Old 09-21-2006, 11:57 AM   #9121
syndr0me's Avatar
Trader Rating: 32 (100%+)
Looks like Toso is running the "old" car with the new topdeck at IIC.
I think I'm going to move away from the 4mm chassis as well. For club racing, at least, it seems like too much. The car was twitchy as hell with the 4mm compared to the 2.9. It felt a lot more tame and drivable with a tiny bit of flex in there.
syndr0me is offline   Reply With Quote
Old 09-21-2006, 04:49 PM   #9122
Just bought a Carpet Spec, does the thrust bearing thats assembled in the diff half come lubed? or do I need to take it apart and lube it.
hobbyman_7 is offline   Reply With Quote
Old 09-21-2006, 04:53 PM   #9123
rc_bam226's Avatar
If you bought it new, you have to lube it. The manual suggests that you use the diff lube, but alot of fellow users here prefer Associated black grease to lube the thrust bearing.
rc_bam226 is offline   Reply With Quote
Old 09-21-2006, 04:54 PM   #9124
Thanks for the reply!
Old 09-21-2006, 07:36 PM   #9125
Trader Rating: 198 (100%+)
Also the the thrust washers are of 2 different inside diameters
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 09-21-2006, 08:25 PM   #9126
Dodgeguy - so what does that mean?
Old 09-21-2006, 08:28 PM   #9127
Trader Rating: 38 (100%+)
The two washers on either side of the thrust bearing are not the same. One has a small diameter in the center hole relative to the other. The instructions dont show this unfortunately. The smaller ones goes to the side with the diff screw head.
or8ital is offline   Reply With Quote
Old 09-22-2006, 06:28 PM   #9128
shaggster's Avatar
Originally Posted by TeamPink91
Check it out guys. New top deck on there with the center link steering...
Have you tried it out yet?
Shaggadellic Paints
shaggster is offline   Reply With Quote
Old 09-23-2006, 04:34 AM   #9129
OllieRDX's Avatar
Send a message via MSN to OllieRDX
The new topdeck is awesome just it makes the car easier to drive!
if you use the new center steering the car has less steering!
Greetings Ollie
| Team Corally | GM Racing | SpeedTech RC Germany | Toni Sport | MobGums | XXX Racing Shop | Black Art | Futaba | Loomans Distribution |
OllieRDX is offline   Reply With Quote
Old 09-23-2006, 10:18 AM   #9130
syndr0me's Avatar
Ollie, how come you're not in Vegas?
Old 09-24-2006, 09:54 AM   #9131
Heh, why would I want LESS steering by using the new steering post? I just started using Parma Indigo tires to get MORE steering with less dual rate.
Stealth_RT is offline   Reply With Quote
Old 09-24-2006, 11:36 PM   #9132
RichO's Avatar
Default Build Question - Front Diff
I have a strange issue that raises two questions.
After getting the car built, I noticed that something had changed once all of the chassis and bumper bits were screwed on. The front diff has a nasty wobble in it. I have rebuilt it a few times (and it has never been run). The wobble is bad enough that the belt chatters since the teeth are catching the side.
The docs are a little sparse when it comes to the front diff (unless I complete missing something):
1. Is the long half supposed to be on the left or right side?
2. Has anyone else had a problem with a wobble - if so, did you manage to fix it and how?
-Rich
RichO is offline   Reply With Quote
Old 09-25-2006, 05:29 AM   #9133
Nuno Gancho's Avatar
Hello, i would like your help for a set up for a wet race, i will use pit shumizu tires. What set up should i use for the rdx, i have the chassi 2,4cm normal, 2,4cm world champion collegno, and 3cm normal, and upper deck? And about the insert, and wheel. Thanks very much.
Nuno Gancho is offline   Reply With Quote
Old 09-25-2006, 05:37 AM   #9134
Robfo's Avatar
When we run in the wet in the UK we use thin Pit wets on 21mm wheels with the standard foam insert. I run my RDX with the same setup as i do in the dry and it is very good, If it is really wet try increasing the ride height a little to cut down on drag from the standing water.
Robfo is offline   Reply With Quote
Old 09-25-2006, 06:24 AM   #9135
T1Raycer's Avatar
-Rich
the long out drive of the diff should be on the rigth side of the car!! if you put the long outdrive to the left your belt gonna hit the side of the pulley!! i mad ethe same error when i built mine !!!
Later!!
T1Raycer is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
