Old 09-13-2006, 12:43 PM   #8986
Don't use the front tensioner location on the topdeck, the belt can wedge between the post and pulley causing it to flip or break. I think it is because of the close location to the diff pulley.
I had to shim the tensioner pulley to line the belt up properly.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 09-13-2006, 12:45 PM   #8987
RC_Woody's Avatar
Originally Posted by fastasu2
I know you said you checked to make sure sure the diffs were in the right direction, but it really sounds like they are the wrong direction which would want to make the belts slide off the tensioner and might cause the flip. But like what was said post a pic of it and maybe someone will be able to see what the problem is.
Ok guys, I will post a pic tonight and see if anybody can see anything.
Woody
Sponsored by - My Wallet
LOSI SCTE
Tekno EB48
Home Track: Firridge Raceway, Scappoose OR
RC_Woody is offline   Reply With Quote
Old 09-13-2006, 12:52 PM   #8988
You can also take the plastic pulley right off and have the belt run on the bearings... this eliminates the risk of belts getting caught. I've been running mine like that since I got the car and no troubles there.
duckman996 is offline   Reply With Quote
Old 09-13-2006, 12:59 PM   #8989
How are your front bulkheads - they maybe bent causing the diff to caulk to one side. Pull them off and check them on a flat surface. You may want to check to ensure that your bearing inserts (in the bulkheads) are not opposite each other (one in the upper position, one in the lower position).
Old 09-13-2006, 01:24 PM   #8990
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
caulk and balls?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-13-2006, 01:26 PM   #8991
He said balls!
Mike Dobbs
Old 09-13-2006, 01:26 PM   #8992
Trader Rating: 38 (100%+)
Originally Posted by seaball
caulk and balls?
Gee no wonder you have so many posts. Between making fun of peoples typing, bumping old threads about lipos, and teaching people how to search... How do you have any time left in the day?
or8ital is offline   Reply With Quote
Old 09-13-2006, 01:27 PM   #8993
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
RC_W
give us the pics ......intersting..dilemna you have there..
it's probably something really small.
ok..guys....put your RDX capes on....
olhipster1 is offline   Reply With Quote
Old 09-13-2006, 01:35 PM   #8994
syndr0me's Avatar
Trader Rating: 32 (100%+)
I wear an RDX mask... but only to cover that stupid XRay tattoo I got when I was young and drunk. Those guys are assholes.
Originally Posted by olhipster1
RC_W
syndr0me is offline   Reply With Quote
Old 09-13-2006, 02:46 PM   #8995
wide_mouth_frog's Avatar
Just wondered if anyone can help.......
Im racing on a tight indoor track on Vtec24r tyres, (27t stock)
REAR
17lb
40w
2nd hole in on shock mount
kit camber possitions apart from on hub wher im on the outer
1.9 roll bar
2 degrees toe in
FRONT
19lb
60
3rd hole in on shock mount
1.9 roll bar
kick up
the car seems pretty well planted (enough to win) but on fast hairpins the front seems to bottom out on the chassis, i went up to 22lb but it still does it, other than that when the grip comes up the rear end is just was to planted for me, i need to free it up slightly but with out wrecking the rest of the handling... i thought maybe raise the inner rear camber link to the top row?
If anyone has any better suggestions, i would like to hear them
wide_mouth_frog is offline   Reply With Quote
Old 09-13-2006, 02:53 PM   #8996
olhipster1's Avatar
Default TMI
Syndrome...TMI on your lyfstyle....
j/k
having a problem understanding droop...
is having more droop on the gauge = to a higher number 6
or the opposite more droop = 1
I'm still using my ride height gauge to adjust droop, usually 1.5 or 2 above ride height...I haven't used the droop gauge yet.
I know silly question.....for some reason I cant get it in my brain waves...here my yellow bus to pick me up....helmet please...
Old 09-13-2006, 03:30 PM   #8997
RC_Woody's Avatar
Interesting statement I'm not sure I understand. Are you talking about the little black inserts that set right in the bulkhead and hold the bearings?
Don't they only fit in one way?(because of the notches)?
and why would one be in the upper position and one in the lower position? that doesn't make any sense to me... can you explain?
(I will post pics when I get home tonight)
Woody
Woody
LOSI SCTE
Tekno EB48
Old 09-13-2006, 03:38 PM   #8998
RC_Woody's Avatar
j/k
More droop means lower the number on a droop gauge.
I think of it this way - if you have 0 or no droop your tires will lift instantly measuring up travel. To Do this you have raise the arms with the droop screw right? So on a droop gauge that would make the numbers go higher the less "droop" you put in your car.
What you are talking about measuring 1.5 or 2 above ride height is called "Up Travel" most of the guys at our track do it this way.
Woody
Woody
LOSI SCTE
Tekno EB48
Old 09-13-2006, 03:56 PM   #8999
syndr0me's Avatar
I believe the diffs can be mounted high or low by rotating the bearing holders in the bulkheads. I imagine it's possible to have one up and one down, but it seems like it would be very apparent. It's worth checking, though, just to be certain. Pretty much everybody runs them in the down position.
I've been running the RDX for two years now, and it's been through some brutal accidents in its time. I've bent bulkheads, broken arms, bumper braces, bumpers, shock towers, steering knuckles, etc. Never, though, have I ever flipped a belt. It seems like there's gotta be something wrote causing it to happen so easily.
Old 09-13-2006, 04:01 PM   #9000
syndr0me's Avatar
Droop is a tough one for people to understand. I prefer to use uptravel. Slide a ride height gauge under one end of your car. Lets say it reads 5mm, which would be your ride height. Then, hold down the wheels at that end of the car, and pull the suspension up as much as you can until it bottoms out, then slide the ride height gauge under your car again while holding the suspension in its upmost position. The difference between that measurement and your ride height is your uptravel. Lots of guys use that instead of droop since it's a more universal and consistent way to measure and express that particular setting. It's essentially two different ways of measuring and explaining the same variable in your car's setup.
Almost every foam/carpet setup I've seen uses 2MM of uptravel at each end of the car. It's a VERY powerful adjustment, so it's good to make sure you've got it right.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
