Old 09-01-2006, 08:57 PM   #8776
Originally Posted by Big Rigg
You shouldn't have to grind anything, the only thing you need to run a 1way is the larger bearings and holders for the 1way... that groove fits into both the diff/spool and 1way bearing holders
Thanks,I took the front end apart to install the bearings and holders and they fit right in! According to the directions the bulkhead had to be ground a little.That's what I get for reading directions!
I have another question.I received a set of Tamiya shocks with the car.I noticed they are a bit shorter than the RDX shocks.Is there an adapter I ahve to use to mount these? Thanks.
outlandr91 is offline   Reply With Quote
Old 09-01-2006, 09:01 PM   #8777
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
you should just use the corally shocks. They work really well
wallstreet is offline   Reply With Quote
Old 09-02-2006, 05:47 AM   #8778
Hey all,
I just got my rdx and i would like to know what pinion i should use wit my car, its a rdx with the standard kit spur and im using a gtb novak 5.5.
The track is small-medium size outdorrs apshalt. Please also tell me what spur the normal kit one is?
Jamie
jamie814340 is offline   Reply With Quote
Old 09-02-2006, 07:48 AM   #8779
HarshGuy's Avatar
Tamiya shocks work just fine withour any special adapters.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 09-02-2006, 06:16 PM   #8780
I plan to run the Corally shocks,but,like I said, I noticed the Tamiya shocks are visibly shorter and I wondered how they mounted to the car.
Old 09-03-2006, 09:05 PM   #8781
RichO's Avatar
Default Spacers for toe-in/out
On the toe-out adjustments on the front of the car, it is unclear to me in the instructions whether to just add a .5 spacer to the 0.8 spacer to get .5 toe-out, or remove the 0.8 spacer and replace with a .5 spacer?
RichO is offline   Reply With Quote
Old 09-03-2006, 10:07 PM   #8782
Jeff Brown's Avatar
Well, I am assuming you mean arm sweep....... which would be adding a 0.5mm shim in addition to the 1.0mm shim all the way around. If you want toe-out then do it with tie rods, not shims.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 09-03-2006, 10:07 PM   #8783
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The spacers are only used to adjust toe in the rear. For front toe you should just adjust your turnbuckles to adjust toe in/out. I belive it is commonly accepted that what is called a .5 spacer is used to achieve about .5* (in the rear) although it is actually .4 mm thick. To get 1*, use one of the thicker spacers that are actually .8 mm thick. The only purpose for spacers in the front is to widen the car. 2 thick washers (1.6 mm technically) under each of the four front roll blocks is pretty standard. Someone please correct me if I am mistaken.
Old 09-03-2006, 10:14 PM   #8784
Jeff Brown's Avatar
You are correct. There is also arm sweep in the front end which is created with washers.
1 deg = .8mm and 1/2 deg = .4mm washer. They do the 0.5 and 1mm shims to keep it simple.
Jeff
Old 09-03-2006, 11:32 PM   #8785
RichO's Avatar
For carpet, is it standard practice to add 2x1mm spacers to each of the low roll blocks or is a single 1mm spacer (as specified in the manual) the right way to go?
I am using the new arms if that effects the answer.
Old 09-04-2006, 12:52 AM   #8786
syndr0me's Avatar
Trader Rating: 32 (100%+)
Heh, XRay is testing a new T2 designed specifically for carpet. Lowered topdeck and bulkheads, thick chassis... What's it been, 6 months?
syndr0me is offline   Reply With Quote
Old 09-04-2006, 07:33 AM   #8787
Spacing the front arm's with 2 1mm spacers at the roll block's , what does that do?
Corally USA - Specialized R/C - eXpress Motorsports - MW Designs - rD2
xxx787 is offline   Reply With Quote
Old 09-04-2006, 07:37 AM   #8788
I have been told the same thing by someone I trust to know these types of things. Again, glad to be with Corally!
Old 09-04-2006, 09:28 AM   #8789
Thraex's Avatar
Me with my keen eyes spotted something.
Corally just came out with a tweakboard. They also made a animation of it (you can see it on their website), and look what is standing on the board...
(it's is bit blur, but it's something)
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 09-04-2006, 09:55 AM   #8790
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Thats NOT a normal RDX!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
