Old 09-11-2006, 08:22 PM   #8941
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by nashrcracer
yes when EA was runningthe RDX last year they always got his special order of the EA 12 pack of arms to him every time he needed a batch.
At least I can hit a fast lap every now and then with a car....You get a good car and are still a second a lap off the pace
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-11-2006, 08:23 PM   #8942
raffaelli's Avatar
ummm....Did I mis the part where Jeff said "Oh crap...the new car has been leaked out in the photo of the tweak station"?
24ITA
raffaelli is offline   Reply With Quote
Old 09-11-2006, 08:24 PM   #8943
Mr. McGoo's Avatar
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 09-11-2006, 08:24 PM   #8944
Chris Adams's Avatar
I have three rctech windows open...
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 09-11-2006, 08:26 PM   #8945
Mr. McGoo's Avatar
we are such dorks....i have 3 (rctech, mikes, and my fantasy football)
Old 09-11-2006, 08:29 PM   #8946
I was just joking.... response to andrews question... But yes, dorks...
Texas EOS 2018!
Old 09-11-2006, 09:04 PM   #8947
syndr0me's Avatar
Trader Rating: 32 (100%+)
I have the same problem with my car's turning. Corner entry, NO problem at all, but it pushes like hell on power out of the turns. I'm running 6 degrees up front, but I notice a lot of guys are moving to 4 and even 3.
syndr0me is offline   Reply With Quote
Old 09-11-2006, 09:10 PM   #8948
nashrcracer's Avatar
R/C Tech Charter Subscriber
childs play
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 09-11-2006, 09:30 PM   #8949
tbeardmore's Avatar
Running rubber?
Try front anti-dive w/ 4* castor... works for me...
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 09-11-2006, 09:45 PM   #8950
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default foams
I'm having the same problem running foams.
4 degree Chubs.
car wants to push on mid.
i put 1mm wheel spacers in front and back which made the car feel a bit more neutral.
should i try changing my antidive/kickup? is so up on the front or down..
the car handles entry and exit just fine.
olhipster1 is offline   Reply With Quote
Old 09-11-2006, 10:00 PM   #8951
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Big Rigg
I've noticed that there appears to be 'new' outer hingepins that are oh so very slightly larger around, they work fine in the new arms but will bind up in the old (25, 50, 75) arms... all I did was bevel the flash away from both sides of the holes on the old arms until the 'new' pins would fit in smoothly... I only use the setscrew and not the eclips... hope that helps
I belive you are right there about two sizes. I measured up a few different outer hinge pins I had laying around and found two distinct sizes.
The set that came on the car and was free without slop in the 75 arms was 2.32 mm. THey were free even when used with both e-clips and set screw.
The set that I bought recently to replace some bent and broken pins measured 2.36 mm. These rotate with some resistance in the arms. I wish they were big enough to chuck in my dremel. I could just take some sand paper to them so get them to work perfect. Oh, well. At least I know now.
Old 09-11-2006, 10:06 PM   #8952
Jeff Brown's Avatar
Originally Posted by T1Raycer
jeff you dont want to deal whit me anymore??? hehe!!
ill contact fastcats to see if we can do something about the order from corallyusa!!
Later!!
We will always help out. We just want to promote the local hobby shops since they provide the places to race.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 09-11-2006, 10:13 PM   #8953
tbeardmore's Avatar
4 degree Chubs.
Maybe try 1 to 1-1/2 mm more rear droop - allows more weight transfer to the front.
60wt front shock oil / 40-45wt rear shock oil w/ foams.
also take 1-mm droop out of the front - which stops weight transfer to the rear on power...
Try it - you might like it!
Old 09-11-2006, 10:18 PM   #8954
tbeardmore's Avatar
HEY Jeff B!
Workin Kinda LATE tonight aren't you????
BTW.... if you find a little box at work that has a "12" and an "X" on it.... don't forget to pack it in your Vegas bound suit case...
I think it has my name on it tooooo...!
Old 09-11-2006, 10:24 PM   #8955
syndr0me's Avatar
I'm running on foams.
I'm not convinced it's not my driving that's the issue, but at my current skill level, it feels like the car turns really well during entry, and pushes like mad on exit.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
