Old 09-16-2006, 10:52 PM   #9046
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Could someone post the actual measurements of the Lunsford Ti turnbuckles used in the following locations for the RDX? I am having a problem getting the rear camber links short enough to get -2* camber. I bought the car used and it had a mix of Lunsford turnbuckles and Corally aluminum turnbuckles.
Also those using the Lunsford turnbuckles with the RPM ball cups, have you had to cut down any of the ball cups to make them work?
Front Camber Turnbuckles
Front "Tie Rod" Turnbuckles
Center steering link Turnbuckle
Servo to bellcrank turnbuckle
rear camber turnbuckles
Old 09-17-2006, 09:50 AM   #9047
hi everybody i was wondering if anyone has an rdx differential that i could buy off them
jordan
jordys jrxs is offline   Reply With Quote
Old 09-17-2006, 09:58 AM   #9048
Trader Rating: 38 (100%+)
I asked the same thing a couple times about 4 months ago and could never get an answer.
or8ital is offline   Reply With Quote
Old 09-17-2006, 10:16 AM   #9049
rc_bam226's Avatar
Let's see,
The equivalent versions are:
28mm = 1 1/8"
33mm = 1 1/4"
21mm = 1" (Fits well if you use the inner mounting points on the bell cranks)
These are +/- 1 to 1.5mm from the actual size, of all except the 21mm, which is about 5mm longer than the original. Hope this helps guys.
rc_bam226 is offline   Reply With Quote
Old 09-17-2006, 12:32 PM   #9050
syndr0me's Avatar
Trader Rating: 32 (100%+)
I have an extra used 4mm chassis that came with with a car I bought a few months ago that I'd probably let go for $60 shipped U.S. It's been sealed, and seems to be in pretty okay shape. Not doing me much good just sitting in the box.
syndr0me is offline   Reply With Quote
Old 09-17-2006, 12:32 PM   #9051
shaggster's Avatar
Hi guys I have a corally rdx 2.9mm chassis in the for sale/trade forums and here is the link:
http://www.rctech.net/forum/showthre...89#post2661189
Shaggadellic Paints
shaggster is offline   Reply With Quote
Old 09-17-2006, 12:34 PM   #9052
shaggster's Avatar
That was weird Adam.
Shaggadellic Paints
Old 09-17-2006, 02:23 PM   #9053
syndr0me's Avatar
Weird, at the same minute and everything.
Old 09-17-2006, 02:39 PM   #9054
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
good luck to the guys running corally cars in vegas. Especially the new guy on the team
wallstreet is offline   Reply With Quote
Old 09-17-2006, 02:41 PM   #9055
syndr0me's Avatar
You think the team will be running the new car at Vegas? On one hand, if so, I'll be happy to hear about how it compares. On the other hand, it means we probably won't see many updated carpet setups for the current RDX, especially with all the new parts available for it.
Old 09-17-2006, 02:50 PM   #9056
How in the world do you guys get the circlip into the diff half? I have automotice snap ring pliers but they are too big. Is there a really good way? I have tried body clip ends but can't get it to work. Its getting frustrating. Is that jsut one of things that you have to work at forever and HOPE it goes in?
Old 09-17-2006, 02:54 PM   #9057
The small Craftsmen snap ring pliers from Sears work for the circlips. The circlips are annoying. I wish there were another way.
Old 09-17-2006, 03:02 PM   #9058
TeamPink91's Avatar
Send a message via AIM to TeamPink91
I find that curved body scissors work in a pinch. No pun intended.
TeamPink91 is offline   Reply With Quote
Old 09-17-2006, 03:18 PM   #9059
really? I can't see how. No offecnse, I must just have a different pair. Mine have a blunt tip. I'll have to go check out the small craftsman pliers.
Old 09-17-2006, 03:57 PM   #9060
syndr0me's Avatar
I took a Dremel to my snap-ring pliers and ground down the tips to a point so they were small enough to fit inside the holes.
So, here's how I do it:
I put the ring on the pliers and only squeeze enough to keep it from falling off. Then, I put it flat on the diff half, press down in it with my thumb, and only squeeze the pliers enough to push it into the hole. I don't push very hard, otherwise it'll go past the notch and it's a bitch to get back out. I just get it in there, and then slowly push it down with a flathead until settles into the notch evenly.
If you try to squeeze it, inevitable it's going to shoot off of there and disappear into the dog's water bowl, or somewhere equally exciting to go fishing for it.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
