Old 08-27-2006, 12:32 PM   #8641
Tez
Hi
Ive noticed that some of the set up sheets im interested have lowered shock towers, what do i have to do to achieve this? Cheers.
Tez is offline   Reply With Quote
Old 08-27-2006, 12:36 PM   #8642
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
http://www.speedtechrc.com/store/ebp...id=443&id=5865
Old 08-27-2006, 12:36 PM   #8643
tbeardmore's Avatar
Originally Posted by Tez
Hi
Get the lowered shock tower here:
http://www.corallyusa.com/2005/parts/79239.gif
Primarily used for Foam Carpet set ups.
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 08-27-2006, 12:50 PM   #8644
Tez
Also i have the choice of running foam or rubber on the carpet is there a better choice between them?
Old 08-27-2006, 01:01 PM   #8645
Are the newest kits going to include the lower tower, new arms, milled chassis for moved motor, Motor plate ?
Chris Reilly is online now   Reply With Quote
Old 08-27-2006, 01:01 PM   #8646
Centered motor plate
Sorry about that.
Old 08-27-2006, 01:02 PM   #8647
tbeardmore's Avatar
Hi Tez -
Foam will definately be quicker... maybe .05 to 1 sec. per lap but, the benefit to rubber is you don't have to constantly change your setup and gear ratio due to tire wear.
Another benefit is your tires don't "Chunk" and ultimately costs less.
Once you get your car setup - you're good to go. Then all you have to work on is motor and driving technique.
PS: you won't need the "short" shock tower if you run rubber because the tires are larger / consistant diameter.
Old 08-27-2006, 01:06 PM   #8648
Tez
Thanks!!
Will rubber on carpet set ups be ok for asphalt? or will there be a major difference?
Old 08-27-2006, 08:01 PM   #8649
Joel Lagace's Avatar
LOL not without first making a new name: RDX US CARPET BALANCED EDITION with a extra $40MSRP I dont think to many pro cars get the running changes like that. Look at 415. version 10 out each one has its own new box! LOL
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-27-2006, 08:33 PM   #8650
RichO's Avatar
Holy smokes... I think I just had a heart attack while shopping for an RDX.
$230 bucks in extras for carpet on top of what is considered the carpet car. Wow... on top of a $430 car. Wow how times have changed in R/C.
So what is on this shopping list:
- lowered shock towers
- black springs
- 6 degree c-hubs
- steering blocks
- updated arms
- low roll-center mounts (still don't get why these aren't in the kit)
...and I am probably still missing stuff.
RichO is offline   Reply With Quote
Old 08-27-2006, 08:46 PM   #8651
shaggster's Avatar
[QUOTE=tbeardmore]Hi Tez -
Foam will definately be quicker... maybe .05 to 1 sec. per lap but, the benefit to rubber is you don't have to constantly change your setup and gear ratio due to tire wear.[QUOTE]
What's up Todd. What are you going to be running at the October race at the Plex?
Shaggadellic Paints
shaggster is offline   Reply With Quote
Old 08-27-2006, 08:49 PM   #8652
Jimmy Morris's Avatar
edit.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 08-27-2006, 09:24 PM   #8653
Joel you are probably right. Just get spoiled by Mugen. The updates came in the newer box.
Is that what it really costs for the car and parts to get ready for carpet?
Old 08-27-2006, 09:48 PM   #8654
CHRIS Ill be running rubber on carpet, and you know what i just run the F'N cars as they are out of the box. I'll get springs and a oneway and leave the hopups for guys with too much time and money! LOL My FK04 is box stock and it runs with the t2,fk05 and rdx...
I dont race enough anymore to report back and say hey that 3mm chassis was the S#@$ compared to the 2.9mm chassis! LOL And that the carpet towers really improved my lap times..
You know those ultra low roll center parts are 12$CND!! and you need 8 to convert the car!! WFT... lol ill pass and use a cheaper tunning option.. Dont even get me going on the $80US motor mount holy crap!!
www.rcottawa.com
Old 08-27-2006, 10:59 PM   #8655
syndr0me's Avatar
Trader Rating: 32 (100%+)
Don't forget the 4mm chassis and offset rear bulkhead for another $200. The ultimate bumper system, and some steel CVDs might not hurt either.
Every car has hopups and upgraded parts available, especially one that's been on the market for two years. I'll take updated parts on a proven chassis over releasing a new chassis every year.
The low roll center blocks don't work well with rubber tires. I can't decide if the carpet spec kit is designed with foam or rubber in mind. Either way, it's nice, at least, that Corally makes parts available with foam carpet racing in mind, especially considering how specialized it is. There's plenty of larger companies that don't produce these kinds of parts for their cars.
- black springs
- 6 degree c-hubs
- steering blocks
- updated arms
syndr0me is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
