to turn the shock collars upside down and use retainers like Tamiya, etc. to compensate for the size. If you just want to use Corally springs, just go off the Corally chart, but remember Corally springs tend to be more progessive in their design. Hope this helps. Often the Corally team likkes to try different springs to fine tune their cars. I think Jason used HPi springs again this year, and Chris Tosolini has tried them too. I've tried AE, XRay and Tamiya springs too, like a lot of the other drivers.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 10-03-2006, 12:40 PM   #9253
edseb's Avatar
Sorry, I only know them by site, and just compare side by side.
Carl Hyndman
Old 10-03-2006, 04:25 PM   #9254
JAY_UK's Avatar
Send a message via MSN to JAY_UK
Check out the for sale thread. My RDX is up for grabs!
JAY_UK is offline   Reply With Quote
Old 10-03-2006, 05:22 PM   #9255
Send a message via AIM to ERTRACHTER
if you were going to use corally springs you would use 22 17 the hpi springs arent progressive thats why i use them
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
