Old 09-13-2006, 04:07 PM   #9001
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default droop
thanks guys...that makes sense....guess i'll stick with the ride height measurement.
olhipster1 is offline   Reply With Quote
Old 09-13-2006, 06:28 PM   #9002
shaggster's Avatar
Originally Posted by syndr0me
I wear an RDX mask... but only to cover that stupid XRay tattoo I got when I was young and drunk. Those guys are assholes.
Shaggadellic Paints
shaggster is offline   Reply With Quote
Old 09-13-2006, 06:52 PM   #9003
Originally Posted by wide_mouth_frog
Just wondered if anyone can help.......
Im racing on a tight indoor track on Vtec24r tyres, (27t stock)
REAR
17lb
40w
2nd hole in on shock mount
kit camber possitions apart from on hub wher im on the outer
1.9 roll bar
2 degrees toe in
FRONT
19lb
60
3rd hole in on shock mount
1.9 roll bar
kick up
the car seems pretty well planted (enough to win) but on fast hairpins the front seems to bottom out on the chassis, i went up to 22lb but it still does it, other than that when the grip comes up the rear end is just was to planted for me, i need to free it up slightly but with out wrecking the rest of the handling... i thought maybe raise the inner rear camber link to the top row?
If anyone has any better suggestions, i would like to hear them
What rollcenter positions are you using, front and rear?
Try 1 deg rear toe and shorten rear camber link on tower and maybe even move to middle hole on hub (gives link more angle).
Take a look at Ertrachters setup from Vegas at Corallyusa.com
Mike Dobbs
barnacle is offline   Reply With Quote
Old 09-13-2006, 07:00 PM   #9004
RC_Woody's Avatar
Originally Posted by RC_Woody
Ok guys, I will post a pic tonight and see if anybody can see anything.
Here are some of the pics
Team Corally RDX Touring Car-frontleft.jpg   Team Corally RDX Touring Car-frontright.jpg   Team Corally RDX Touring Car-rearleft.jpg   Team Corally RDX Touring Car-rearright.jpg   Team Corally RDX Touring Car-beltclosebat.jpg
Woody
Sponsored by - My Wallet
LOSI SCTE
Tekno EB48
Home Track: Firridge Raceway, Scappoose OR
RC_Woody is offline   Reply With Quote
Old 09-13-2006, 07:02 PM   #9005
RC_Woody's Avatar
more pics
Team Corally RDX Touring Car-beltoffroll.jpg   Team Corally RDX Touring Car-driveshaft1.jpg   Team Corally RDX Touring Car-driveshaft2.jpg   Team Corally RDX Touring Car-front1.jpg   Team Corally RDX Touring Car-full.jpg
Woody
LOSI SCTE
Tekno EB48
Old 09-13-2006, 07:05 PM   #9006
RC_Woody's Avatar
Default belt flipping
If there is anything else you guys would like to see just let me know.
I really want to figure this out. Don't mind all the dirt just got back from racing last night.
Woody
Woody
LOSI SCTE
Tekno EB48
Old 09-13-2006, 07:13 PM   #9007
CHRIS CHAVEZ's Avatar
i never ran the belt tensioner and i haven't had a single problem.
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 09-13-2006, 07:19 PM   #9008
olhipster1's Avatar
Default ???
RC W
how loose are you running the belts?
long shot....but is the front belt running again the spur gear plate, looks it's favoring the inner side....if that makes any sense...
Old 09-13-2006, 07:25 PM   #9009
Big Rigg's Avatar
Woody: I think I may see a potential problem... in the pic 'driveshaft2.jpg' where you are showing the center layshaft, it is in the highest most position... I don't have my car in front of me, but I think that this will allow the front belt to be way looser than the rear belt... what I do is center this shaft then push down on both belts and adjust the shaft up or down until both belts are tensioned the same... hope this helps!!!
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 09-13-2006, 07:30 PM   #9010
Trader Rating: 38 (100%+)
Actually all the way up makes it the tightest. Is it possible it is too tight? When I have it all the way up it is really tight.
or8ital is offline   Reply With Quote
Old 09-13-2006, 07:34 PM   #9011
olhipster1's Avatar
Default curious
the belts looks loose...
but i'm just curious is anyone else running a spur gear that thick on their RDX...
input, please.
pic Front 1....the belt is leaning towards center...a bit too much..my front belt lean towards outside or stays center.
is the belt always positioned like that?
Old 09-13-2006, 07:40 PM   #9012
input, please.
You might be onto something. Wouldnt a thicker spur gear push everything over (away from where he has his belt tensioner)? My spur gear is just slightly thicker then my belt.
Old 09-13-2006, 07:43 PM   #9013
olhipster1's Avatar
possibly a combination of both...maybe..
spur gear might be too thick....and that rear belt looks mighty loose....perhaps making the front a bit too tight..not allowing a proper centering..or shifting toward outer side.
Old 09-13-2006, 07:44 PM   #9014
I think it is the spur gear. If you look the belt comes off the tensioner and kind of heads left (unless it is illusion) in that front1 picture. If you want to verify hold you car that direction. The distance between the side of my top plate and the metal piece on the left side of the spur gear is 15.67mm on my car.
Old 09-13-2006, 07:46 PM   #9015
Big Rigg's Avatar
Yea I wasn't sure which way tightend what... bummer I thought I was onto somehting there, but the thick spur also sounds like a good theory Hope you figure it out!
-Heywood Jablome
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
