Old 09-28-2006, 01:00 AM   #9166
syndr0me's Avatar
Trader Rating: 32 (100%+)
I think I finally got the RDX shocks figured out. It seems very crucial that you don't get oil on the outside of the diaphragm, or in the cap of the shock. Using new diaphragms that aren't all swollen made it a lot easier too.
syndr0me is offline   Reply With Quote
Old 09-28-2006, 02:56 AM   #9167
Hey guys what websites can u get the asphalty topdeck from?
I really want to try it out
jamie814340 is offline   Reply With Quote
Old 09-28-2006, 05:23 AM   #9168
Hey guys this is kinda urgent so if you could reply straight away that would be great.
I have broken a pin in my cvd and my lhs doesnt stock them and i need a new one but my online order doesnt come for a few days is there any other pin will fit my cvds?
Thanks in advance
Jamie
Old 09-28-2006, 05:51 AM   #9169
Static_racing's Avatar
www.speedtechrc.com
www.stormerhobbies.com
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 09-28-2006, 08:27 AM   #9170
Trader Rating: 38 (100%+)
When will the new top deck / center steering be available in the US?
or8ital is offline   Reply With Quote
Old 09-28-2006, 08:34 AM   #9171
It is available now. I got one last week.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 09-28-2006, 08:39 AM   #9172
Oh, I didnt see the part listed on Corally USA. Is it available from Corally USA? Part # 79359B right? I dont need anything else for center steering? Any online stores have it?
Also, I presume it doesnt work with the 4mm chassis?
Old 09-28-2006, 08:40 AM   #9173
Just call and order it.
Mike Dobbs
Old 09-28-2006, 08:42 AM   #9174
Jimmy Morris's Avatar
Thanks in advance
Jamie
They are regular MIP cvd's, so the pin is the same as on any other car that uses them.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 09-28-2006, 08:44 AM   #9175
Jeff Brown's Avatar
It has not been put into the system yet. They arrived as we left for Vegas.
You also need 38mm turnbuckles. The part number is 79273. The retail on the topdeck is $35.00.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 09-28-2006, 08:44 AM   #9176
You need longer turnbuckles. And if you have a regular servo it might stick out a little bit.
Old 09-28-2006, 08:53 AM   #9177
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default 4mm chassis
edit..silly question...
found the answer a few post back...
olhipster1 is offline   Reply With Quote
Old 09-28-2006, 09:06 AM   #9178
Trader Rating: 45 (100%+)
Default Question???
I notice when using Jaco Foam Tires the front tire rubs the shock which also limits the amount of steering travel. What have you done to fix this? I'm thinking about just adding spacers to space the wheel out more until the track is 190mm. Any ideas, suggestions???
Apex is offline   Reply With Quote
Old 09-28-2006, 09:10 AM   #9179
2 toe shims under each pin holder in the front. Also, how much dual rate do you have? You don't need alot, try turning it down some, so that you can make the tightest corner on the track.
Old 09-28-2006, 09:33 AM   #9180
rayhuang's Avatar
To add to Jimbo-wide hexes are standard when running Jacos. YOu should always run the RDX 190mm with foams is my experience so shim the arm mounts out as much as it takes to hit 190mm. The cars more stable and carries more corner speed the wider you make it. a 4 to 5' circle is all you should need. If your running smaller than that-then you might want to think about some set-up changes to gain steering back.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
